Good plate amp for my Infinity 1260 project ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-07-2014, 04:56 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Hi all,
I am making a high value sub woofer for my office. Sealed Infinity 1260 driver. Need advice on an amp plate. I should note I also have the dual voice coil version as well and could install either into the box. Looking for a good high value match with maximum bang for the buck.
Mfusick is offline
post #2 of 5 Old 04-07-2014, 05:15 PM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Although I am not a fan of plate amps any more, i think what ever is on sale right now with the appropriate wattage would work just fine.
manuetdeo is online now
post #3 of 5 Old 04-07-2014, 06:33 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I'm probably gong to drive one with an iNUKE (small one) but I need a plate for the sealed for my office.
Mfusick is offline
post #4 of 5 Old 04-08-2014, 08:52 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Is there a difference between a Dayton and a BASH amp plate ?
Mfusick is offline
post #5 of 5 Old 04-08-2014, 11:54 AM
garciab's Avatar
Quoted: 144 Post(s)
Liked: 55
Which dayton? The lower wattage models are 'old school' class AB. The BASH are some class of class D (or T or something). The higher wattage Daytons use something a bit different, based on Carver's signal tracking James Bond kinda stuff. smile.gif I'd go BASH or Yung, as in my experience, they are much less prone to ground-loop noise, or mechanical hum from the larger transformers used in class a/b. JMHO.
bg
garciab is offline
