Fusion-6 test build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-24-2014, 08:14 PM - Thread Starter
beck4353's Avatar
Just getting into DIY speaker building so I figured I would start small with a couple of Fusion-6 speakers. I already have all the parts and materials for a couple of martycubes, and plan on Tempest or Tux 1099 for LCR, so these will serve as rears or sides/heights or wherever.
I did a rough setup of the crossover without any box just to prove out if they worked. No problems there (I think). Didn't sound great, but no cab, not a very good source either so I am not worried.
I don't see a lot on these forums for this speaker, so I just have a few questions.
Would regular 1/2" MDF be fine for the cabinets?
I see some sort of baffle cut in the middle of the brace in the pic of the flatpack. Is that necessary? http://www.diysoundgroup.com/flat-packs-1/seos-flat-packs/35-cuft-flat-pack.html
Anyone else out there using these? Will they server their role as one of the side/surround speaker pairs?
Thanks for any input.
beck4353 is offline
post #2 of 3 Old 03-24-2014, 08:32 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
1/2" fine for cab but baffle needs to be 3/4"
beck4353 likes this.
chalugadp is offline
post #3 of 3 Old 03-25-2014, 07:07 AM - Thread Starter
beck4353's Avatar
Thanks for the reply. I did get the front baffle from Erich and it is 3/4".
beck4353 is offline
