about ready to start a DIY Sub build - checklist / feedback - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 70 Old 04-03-2014, 07:45 PM
schmidtwi's Avatar
Quoted: 167 Post(s)
Liked: 121
Originally Posted by homerism View Post
It looks like the PC software makes it a lot easier to make sense of the menu options, too.
iNuke software is much easier to use than the front menu. Great job on your sub!
The Schmidt Haus Theater - WIP (or not) since 2010
schmidtwi is offline
post #62 of 70 Old 04-05-2014, 05:40 PM - Thread Starter
homerism's Avatar
Originally Posted by chalugadp View Post
Yes 8 adjustable. As well q factor or quality as inuke has spreads out the peq wide or narrow.
Got it, thanks.  I still have to figure out how to make use of all these PEQ options without any feedback mechanism for calibrating them...  Maybe I'll give a demo to someone with a REW equipped laptop. ;)
Thanks and thanks. :) There are at least three cosmetic things that I could have done better with, but: a) it was my first DIY build, and b) functionally I'm pretty darn happy with how it turned out.  I got the proper speakon connector hooked up today so I can run the amp in bridged mode.  [insert bug eyed, **** eating grin.]  Even at the amp's full 750W, the sub still blends into the front sound stage perfectly.  Put your head directly in front of it a couple feet away and it pounds you pretty good, but anywhere off center and it feels like an extension of the front towers.
I turned the preamp's gain down from +10 dB (max) to +7, and have the Behringer at about two-thirds gain.  I'll play with it further and re-run the EmoQ calibration now that the sub isn't running on 25% power.
homerism is offline
post #63 of 70 Old 04-16-2014, 07:57 PM - Thread Starter
homerism's Avatar
While watching Star Trek (2009), I got what sounded like major subwoofer clipping @ 50 minutes. It happened a bit later, but not as bad, so I turned the sub amp's gain down a couple clicks. After a bit, I went into the Behringer menu to try and figure out how to set the high pass filter to 20 Hz. (I haven't tried installing the PC software yet.) It took some blind bumbling about to get into the right mode, but I eventually got it and that seemed to solve the clipping.
However, going back over that scene, my front baffle (the inner 3/4" ply that the sub is mounted to) once bouncing and vibrating like crazy, with lots of cone travel. I haven't seen that happen on any other soundtracks. Is the power of the sub/amp exceeding the strength of my cabinet, or is it a cabinet volume issue?
homerism is offline
post #64 of 70 Old 04-17-2014, 06:28 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
I could be wrong, but it sounds like a bracing problem? Is there sufficient bracing in your cabinet or did it come looses somehow?
Blazar!
blazar is offline
post #65 of 70 Old 04-17-2014, 09:18 AM - Thread Starter
homerism's Avatar
I haven't opened it up to see -- will probably require an extra set of hands to tip it forward carefully and get the driver to slide out -- but I braced it well front-to-back. The braces are glued (TiteBond) at both ends and screwed to the inner front baffle, but I didn't screw them at the back. That's one point of failure that may need looking at.
homerism is offline
post #66 of 70 Old 04-17-2014, 07:57 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
I am trying to figure out how to wire my subwoofers without the wire floping around inside and potentially vibrating.
Do you guys use some sort of more rigid wiring?
Blazar!
blazar is offline
post #67 of 70 Old 04-17-2014, 08:09 PM
Bill Fitzmaurice's Avatar
Liked: 4631
Originally Posted by blazar View Post
I am trying to figure out how to wire my subwoofers without the wire floping around inside and potentially vibrating.Do you guys use some sort of more rigid wiring?
Use solid wire, not stranded.
Bill Fitzmaurice is offline
post #68 of 70 Old 04-17-2014, 08:34 PM - Thread Starter
homerism's Avatar
I used 12 ga speaker wire with very thick insulation. Between the wire's heft and the cabinet's insulation, it should stay in place and not be resting against anything rigid to vibrate against.
I would think solid wire would be a real PITA to maneuver in and out of the cabinet.
homerism is offline
post #69 of 70 Old 04-17-2014, 09:30 PM
sooly1's Avatar
Liked: 35
I ran my wire down a brace inside my Marty and hot glued the sheet out of it then put a few pieces of scrap wood around it and brad nailed it.
sooly1 is offline
post #70 of 70 Old 04-18-2014, 06:04 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Some good ideas there, i will order some 12 guage which will be soldered to the speaker and the banana plug / spring connector. I wont need to use it to navigate outside the box except to put the speaker in.
Blazar!
blazar is offline
