Twin Alpine SWR12D4 - 8 ohm? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-16-2014, 08:59 AM - Thread Starter
tstape's Avatar
Just joined the forum. I hope this isn't too generic for this particular forum. Please let me know if I'm in the wrong forum, and I'll post where most appropriate.
Head unit: JVC KD-R740BT
Amp: Kenwood Kac-9105D 1800-Watt Class D Mono Amplifier
Speakers: Twin Alpine SWR-12D4, Dual 4-ohm Voice Coils
Box: Ported
The Alpine directions had me install a jumper on each speaker. This converted each to 8 ohms. I have each speaker wired to individual connector terminals on the box, so each speaker is wired to the amp separately.
Should I remove the jumper cables so the each speaker is 4 ohms, and still run individual speaker wires to the amp?
Should I wire the speakers together (changing ohms) and only run one speaker wire to the amp?
If I wire the speakers together, should I wire outside the box (it's ported so I'm not sure about running wires through the center walls)?
tstape is offline
post #2 of 7 Old 03-16-2014, 10:34 AM
Bombelman's Avatar
Quoted: 56 Post(s)
Liked: 52
I would not wire it in 8ohms, no much power from the amp that way.
Your Kenwood amp is 1 ohm stable so you can wire all positive terminals together to the positive terminal on the amp. Same goes for the negative leads
Bombelman is offline
post #3 of 7 Old 03-16-2014, 03:20 PM - Thread Starter
tstape's Avatar
Rewired per your suggestion to 1ohm, then set the gain using a multimeter. Much better. Thank you.
tstape is offline
post #4 of 7 Old 03-16-2014, 03:31 PM
Bombelman's Avatar
Quoted: 56 Post(s)
Liked: 52
You're welcome !
According to the Kenwood specs, your amp is 1-ohm stable.
This amp will deliver more power to the subs in 1-ohm, than 2, 4 or 8 ohms...
Because you are running this amp at max capacity, do make sure you're not overheating it and make sure your wires are of sufficient size, 1-ohm can melt things pretty quickly (don't ask how I know this biggrin.gif )
Just finished my 2x Dual 4-Ohm Pioneer TS-W3003D4 subs also, in a 1-ohm load to the amp.
Kenwood specs source: http://www.kenwoodusa.com/car_entertainment/amplifiers/kac-9105d
post #5 of 7 Old 03-16-2014, 03:41 PM - Thread Starter
tstape's Avatar
Now I am nervous. I bought a kit for the wiring. 4 gauge for battery and ground. 14 gauge for speakers. Is that enough?
I thought running at 8 ohm would be harder on the amp, cause it need to work harder to push through?
tstape is offline
post #6 of 7 Old 03-16-2014, 03:57 PM
Bombelman's Avatar
Quoted: 56 Post(s)
Liked: 52
I don't even think it could handle 8-ohm, but see it this way, in 1-ohm your amp is pushing more Watts to the subs.
4ga for power is great, as is 14ga for your subs ;-)
Class-D amps don't get hot like Class-A/B, don't you worry... biggrin.gif
Happy Thumpin' !!
post #7 of 7 Old 03-16-2014, 04:53 PM - Thread Starter
tstape's Avatar
Thanks, appreciate all the help.
tstape is offline
