First Build, Maybe A Little Help? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 42 Old 03-17-2014, 04:49 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Originally Posted by AVI20 View Post
Thank you! You guys are so helpful and knowledgeable! I am really excited to go start these!!
Edit: Im going with the ZA5.5tt - MMTMM 2.5-way vertical array design.
I am going out to start building the box right now, anything special I need to know? Im pretty sure the pdf of the design shows all the ports and such needed
Good for you! I have been wondering why we don't see many folks building the Zaph designs! I really like the way Zaph has the designs laid out, making it much easier to understand. The ZA5.5 should be a great sounding speaker! Especially considering it's low price, which is half of what you would spend building something like the Statements, which are another speaker that I absolutely love! Good luck with your build, and be sure to post pics and details along the way of assembling and finishing it out!
AVI20 likes this.
Martycool007 is offline
post #32 of 42 Old 03-17-2014, 06:14 AM - Thread Starter
AVI20's Avatar
Will do for sure! Thanks again!
AVI20 is offline
post #33 of 42 Old 03-17-2014, 05:03 PM - Thread Starter
AVI20's Avatar
Couple more questions, what would the best setup be for powering these towers? And if I did the towers and then sub in a month or so, I would have to higher the xover on the mids right? So I don't get any overlap? Would that be the best sounding or just the towers alone?
AVI20 is offline
post #34 of 42 Old 03-17-2014, 05:57 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
I can't find any power ratings for those towers but I think you'll be alright with a 150w amp. You'll need a sub, the towers only go down to 55hz. A 80hz crossover is recommended when crossing over to a sub but you tweak it to your liking.
AVI20 likes this.
Mrkazador is offline
post #35 of 42 Old 03-17-2014, 08:18 PM - Thread Starter
AVI20's Avatar
Yeah sounds similar to car audio...
So the sub up to 80hz, the mids from 80hz to ?(whatever the tweeters are rated at), and then tweeters from there up?
AVI20 is offline
post #36 of 42 Old 03-17-2014, 08:21 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
The crossover handles the cross from midrange to tweeter so you don't have to worry about that.
AVI20 likes this.
post #37 of 42 Old 03-17-2014, 08:33 PM - Thread Starter
AVI20's Avatar
Right, sorry.
http://www.zaphaudio.com/ZA5/ZA5.5tt-crossover.gif
thats the crossovers for the mids and tweeters, you said that the towers go down to 55hz right? Thats for the mids? So do I need to modify the crossovers so they only go down to 80hz?
AVI20 is offline
post #38 of 42 Old 03-17-2014, 09:00 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
That is handled by a receiver (bass management) or a DSP (minidsp).
AVI20 likes this.
post #39 of 42 Old 03-17-2014, 09:12 PM - Thread Starter
AVI20's Avatar
Awesome! Sorry for all the questions, but you have ALL the answers! Thank you again and im sure I will have another question sooner or later, hopefully working on them tomorrow!
AVI20 is offline
post #40 of 42 Old 03-30-2014, 06:41 PM - Thread Starter
AVI20's Avatar
Clamped everything and used a jigsaw (table saw not available)
Giving myself 1/16 of an inch so I can flush trim after I cut
Pretty nice these clamps hold after I finish the cut
Making all the glued edges perfectly sealed, and I know the wood split, I repaired it with some bondo :)
Gettin there
Digital caliper worked its wonders!
45 Degree on the back of the drivers
Love the snap-on die grinder for removal of all those nails that missed
Finished baffle with some repaired holes
Had to do two passes with the router as its only .25 of an inch
AVI20 is offline
post #41 of 42 Old 03-31-2014, 05:33 PM - Thread Starter
AVI20's Avatar
Also one question, as far at the ports out the back, are they just evenly spaced in the enclosure? And are they just cut straight or cut and then rounded over? Thanks in advance!
AVI20 is offline
post #42 of 42 Old 04-02-2014, 06:32 AM - Thread Starter
AVI20's Avatar
And also, for painting is bondo ok to fill all the ends and nail holes?
AVI20 is offline
