Enough theory talk, I gotta build something. Celestion FTR12-3070C - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #481 of 509 Old 10-21-2014, 02:59 AM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 176
I can't wait to hear more about it tux! Will it be available as a DIY kit in the future?
mlah384 is offline
post #482 of 509 Old 10-21-2014, 06:49 AM - Thread Starter
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1725
No, it won't be available. I'm offering the XOers if someone wants to source all the other components themselves. Once I post the measurements and get feedback from the GtG I'll say more on that.
tuxedocivic is online now
post #483 of 509 Old 10-21-2014, 08:18 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Originally Posted by chalugadp View Post
Vancouver part 2
Linky?
I would love to read and follow that. The first one was cool. You guys are just on the other side of the world from me... lol.
Mfusick is offline
post #484 of 509 Old 10-21-2014, 09:59 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
jbrown15 is offline
post #485 of 509 Old 10-22-2014, 06:42 AM
eXa
eXa's Avatar
Oh my. The DO WANT feeling on theese speakers surpassed the 1099.
Quick question. You said that everything fell in place when you lowered the XO to 900ish. Do you think a Sesos 15 could be beneficial on this? Not talking a straigth swap, but with matching XO. (Question just for mental excercise/curiosity)
eXa is offline
post #486 of 509 Old 10-22-2014, 07:42 AM - Thread Starter
Liked: 1725
Hi eXa.
Well, for mental excersize, yes, a SEOS 15 would be better. But so would adding mids and going to 15" woofers and active XOers, and... 900hz is very low for the waveguide, but I still have an excellent directivity match, which you'll see when I port my measurements. It's not so low that the woofer can't pick up the directivity in time.
Good question
post #487 of 509 Old 10-22-2014, 08:56 AM
eXa
eXa's Avatar
Cant wait
eXa is offline
post #488 of 509 Old 10-29-2014, 09:45 AM - Thread Starter
Liked: 1725
Ok, probably the last bump unless something happens/changes.
Here's the on axis response with and without the grills. Blue is without grills.
Here's 0, 30, 60 degrees.
And here's the ground plane bass response.
post #489 of 509 Old 10-29-2014, 11:58 AM
Nate Hansen's Avatar
Quoted: 252 Post(s)
Liked: 162
Nice work! I'm kind of surprised you have such a nice match running the seos 12 that low.
I see you have a dip off axis around 14khz. Probably not audible, but I've seen the same thing with my waveguides. Some plumbers putty smoothes out the little gap between the cd and the wg throat and takes care of the dip. I noticed it cleaned up the hf hash a bit as well.
Nate Hansen is offline
post #490 of 509 Old 10-29-2014, 12:20 PM - Thread Starter
Liked: 1725
I thought it might be the phragm breaking up, hadn't considered the throat but that makes sense. I'm not sure I'll bother though. My other CD measures with less "hash", but does have some off axis irregularity.
post #491 of 509 Old 10-29-2014, 12:45 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
That dip is caused by the phase plug in the compression driver. Way back when I was testing the plastic SEOS-15 samples against the fiberglass I had a similar dip show up on the plastic model but not the fiberglass. It had me perplexed and Erich was really worried something was wrong with the mold. I was playing around with it more and figured out depending upon the angle the CD is mounted the dip changed or disappeared. (I had it clamped on to try the different angles.) Try measuring the opposite side it might not be there on that side. I would post a graph but I am on my phone.
mtg90 is online now
post #492 of 509 Old 10-29-2014, 12:49 PM - Thread Starter
Liked: 1725
I certainly tried to center the CD as best possible. If I find time I'll check it out. I would never hear that TBH.
post #493 of 509 Old 10-29-2014, 05:19 PM
Quoted: 252 Post(s)
Liked: 162
mtg - are you talking the angle of rotation? If that's the case then I would think the phase plug is flawed. On my waveguides I noticed that off axis null measuring both sides horizontally and vertically. The plumbers putty took care of that in every direction that I measured.
post #494 of 509 Old 10-29-2014, 09:49 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
Yes the angle of rotation that the CD is mounted, The fiberglass has the mounting holes vertical while they are at an angle on the plastic waveguide. Looking back at my measurements what I saw is not as severe as what is in Tux's measurement. Maybe this is not the same thing. Here is my measurement, only about 3dB when 40+ degrees off axis which is not really audible. (I went to 60 degrees with these):
mtg90 is online now
post #495 of 509 Old 10-29-2014, 10:03 PM - Thread Starter
Liked: 1725
If you use any smoothing that may be why mtg. I don't have any smoothing on those graphs, just gating. Which leaves the top octave extremely high resolution.
post #496 of 509 Old 10-29-2014, 10:19 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
Shoot I forgot, looks like it was 1/12th on that graph.
Here is 0-40-60 degrees without smoothing, it's a very narrow notch:
mtg90 is online now
post #497 of 509 Old 10-30-2014, 07:46 AM - Thread Starter
Liked: 1725
Ours look really close now I think.
post #498 of 509 Old 11-13-2014, 10:07 AM
Wahoo_envy's Avatar
Quoted: 30 Post(s)
I think this is the design for me. I like the cast frame woofers and the fact that it will dig lower than some of the other designs.
Would it change the sound characteristics if these were place on a 12" high sand-filled stage or was the intent to be placed on the floor? In my case, I would place them within a foot of the front edge.
Also, is it possible to use the Tempest baffle with your port specs and crossovers?
Great job BTW! Mine will be hidden behind an A/T screen and false wall--so no need to be that aesthetic.
R/Shawn
Wahoo_envy is offline
post #499 of 509 Old 11-13-2014, 10:23 AM - Thread Starter
Liked: 1725
Hey Shawn.
The idea is the lower woofer is floor loaded, and that give it more kick, but if it's on the stage within 12" of the main floor I think you'd be ok. It's like any speaker you put in your room, the sound can change. When I brought them to jbrown's they were on the edge of his 12" riser and they worked great. His room has a big suckout at 80 and 250hz. But I think you're within the general intent of what I designed here.
I started making drawings and stuff in case people wanted to build these. I haven't had much interest. And I have talked to Erich about how he could sell people the parts. I do have the bill of materials done though for anyone who wants to see what's involved cost wise. It's not a cheap speaker. The XO is complex with big values too. If you'd like to have a look at that just PM me your email and I'll send it to you. I'll try and finish the CAD drawings of the box design aswell so you can see that. Or anyone who wants to see.
As for the Tempest baffle, it would work. Even the tuning is very similar. But it's tricky cause there are two woofers. So I'm not sure what you'd do there... I was thinking most people would just build one big speaker, not modular like I did. But either way would be just fine.
post #500 of 509 Old 11-13-2014, 11:36 AM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 176
BTW, Axel finished his bowl
Actually, your son may have just designed the ultimate speaker enclosure and we are all just too dumb to have noticed!
mlah384 is offline
post #501 of 509 Old 11-13-2014, 11:49 AM
Wahoo_envy's Avatar
Quoted: 30 Post(s)
That is funny. When I first glance at this thread, I thought he was making wooden wave guides by hand and immediately dismissed the possibility of this build due to complexity. I'm glad I finally finished reading the whole thread, but that wasn't until I read the results of the Vancouver GTG.
post #502 of 509 Old 11-13-2014, 12:47 PM - Thread Starter
Liked: 1725
Ha, in retrospect, I can see how someone would have thought that! Not a bad idea. I've done small round waveguides for dome tweeters from wood.
post #503 of 509 Old 11-13-2014, 08:27 PM
Wahoo_envy's Avatar
Quoted: 30 Post(s)
Hey Shawn.
That will be great to see the BOM and drawings. PM with my email address has been sent.
Another question about the lower woofer--how bad would the performance of the speaker be effected with the screen frame cutting across the woofer horizontally?
post #504 of 509 Old 01-21-2015, 08:07 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Ryan,
I am coming here to continue the question I had about the speaker on the bottom. I am curious to the reasons why ? (I want to learn)
Can you explain a little in the design choice of that, versus a MTM type with a SEOS in between two. I have seen a lot of other speakers designed like that too, so I am curious to hear your thoughts on this.
Mfusick is offline
post #505 of 509 Old 01-21-2015, 09:33 AM - Thread Starter
Liked: 1725
Thanks for coming here, didn't want to clog up that guys thread.
To do a TMM, you usually have to make it a 2.5 way XO, which is what I ended up doing here. The advantage of a 2.5 way the way I've done it is the woofer is boundary loaded, so tons of bass output. It also helps to minimize the floor reflection and ceiling reflection to a lesser extent, but doesn't do it quite as well as the MTM. It also has the practical advantage of not being as tall. This was quite important to me. A disadvantage of 2.5way is XO complexity and it robs some effeciency out of the midrange. I find the effeciency to not be an issue. Effeciency matters most at 100hz. This is where the baffle step losses are happening, sound tracks are demanding, etc.
An MTM on the other hand will have more vertical directivity (assuming not a 2.5 way with the MTM) so it'll actually do a better job at reducing floor and ceiling reflections. But as far as bass is concerned, both woofers are in full space (sorta). So it won't have quite the oomph in the bass department as my setup. It's also very tall and tippy. Another draw back of it not being 2.5way is you can get lobing, or nulls, in the vertical direction. Especially with such a large spacing between the woofers. Generally, the bigger the speaker the harder this is to deal with. The 10" size is generally ok, even with a 1500hz XO (Cinema 10 Max). But that does have nulls beyond 20 degrees vertically. But a 12", even if crossing down around 1000hz (quite low) would be worse. Then at 15" it's pretty much impossible. You'll get nulls even 10 degrees off probably. That's with the SEOS which is quite short. Most waveguides are taller than the SEOS.
Hope that helps.
post #506 of 509 Old 01-21-2015, 09:39 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Awesome! Thank you! Intelligently explained and exactly what I was looking for.
Mfusick is offline
post #507 of 509 Old 04-06-2016, 12:11 AM
eXa
eXa's Avatar
Would this design still be relevant with the 1299 on the marked? Seemes like the price wouldnt differ much between the 2 anyways.
eXa is offline
post #508 of 509 Old 04-06-2016, 08:14 AM - Thread Starter
Liked: 1725
It would depend on what someone wants. This would be higher WAF, as it's much smaller, but still has the benefits of 12" woofers. The 1299 should outperform it. I still need to do some comparison listening with the 1299 and other designs. Maybe I'll throw this in the mix.
Ryan
post #509 of 509 Old 04-06-2016, 01:51 PM
eXa
eXa's Avatar
Allright. WAF has a low priority for me... so, might aswell go for 1299 if that sound better. 1299 beeing a kit also helps.
tuxedocivic likes this.
eXa is offline
