Need a custom box built. Anyone around the Orlando FL area that can make one? - AVS Forum | Home Theater Discussions And Reviews
Old 03-26-2014, 11:04 AM - Thread Starter
Michael Adkins's Avatar
Its going to be ported to around 17hz 10-12 CF.
If not I guess i need to break out WINISD and fire up the table saw :)
Epson 8350
DIY 200" 2:35
B&W 7.1 Setup
A few 18" subs here and there!
LFE ADDICT
Michael Adkins is offline
Old 03-26-2014, 11:43 AM
Starquester's Avatar
Flatpack?
http://www.avsforum.com/t/1516724/martysub-flatpacks
Then just glue and clamp, and finish however you desire.
Starquester is offline
Old 03-26-2014, 12:34 PM - Thread Starter
Originally Posted by Starquester View Post
Flatpack?
This is good option, I have the SI 18" subs and i need to integrate into my front stage so i need something a little more custom :(
Epson 8350
DIY 200" 2:35
B&W 7.1 Setup
LFE ADDICT
Old 03-26-2014, 01:17 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Any car audio shop will be able to do it for you.
Manic1! is offline
Old 03-26-2014, 01:52 PM
I'd also list what dimensional constraints you're dealing with here.
It's pretty easy to deal with taking a proven design of a 24x24x48 box and altering it to be 20x24x52 instead for instance. Not that those figures are correct, and the port has to be reworked, but just an idea. Once your design is hashed out here, I'd shoot chaluga a PM and see what he can do for you.
A local car audio shop is definitely a good idea too, I have a couple local ones here who do amazing fabrication work.
Old 03-27-2014, 01:58 AM
Jack Arnott's Avatar
Ramsdell Pro Audio
Jack Arnott is offline
Old 03-27-2014, 06:01 AM
Bill Fitzmaurice's Avatar
Liked: 4631
Try Drey Chennells in Orlando. Email info@infracoustik dot com, website www.infracoustik.com
Bill Fitzmaurice is offline
Old 03-27-2014, 08:43 AM - Thread Starter
My MAX box size is as following:
8' Foot Wide
18-24 Tall
24-36 Deep
I want it to go as low as possible. Ill be using the INuke6000DSP to power two of these boxes.
Epson 8350
DIY 200" 2:35
B&W 7.1 Setup
LFE ADDICT
