DIY Acoutic Panels or flower prints... - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 03-21-2014, 11:32 AM
bass addict's Avatar
Quoted: 372 Post(s)
Liked: 448
Originally Posted by cessna1466u View Post
Nice, is that a subwoofer on top of a subwoofer on the second picture? Also doesn't wrapping it in plastic sheeting defeat the purpose? I thought it was supposed to be porous? I am really lost now.
The plastic sheeting is there to prevent reducing upper frequencies too much, while still allowing the broadband to do it's job.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #32 of 37 Old 03-21-2014, 11:36 AM - Thread Starter
cessna1466u's Avatar
Quoted: 117 Post(s)
Liked: 204
Got it, there is some great information here. The more I read on it the more I think what I wanted to do is not going to help. I do not have permission to fill the corner with sound dampening material. The frames are on and approved but not much more. She is letting me at a rear channel speaker thought, so I will be asking about that later. I only have room for 1 so it will be 6.1 only. Don't know if its worth the effort.
cessna1466u is offline
post #33 of 37 Old 03-21-2014, 11:46 AM
Spanglo's Avatar
Quoted: 491 Post(s)
Liked: 436
Yes, I was playing around with sub placement. Currently have both my 18's in that corner.
Tip: For WAF, first build the traps, then ask your wife to choose the fabric. She probably has better taste than you, and is less likely to have a problem with something she picked out.
PSN - Hapi_Kilmore_v3
My 6.4.4 Living Room HT
Spanglo is offline
post #34 of 37 Old 03-21-2014, 01:45 PM
JackNC's Avatar
Quoted: 140 Post(s)
Liked: 39
Originally Posted by Martycool007 View Post
Bill is correct. The reasoning behind using two layers of drywall and green glue/clips are for sound proofing.
Actually, we are both/all three correct. Here is a quote form Premium Home Theater by E. Geddes, talking about constrained layer damping with two layers of Gypsum board with a layer of mastic between:
"The first goal is sound isolation. The CLD panel does not transmit sound as effectively by converting it to energy. Second, it adds considerable low frequency sound absorption..... With a fairly hard surface treatment it will basically act as a damper at lower frequencies, one whose damping coefficient will decrease with frequency - which is exactly what we want.!"
Its fairly expensive technique (requires two layers of Gypsum on spring clips) but he claims it works very well and best of all, when done its invisible and takes up little space in the room.
Jack
JackNC is offline
post #35 of 37 Old 03-21-2014, 02:00 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
From post #23 page 1;
Now, if you find you're loosing too much MF/HF, and your room becomes a bit over-damped and lifeless, you can face any of your treatment panels and bring back that precious energy. Most simply use like a 6mil plastic ... common Visqueen. You could employ paper facing, and it will start to reflect somewhere around 1khz. A "pool liner" thickness of vinyl will return around 500hz and up. If needed, you can use 1/2lb mass loaded vinyl, it exhibits returns around 250hz and up.
Wrapping, facing or covering bass traps with plastic or equivalent, can slightly increase it's effectiveness down low, and ... as stated, returns the precious higher freqs.
Rooms need treatment. Primarily, they need bass trapping, to even out room decay times, because inherently there's more bass energy over time ... it just doesn't decay as quick as the mids and highs. This makes for less bass clarity and detail...so bass trapping, as low and as effective as possible is typically the first thing most every room needs.
With all the appropriate bass trapping, often over absorbs the mids and highs, thus the bass trap facing/covering.
I'd not recommend 6.1
7.1 is fine, but there's much more important elements; ie, Subs and LCRs.
Properly executed and blended subs, and optimized and proper LCRs are monumentally more important than rears, IMO.
cessna1466u likes this.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #36 of 37 Old 03-21-2014, 02:32 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
Originally Posted by JackNC View Post
Geddes recommends a 2nd layer of sheetrock on walls and ceiling with green glue between it and the first layer. Has anyone tried that or know how well that works relative to bass traps?
Originally Posted by Bill Fitzmaurice View Post
A second layer of sheet rock would be used to reduce transmission through the walls and ceiling to adjacent rooms or the environment. Acoustic panels are used to reduce wave reflections inside the listening room.
Well, JackNC is inquiring about bass traps, and how a second layer, or double thickness with GG in between, impacts it's bass damping/bass trapping effectiveness.
It's really important to understand a common acoustic distortion characteristic of small rooms, even treated small rooms/HTs, is an un-even decay times. It's very tough to properly damp the lower octave energy, due to the wavelength size inherent to the low freqs. Most importantly, one needs uniform decay times top to bottom. A room that has too much MF/HF absorption, relative to the LF absorption, just allows the LF reverberation to drone on, resulting in an unbalanced sound bass clarity and detail that could be much better.
The low bass clarity and detail results from the decay times masking of that part of the playback, as the lower level is overly bathed in reverberant noise. The low level details within the material simply can't be heard due to the uneven and slow decay of the more prominent sounds...masking. This results in a scenario whereby the listener can't resolve the reproduced acoustic cues that accompany the imaging. Characteristics like the decay of the recorded space... this impacts imaging spatial characteristics.
If the room's response time exceeds the material's recorded reverberant energy and is of sufficient level, the recorded details are masked.
In many rooms that difficult to achieve, but we try. Ideally, striving for uniform decay times, ... even if they're excessive, still is a step in the right direction. Similar to overly thin absorption EQ'ing a reflection, if the decay times are somewhat uniform, then at least there's no gross changes in reverberant energy.
Jack
I agree
Absorption of sound energy at bass frequencies, can be achieved with a resonant absorber... the drywall.
Just like the drywall example Jack and Geddes are talking about, a mass suspended by a spring will vibrate at it's natural frequency.
The mass of the panel, in concert with the combined springy-ness of the damping layer of GreenGlue, and the stud/air cavity, are resonant at some natural frequency. The sound energy is absorbed because of frictional heat losses of the motion.
Damping increases as the velocity increases, and velocity is highest at resonant frequency. You change the resonant frequency with the mass.
Everest states 1/2" sheetrock, on 16" studs, possesses about .29 absorption coefficient at 125hz, and it increases at 63hz.
He states 1/2" sheetrock, 16" studs, with the typical 3.75" airspace, resonates at around 60hz.
Also, double 5/8" lowers the freq to around 38hz.
Adding the mass lowers the resonant freq.
As Jack points out, in the Geddes example, both bass trapping increases, and sound egress control increases.
FOH is offline
post #37 of 37 Old 04-07-2014, 03:37 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5025
Hey Kevin or any one else...
What do you think is better?
1) 2" 703 with a 4" air gap from wall
or
2) 4" 703 with a 2" air gap from wall
or
3) 6" 703 with no air gap
Ignore cost or weight factors here. Goal is to eliminate slap echo and provide broadband absorption. Would prefer a 'slightly too dead' sound than a 'slightly too live' sound to the room. But if I can get it "just right" that would be nice too. smile.gif
Scott Simonian is offline
