Funk Audio TSAD18v1 Passive Radiator Build - AVS Forum | Home Theater Discussions And Reviews
Old 04-06-2014, 04:26 AM - Thread Starter
kawika4's Avatar
I did another build thread on a different forum, but I thought I'd share it here as well.
Recently I revamped my entire home theater set-up. It's not a dedicated room, but it works pretty well. In 2000 or so I built 2 194L ported enclosures for adire audio Tempest 15" subwoofers. They still worked well, but I wanted more bass.
At first I thought that I'd just upgrade my dedicated subwoofer amp. This led me to Funk Audio. I contacted Nathan and he sent me back a graph showing that the gain I would get by using one of his amps would be negligible. I told him I was thinking about the LMS ultra 18 inch sub. He mentioned that he doesn't sell his subs alone, but he will put together a package deal with an amplifier. His drivers are very light due to the neodymium magnet structure and saved me quite a bit due to the fact that I live in Honolulu.
My initial plan was this order two of the TSAD18v1 subs along with a stand alone 2.4kw x 2 into 4 ohms rack amplifier, mount them in my existing 194L enclosures and see how they sound. The results were the boxes seen above. Here are some images of the drivers and amplifier.
AppleMark
kawika4 is offline
Old 04-06-2014, 04:41 AM - Thread Starter
kawika4's Avatar
They sounded great, according to Nathan the 194L enclosure size would create a Qtc of about .6. They sounded great and blended seamlessly with my B&W Nautilus 804s. Usually I turn my subs off for critical listening, but it sounded better with them on. I wasn't sure how large I wanted to make the enclosures 120L sealed will give a .707 Qtc. Nathan sent me a graph showing a 300L ported vs 150L passive radiator system vs 120L sealed. These models are for max sol for one driver.
This next graph is 180L passive vs 120L sealed:
After days of box designs and debates on enclosure placement I decided on one enclosure that would house the two active drivers and all four passive radiators. Each active driver would have it's own enclosure of about 220L. These are the four passives:
kawika4 is offline
Old 04-06-2014, 05:40 AM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
Those look like some very nice drivers!!! Don't be shy with the pics. I'd like to see how the enclosure turns out.
Btw where is your build thread?
tsloms is offline
Old 04-06-2014, 06:03 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
If it were me, I would build two enclosures in order to get the frequency response smoothing that comes from having more than one sub located at various positions.
Martycool007 is offline
Old 04-06-2014, 06:24 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
cool.
good looking amp too.
somebody did something kind of similar quite a while back. long thread, but might be good for ideas. having 2 as marty suggests might give you better results though due to room mode cancelling/non-excitation.
http://www.avsforum.com/t/880571/4-18-5400s-powered-by-2-qsc-rmx-5050s/
http://www.harman.com/EN-US/OurCompany/Innovation/Documents/White%20Papers/multsubs.pdf
Listen. It's All Good.
LTD02 is online now
Old 04-06-2014, 01:47 PM - Thread Starter
kawika4's Avatar
It's on HTS. I'll post more pics soon.
cool.
Thanks for your input. I wish I could have built two separate enclosures, but it just doesn't work for my set-up.
kawika4 is offline
Old 04-06-2014, 02:03 PM - Thread Starter
kawika4's Avatar
The external dimensions will be 23"x23"x69". The top and bottom will be 3/4" thick and the sides will be 1.5" thick. I used baltic birch plywood. I don't have very many clamps, so I decided to screw and glue, remove the screws and fill the holes later prior to finishing. Here's some pics of the process.
AppleMark
AppleMark
Internal bracing:
Almost finished:
kawika4 is offline
Old 04-06-2014, 02:11 PM - Thread Starter
kawika4's Avatar
The neighbor helped me carry it in and it was time to install the drivers.
AppleMark
AppleMark
The passives have two weights on the rear and can be adjusted to three different frequencies:
It's nice having a wife who supports my hobby:D
kawika4 is offline
Old 04-26-2014, 11:20 AM
lees23's Avatar
Quoted: 20 Post(s)
Nice to have a wife that looks like that!
lees23 is offline
