My WinISD always errors and won't close in W7 x64. Anyone else have this problem ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-02-2014, 11:38 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
When I try to exit it wont.
What is the most recent version? What version should I be using ?
Mfusick is offline
post #2 of 12 Old 04-02-2014, 11:46 AM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
My old version used to do that, new one 0.7.0.900 on W7/64 is fine.
It wasn't at all obvious how to download it, I just klutzed through and did it by accident, wish I could tell you how.
Noah
noah katz is online now
post #3 of 12 Old 04-02-2014, 12:07 PM
dmadesign's Avatar
It's on their Facebook page.
dmadesign is offline
post #4 of 12 Old 04-02-2014, 12:22 PM
LastButNotLeast's Avatar
Quoted: 1474 Post(s)
Liked: 1069
Same thing happened with me (yesterday, when I started playing with it for the first time). I just rebooted.
I'm not home, so I can't get you the version number, but it can check for updates from within the program.
Make sure you get the "pro" version.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #5 of 12 Old 04-02-2014, 12:29 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I'm running the one right from their website. It's PRO. .50a7
Mfusick is offline
post #6 of 12 Old 04-02-2014, 12:29 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Where would I get a better version ?
Mfusick is offline
post #7 of 12 Old 04-02-2014, 12:37 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
off facebook page
Mfusick likes this.
cookieattk is offline
post #8 of 12 Old 04-02-2014, 01:08 PM
Liked: 1069
post #9 of 12 Old 04-02-2014, 01:35 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Set compatibility mode to Windows 98 / Windows ME
Mfusick likes this.
Mrkazador is offline
post #10 of 12 Old 04-02-2014, 01:54 PM
trancemitr's Avatar
Quoted: 17 Post(s)
I've always had the same issue. I just Ctrl+Alt+Del, go to Task Manager, click on WinISD and End Task. All done. Just save your stuff first.
trancemitr is offline
post #11 of 12 Old 04-02-2014, 02:03 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 335
http://www.linearteam.org/download/winisd-07x.exe
Previous versions were compiled with the now-defunct free version of Borland Delphi. It has since been ported to the open-source Lazarus development system and its code is compatible with Windows UAC (introduced in Vista and continued thereafter).
Edit: They seem to have abandoned their website and forum completely, but the link above can be found on their Facebook page (as previously posted).
andyc56 is offline
post #12 of 12 Old 04-02-2014, 02:20 PM
Bill Fitzmaurice's Avatar
Liked: 4630
W7 if you have W7 or 8. You need to run whatever you have in the correct compatibility mode.
Mfusick likes this.
Bill Fitzmaurice is online now
