Local music store has busted iNUKE for sale for $80. Worth it? What is expected cost to repair ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-08-2014, 12:16 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I checked online and musicians friend also has busted ones for $100 as well.
I just have no clue what a repair would cost. Is this plug and play boards or something common I could do myself ? What is the worst case scenario in parts?
$80 seems worth a gamble on a $250 item.
Mfusick is offline
post #2 of 7 Old 04-08-2014, 12:46 PM
dtsdig's Avatar
Quoted: 901 Post(s)
Liked: 1015
Availability on new boards will most likely be difficult to impossible. First thing would be trying to get your hands on schematics for them, which will also be difficult, IMO. Depending on the failures, you could get lucky with some straightforward component replacements to very unlucky with torched/destroyed boards. For my money, I would stick with either new with warranty or used with warranty.
dtsdig is offline
post #3 of 7 Old 04-08-2014, 03:39 PM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 44
Maybe if you could talk them down more, and if you are comfortable with your knowledge of electronics.
I've tinkered with the Inuke3000(dsp) and it's pretty bare on the inside. Its a lot easier to access the internals then most amps.
I still probably wouldn't though..
Thatsnasty is offline
post #4 of 7 Old 04-08-2014, 04:22 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
just by asking those questions i can assure u your wasting your time trying to fix these amps.
cookieattk is offline
post #5 of 7 Old 04-08-2014, 05:20 PM
Bob7145's Avatar
Liked: 36
Sometimes Free isn't cheap enough.
Hard to get an estimate on repairing electronics because by the time you troubleshoot the problem you've already done 90% of the work. There is probably a good reason someone hasn't repaired it already. Probably did a once over and decided they didn't want to invest any more time in it. Time is money.
Bob7145 is offline
post #6 of 7 Old 04-08-2014, 05:42 PM
paskal9's Avatar
Liked: 24
repairing a switching amp is a hard (if not impossible) thing to do.
unless you have access to equipment to actually measure the waveforms then don't even try.
even if you do, there's so much going on with so many different design that make it almost impossible.
gone are the days where you could spot the problem by visual inspection and validate the problematic component with a cheap multimeter.
paskal9 is offline
post #7 of 7 Old 04-08-2014, 08:08 PM
blazar's Avatar
Quoted: 736 Post(s)
Liked: 536
it wouldn't be worth the shipping to send to a service center. These are manufactured so cheap (may under $50) these days. Your best bet is to look for a used unit and not pay sales tax and be done with it.
Blazar!
blazar is offline
