How much cubic feet does a 12" or 15" SUB typically consume ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-29-2014, 06:16 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2668
Guess ? Anyone ?
Mfusick is offline
post #2 of 9 Old 03-29-2014, 06:19 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 87
.05 to .5 ft cubed, depends on a number of variables. I would assume . 1 for a 12 and .2 for a 15.
Are you concerned about enclosure volume being affected.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
post #3 of 9 Old 03-29-2014, 06:27 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2668
Yes. But if it's that small an amount it only effects my port tune 1hz or so.. I can live with that.
Mfusick is offline
post #4 of 9 Old 03-29-2014, 06:37 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 87
Yeah it really isn't much, that's why nobody really discusses it. If it was a concern most woofers would probably have their volume listed in their specs.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
Stumbo is offline
post #5 of 9 Old 03-29-2014, 06:45 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2668
So .5 for two 15" is pretty reasonable assumption... and .2 for a single 12" seems reasonable right ?
Mfusick is offline
post #6 of 9 Old 03-30-2014, 06:32 PM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
I think SI list the HT18 driver as 0.25 cu ft displacement: http://stereointegrity.com/index.php?id=60
MemX is offline
post #7 of 9 Old 03-30-2014, 06:35 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 87
Yeah that would work, and even if you were off by a multiple of 2, it may change your response by a small percentage of a db
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
Stumbo is offline
post #8 of 9 Old 04-02-2014, 11:18 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2668
If it's a small amount I can just guess at it and be ok biggrin.gif Thanks again for all the great replies!
Mfusick is offline
post #9 of 9 Old 04-02-2014, 11:30 AM
WVSyd's Avatar
Liked: 42
https://www.parts-express.com/resources-woofer-selection-guide
Put the Guide in Driver size order and note: F3, SPL, and Box size required
It depends on your tradeoffs and compromises ( Low frequency extension, SPL and box size requirements )
( Hoffman's Law )
"Beware of Salesmen: They are the modern Svengali, immune to Science and Reality"
WVSyd is offline
