UXL18 4 cu. ft. sealed amp power? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-28-2014, 06:51 PM - Thread Starter
bear123's Avatar
Quoted: 1470 Post(s)
Liked: 2091
Hey guys sorry I don't know this or how to figure it out, but what would be the ideal amp for this setup?  Would the Inuke3000 be good or 6000 needed/beneficial?
bear123 is offline
post #2 of 15 Old 03-28-2014, 07:09 PM
Thatsnasty's Avatar
Quoted: 43 Post(s)
Liked: 37
Inuke 3000 bridged at 4 ohms
or
Ep4000 bridged at 4 ohms.
Roughly 1900-2000 watts RMS , perfect match for the single 4 ohm coils on the UXL ( or FTW ).
Ep4000 is a flat a little bit lower but they are basically the same.
Be careful juicing the full amp power if you aren't running a high-pass filter though, but you should be okay otherwise.
Inuke6000 isn't really needed unless you have plans to get a second UXL.
Thatsnasty is offline
post #3 of 15 Old 03-28-2014, 07:13 PM - Thread Starter
bear123's Avatar
Liked: 2091
Thanks very much. Just planning on one in conjunction with an XS30.  Not sure if I am going to run a HPF but I might, as I don't seem to notice much below 16 Hz at this point.
Do you have any opinion as to the pros and cons of the Inuke vs the Ep?
bear123 is offline
post #4 of 15 Old 03-28-2014, 07:18 PM
The Red Baron's Avatar
I've heard the Inuke 3000dsp is a much better amp. That's what I would do if I were you. wink.gif
The Red Baron is offline
post #5 of 15 Old 03-28-2014, 07:24 PM - Thread Starter
bear123's Avatar
Liked: 2091
Cool thanks again.  I am thinking I can do this build for about the same or a little less than adding a 2nd XS30 with more output in the low end.  Plus I can split the cost up over the three components.
bear123 is offline
post #6 of 15 Old 03-28-2014, 07:28 PM
Thatsnasty's Avatar
Quoted: 43 Post(s)
Liked: 37
Not true, they are basically the same amp, from the same manufacturer. But do a few things different.
Inuke3000 is smaller, lighter, but does nearly the same thing is the Ep4000.
Ep4000 is around 40-50 pounds, but doesn't start rolling off until around 5hz. Inukes are supposed to rolloff slightly higher at around 10hz.
This is not a big deal as much people don't even shoot for bass reproduction that low, but around these forums, it can make a difference.
So if you don't need the DSP built in the Inuke series, and you can deal with the larger weight and form factor, the EP4000 is the better buy.
For the record I own two ep4000's and one Inuke3000DSP.
post #7 of 15 Old 03-28-2014, 08:19 PM
post #8 of 15 Old 03-28-2014, 09:37 PM
Thatsnasty's Avatar
Quoted: 43 Post(s)
Liked: 37
I have, a while ago, and it was posted on this forum.
I already know the results.
I would encourage you do the same. Unless you are hiding some mystery test that was done recently, then feel free to post it, as I'm only trying to help the OP.
http://www.avsforum.com/t/855865/measuring-amplifiers
Edit: Apparently the 3000 doesn't have the rollof of the 6000, and is closer to the ep4000/2500 amps. Still, a toss up between them.
post #9 of 15 Old 03-28-2014, 09:59 PM - Thread Starter
bear123's Avatar
Liked: 2091
I have a miniDSP, but I would probably opt for the amp with DSP anyway, seems like a valuable feature to me for the future just in case.
bear123 is offline
post #10 of 15 Old 03-28-2014, 10:09 PM
basshead81's Avatar
Quoted: 117 Post(s)
Liked: 3745
The DSP is what makes the Inuke a great value imo.
Getting Started with REW: A Step by Step Guide --> http://www.mediafire.com/view/aolmz2..._101_v3.92.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #11 of 15 Old 03-28-2014, 11:08 PM
I searched that thread and all I could find was a reference to a SPL test with the EP4000 and inuke 3000dsp in a separate thread.
http://www.avsforum.com/t/1375633/ep4000-vs-inuke-dsp-3000-w-2-jtr-captivators-and-an-omnimic-which-amp-is-better/0_100
Later in your thread they make fun of the test. Go figure...
If some one can show these two amps rms tested I'd love to see it. biggrin.gif
post #12 of 15 Old 03-28-2014, 11:21 PM
steve nn's Avatar
Liked: 433
The EP has always been a good bang for your $$ amp over the years it seems. It would be nice if they had a EP dsp option with a hp that reached down to 15 with at least the power of the 4/2500.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #13 of 15 Old 03-28-2014, 11:55 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 343
I would not touch a ep 4000 for sub duty. Id go with a Inuke 6000 if you can.
Swolephile is offline
post #14 of 15 Old 03-29-2014, 12:02 AM
To drive one UXL18 in a 4cf sealed box? That's what I got to drive two. eek.gif
post #15 of 15 Old 03-29-2014, 12:02 AM
Thatsnasty's Avatar
Quoted: 43 Post(s)
Liked: 37
It has RMS testing of the ep2500. The Ep2500 is the same as the Ep4000, and they do 1950watts RMS indicated in that thread, at 4 ohms.
I don't think the Inuke3000 has been officially tested, but it's known to be similar, or rolloff ever so slightly sooner.
We are basically splitting hairs at this point. Fan mod any Inuke series or Ep2500/4000 amp and you would be hard pressed to find a better subwoofer amp for home duty. (for the money)
What are you basing this on? The Ep4000 gives more power under 20hz then most amps.
According to Bassthathz's thread with the Fluke DMM, it actually shows it might even rolloff less then the clone amps.
taboola here
