plans changed si 24 dual - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 03-31-2014, 11:55 AM - Thread Starter
Rhino11's Avatar
Since there are no is 18 right now avalible I will be jumping on the si 24 wagon. Just wondering which version should get d1 or d2 and which amp to get. The inuke6000 DSP for now and/or pro-lite 7.5dsp.
Thanks for you guys help need to make choice today. No more waiting.
Rhino11 is offline
Old 03-31-2014, 11:59 AM - Thread Starter
Rhino11's Avatar
Looking at going sealed like swole in 10cf box.
Rhino11 is offline
Old 03-31-2014, 12:21 PM
ChopShop1's Avatar
Quoted: 284 Post(s)
Liked: 285
Yesss!!! Welcome to the 24 club sir!
I would go bigger if you can. Testing has shown 15 cubes sealed to be about the otimal size....bigger is better, but only incrimentally from there really, withing reason. 10 will work great if you can't go bigger, just some food for thought. I'd go d2 because you can wire coils in series for 4ohm stereo...nice easy load on the amp..crest amp with 2kw a piece....or if you wanna get a bit crazy go d1 and 2 ohm stereo for almost 4kw a piece biggrin.gif
ChopShop1 is offline
Old 03-31-2014, 12:25 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5073 Post(s)
Liked: 4000
Scott Simonian is offline
Old 03-31-2014, 12:30 PM
ChopShop1's Avatar
Quoted: 284 Post(s)
Liked: 285
Old 03-31-2014, 12:38 PM
Bass Enabler
Liked: 4000
Honestly that's what I would do with these if I were intending on using them in "small" sealed enclosures. The specs released are based on the d2 version. Now this is an assumption but if there were no other changes other than the coil being wound for the d1's then there is a strong likelihood that the BL has increased and that the Qes/Qts has dropped. This would end with a lower Qtc in 10-15cuft compared to the d2's.
Plus in the smaller cabs you'll need that extra power to use up all that throw. smile.gif
Old 03-31-2014, 12:40 PM - Thread Starter
Rhino11's Avatar
Yes sir I was looking at pro-lite 7.5 it looked like a good match whether it be 2 it 4 ohm load. Maybe I can get the 1 ohm version and get to more latter and run 2 per channel at 4 ohm load smile.gif . Just food for thought
Rhino11 is offline
Old 03-31-2014, 01:30 PM
ChopShop1's Avatar
Quoted: 284 Post(s)
Liked: 285
Just razzin' ya man....I agree 100% I'm just big on not running them amp to hard.
Old 03-31-2014, 01:35 PM
Fatshaft's Avatar
Quoted: 589 Post(s)
Liked: 902
Isn't Ricci supposed to get one of these 24's to test?
I read that somewhere...I forget where...
anyways. when is he supposed to get his to test?
Sorry for the minor derail...
Rhino11...congrats on a great purchase
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
Old 03-31-2014, 01:46 PM
Bass Enabler
Liked: 4000
No offense taken at all. That's just another way I'd go about using these monsters. In your case, probably not even an issue and really in the grand scheme of things...going with either one will present similar end results of performance and satisfaction. smile.gif
Old 03-31-2014, 02:51 PM
LTD02's Avatar
Quoted: 2293 Post(s)
Liked: 2490
it depends on which amp you intend to run.
the inuke 6000 or 3000 (bridged) work with 4 ohms net well.
the prolite on the other hand can run 2ohm loads per channel. well, at least the manual says it can. :-) not sure if it is designed to run at those loads for short time frames or hours on end.
the cv5000 can run 2 ohm loads per channel as well. surprisingly, I've never seen it bench tested, but the amp that it is modeled on (crest ca18) has a pretty solid reputation.
all that said, the driver is only spec'd for 1500 watts. 1500 watts in a 15 cubic foot enclosure only gets the driver to about 25mm excursion. in order to take advantage of the massive excursion, either a really large box / infinite baffle is required or running the driver at more than rated power is required.
Listen. It's All Good.
LTD02 is offline
LTD02's Avatar
Liked: 2490
also, it looks like on the website that today is the last day before the price on them goes up...if that is relevant in your case.
LTD02 is offline
Old 03-31-2014, 03:27 PM - Thread Starter
Rhino11's Avatar
Alright got the order in.
Rhino11 is offline
Old 03-31-2014, 03:28 PM
ChopShop1's Avatar
Quoted: 284 Post(s)
Liked: 285
Yep, huge sealed/IB with rated power or much more in a 15 cube or less box. I can tell you this, you'll all know more for sure after this weekend biggrin.gif
The rated power really is comical...it's capabilities have been proven privately to be much, much more..more than double and serious abuse.
I swear I had seen a CV bench before I bought them, but can't find it for my life right now. Really solid amps and handle the load no problem at all.
LTD02 likes this.
Bass Enabler
Liked: 4000
Sweet!
Maybe I missed it but how were you going to use them?
Old 03-31-2014, 03:29 PM
ChopShop1's Avatar
Quoted: 284 Post(s)
Liked: 285
Congrats man!
Old 03-31-2014, 03:29 PM - Thread Starter
Rhino11's Avatar
I guess if i want to change it i have to get ahold of nick to change the order version. maybe i should had got the 2 ohm version. oh well i am still excited.biggrin.gif:D
Rhino11 is offline
Old 03-31-2014, 03:31 PM
Bass Enabler
Liked: 4000
You should be fine. You can always hook them up together for a 4ohm load at the very worst.
Old 03-31-2014, 03:32 PM - Thread Starter
Rhino11's Avatar
ya worst case i can just get 2 more and wire them for 4 ohm:eek:.
Rhino11 is offline
Old 03-31-2014, 03:33 PM - Thread Starter
Rhino11's Avatar
Rhino11 is offline
Old 03-31-2014, 03:34 PM
Bass Enabler
Liked: 4000
You don't have to buy two more to get a 4ohm load.
D1's are 2ohm with the coils in series. Two 24d1's (like you just ordered) in series would be 4ohm.
Old 03-31-2014, 03:42 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
You'll be fine.
Can you tell us how you plan to use them. What's the remainder your system?
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
Old 03-31-2014, 04:03 PM
LTD02's Avatar
Liked: 2490
roger chop. if you happen to remember where the cv test was, please let me know.
without knowing the testing conditions, the "1500 watts" rating could pretty much mean anything. what bandwith, what signal, what crest factor, how long, etc.? maybe it is conservatively rated suggested amp power for folks who might get the urge to send sustained sine waves/bass drops through their gear. who knows...
sounds like the cv5000 would be a good match for the op's new acquisitions!
LTD02 is offline
Old 03-31-2014, 04:10 PM
Bass Enabler
Liked: 4000
I sure like mine! Loud fans though. Gotta do something about that.
Old 03-31-2014, 04:12 PM
ChopShop1's Avatar
Quoted: 284 Post(s)
Liked: 285
I think it will be a great match. With regard to testing...A sine wave, long term at double rated power didn't bust it
Old 03-31-2014, 05:44 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 347
Good luck with your build Rhino. I'm sure you will be thrilled with the results.smile.gif
Swolephile is offline
Old 03-31-2014, 07:02 PM - Thread Starter
Rhino11's Avatar
Thanks guys I am looking to go sealed will see if I can pull off going with 15cf but you can check out my theater build when it goes up. I need to get on that soon. I have a dedicated space of 27x14x9 foe the theater all the walls have insulation and drywall. So I need to make decsion on the sound proofing. I want to build a room within a room, but I can do hat channel and iso clips if need be. Stage and screen wall. There will be about 3 feet or so Behind screen for room for the speakers.
Rhino11 is offline
Old 03-31-2014, 07:14 PM - Thread Starter
Rhino11's Avatar
Swole you box guy is in Huston right are you in that area. For kin over there.
Rhino11 is offline
Old 03-31-2014, 10:49 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 347
Old 03-31-2014, 11:06 PM - Thread Starter
Rhino11's Avatar
Dang you live just 50 minutes away. I got a friend that owns a personal gym and training facility in Austin.
Rhino11 is offline
