3-way center channel build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 63 Old 03-30-2014, 11:23 PM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
I have been enjoying movies in 4.1 configuration for a while. MA BX2-s are undoubtedly great sounding speakers. But I think it's time to move on, to DIY land.
So I present you my 3-way center channel build:
As you may notice, it has:
1 x NeoX2.0 Silver
1 x Scanspeak 10F/4424G00
2 x Seas U18RNX/P
I already ordered the drivers. And I have 3/4" and 1" MDF. Friend of mine lets me use his CNC-machine to cut everything. In couple of weeks I will start building this thing (and if all goes well, matching left/right floorstanders aswell).
If you have any comments, please let me know. The size and shape of the cabinet is still undecided. Also, since a local DIY guy is designing the crossover for me, any guideline in that area is particularily welcome.
Silent HTPC.
3-way center channel build.
White Alpine build.
White bookshelf build.
nexxest is offline
post #2 of 63 Old 03-30-2014, 11:32 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
What's the sensitivity of that center and how loud do you like to listen to movies?
chalugadp is offline
post #3 of 63 Old 03-31-2014, 12:01 AM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
Sensitivity of the drivers: tweeter 94, mid 90 and woofers 88 dB. I'm still learning crossover theory but does this imply that final sensitivity could be around 89-90 dB?
I don't listen very loud (10 dB below ref with my Denon).
Silent HTPC.
White Alpine build.
nexxest is offline
post #4 of 63 Old 03-31-2014, 12:04 AM
chalugadp's Avatar
Liked: 1505
I think so. Some of the 3 way designs I have seen have sensitivity of around 85. Tough to power with avr at reference. At your numbers the denon will do fine. Looks like a nice build
nexxest likes this.
post #5 of 63 Old 03-31-2014, 05:33 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
That design looks very similar to the Ascend Acoustics Horizon center channel. I really like this design as it is able to incorporate two woofers without the same MTM issues that plague many center channel designs! This should be a pretty sweet speaker with those drivers, assuming the crossover is done right!
I would love to see a similar designed center channel but with an RAAL tweeter!
Martycool007 is offline
post #6 of 63 Old 03-31-2014, 06:37 AM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
What could be the optimal size of the box for dual Seas woofers?
According to http://www.mh-audio.nl/CBC.asp, using Fs 43, Qts 0.37, Vas 22, Qtc 0.6 - 13.5 l per driver, so 27L. Seems ok?
Cabinet will be sealed and crossed to subwoofer at 80 hz. That makes me think a port or a pair of ports are not needed.
Silent HTPC.
White Alpine build.
nexxest is offline
post #7 of 63 Old 03-31-2014, 06:53 AM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
I may be wrong. According to http://www.micka.de/org/en/index.php#ideal, using T/S parameters, QTC 0.6 and sealed configuration, F3 is 84.32 Hz. So port may be needed after all.
Silent HTPC.
White Alpine build.
nexxest is offline
post #8 of 63 Old 03-31-2014, 07:06 AM
Quoted: 280 Post(s)
Liked: 176
I can't help you with regards to the ideal box volume, but, I would go with a ported enclosure if it were me. I like the way that ported mains sound compared to sealed.
To me ported mains just sound more full, and have a somewhat different tone on the low end compared to sealed. Some folks will tell you that this is not possible as the lows are Omni-directional, and while the lows are indeed Omni, I still believe there is a different sound.
nexxest likes this.
post #9 of 63 Old 03-31-2014, 11:47 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
Originally Posted by nexxest View Post
I have been enjoying movies in 4.2 configuration for a while. MA BX2-s are undoubtedly great sounding speakers. But I think it's time to move on, to DIY land.
1 x NeoX2.0 Silver
2 x Seas U18RNX/P
Could always go this route.
http://www.speakerdesignworks.com/Statements_Center_Channel.html
nexxest likes this.
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is offline
post #10 of 63 Old 03-31-2014, 12:09 PM
Quoted: 280 Post(s)
Liked: 176
I wonder how the NeoX2.0 sounds compared up the NeoCD3.0 used in the Statements? Fountek recommends crossing over the NeoCD3.0 at 2,500 and the NeoX2.0 at 2000. I am not sure if using the Neo2.0 would be of any benefit over the NeoCD3.0 when crossed to a dedicated mid in a 3-way setup. I have heard the NeoCD3.0 in the Statement Monitors, and I personally thought that it was an outstanding performer.
I wish that we had more designs in the $900 to $1,200 price range to choose from. I rarely ever see any thing with ribbons or even domes in this price range. You can get a RAAL 10d for $300. Pair that with a nice Seas or ScanSpeak mid, and perhaps some Dayton RS series woofers, and for $1000 you could build yourself a world class speaker! Maybe one day some will do a design like this and make the design available to us HIFI DIY guys!
post #11 of 63 Old 03-31-2014, 12:37 PM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
I will experiment a bit with this box calculation tool. F3 @ 84 Hz is not low enough.
Absolutely, but there is a possibility that a friend of mine starts selling these (if they come out OK of course). That's why I picked X2.0/SS/Seas combo. To my knowledge, it hasn't been done before.
As I see it, X2.0 is newer, takes more power, has better horizontal and vertical dispersion. I have heard both, and they sounded the same to me. In fact, they sounded 95% as good as RAAL. And funny fact: X2.0 is 20€ cheaper than CD3.0.
Silent HTPC.
White Alpine build.
nexxest is offline
post #12 of 63 Old 04-01-2014, 05:06 AM
Quoted: 280 Post(s)
Liked: 176
Well this should definitely be interesting and exciting to see a non-high efficiency build, but rather, more of a HIFI type build!
Perhaps I missed, but, what mains are you going to be pairing this center channel with?
post #13 of 63 Old 04-01-2014, 06:00 AM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
Same drivers, vertical alignment smile.gif And perhaps 3 woofers, not 2.
Silent HTPC.
White Alpine build.
nexxest is offline
post #14 of 63 Old 04-01-2014, 08:47 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
Sealed or ported?
pgwalsh is offline
post #15 of 63 Old 04-01-2014, 08:53 AM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
I have always been "sealed" guy, but I guess it shall be ported. There are not many people who would buy a floorstander that has F3 @ 80 Hz.
Silent HTPC.
White Alpine build.
nexxest is offline
post #16 of 63 Old 04-01-2014, 08:56 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
Could do satellites instead of floor standers. Could probably use them for your sides and rears too.
pgwalsh is offline
post #17 of 63 Old 04-01-2014, 11:15 AM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
Not "instead", but "and". Matching center, floorstanders and satellites.
What about design?
Larger is 800 x 260 mm.
Smaller is 600 x 280 mm.
Silent HTPC.
White Alpine build.
nexxest is offline
post #18 of 63 Old 04-01-2014, 11:22 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
What about design?
Could fire the ports out the back. Instead only because you're then designing 2 speakers instead of 3. I personally prefer satellites, but I've built the Statements for a friend and they are quite awesome.
pgwalsh is offline
post #19 of 63 Old 04-01-2014, 11:44 AM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
Due to the layout of my room, center channel will be touching the wall.
Again, if this project is successful, it could go on sale.
Silent HTPC.
White Alpine build.
nexxest is offline
post #20 of 63 Old 04-02-2014, 05:46 AM
Quoted: 280 Post(s)
Liked: 176
This would be an awesome contender to the Statements, which now that I think about it, are quite different with their open backed mids and larger cabinet. I would love to see a nice, big floor standing tower with these drivers that the OP is using!
I would imagine that if the crossover is done right, these ScanSpeak mids would be as good if not better than the Tang Band w4's used in the Statements, and the Seas woofers would likely best the Dayton RS-225's.
post #21 of 63 Old 04-02-2014, 01:37 PM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
I have heard many DIY builds with Dayton and Seas/Scanspeak drivers. And not long ago sold my Audes 037's. Dayton makes some pretty good models, but is still outclassed by S/S.
Speaker layout has been decided:
And in black:
And in cherry:
Should I move woofers closer together?
Front panel: 650 x 300 mm.
Silent HTPC.
White Alpine build.
nexxest is offline
post #22 of 63 Old 04-03-2014, 08:36 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
And in black:
And in cherry:
Cherry looks nice, but I love dark woods. I prefer the one with the ports on the side, but mainly because it doesn't take up as much vertical space or perhaps it's just looks that way.
pgwalsh is offline
post #23 of 63 Old 04-11-2014, 01:55 PM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
I have something to show you.
Heavy Seas, shiny Fountek and tinyyyy Scanspeak:
Scanspeak is so tiny it's almost funny:
Gang:
Actually, they are massive. And Fountek is unbelievably heavy. Finished speaker will probably be around 30 kgs.
Silent HTPC.
White Alpine build.
nexxest is offline
post #24 of 63 Old 04-11-2014, 02:29 PM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1725
Ryan
tuxedocivic is offline
post #25 of 63 Old 04-11-2014, 03:46 PM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
It's nice just to look at them. Looking forward to this build.
nexxest likes this.
pgwalsh is offline
post #26 of 63 Old 04-12-2014, 09:26 AM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
Update:
Cutting backside:
Cutting holes:
Front:
Back:
Driver fit test: success!
PS: anyone who's planning on building a speaker using slotted panels - you are nuts! Took us 100 hours of modelling to get everything to fit. Luckily we had tons of MDF to experiment with.
Silent HTPC.
White Alpine build.
nexxest is offline
post #27 of 63 Old 04-12-2014, 10:31 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
That looks fantastic. Pictures made it look like it took 2 seconds.
Is that the picture or is the top right edge kinda funky? Part of the design?
pgwalsh is offline
post #28 of 63 Old 04-12-2014, 01:51 PM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
It's a V-shape. It all comes together when it's painted.
Silent HTPC.
White Alpine build.
nexxest is offline
post #29 of 63 Old 04-12-2014, 02:02 PM
fperra's Avatar
Quoted: 50 Post(s)
Liked: 71
Very similar design to the center channel I built:
I think you'll like yours.
nexxest likes this.
fperra is offline
post #30 of 63 Old 04-12-2014, 02:15 PM - Thread Starter
nexxest's Avatar
Quoted: 21 Post(s)
Liked: 45
Originally Posted by fperra View Post
Very similar design to the center channel I built.
I considered that Morel, but was too hard to find here in Europe. How does yours sound?
Silent HTPC.
White Alpine build.
nexxest is offline
