Official CNC router Help and Suggestions thread - Page 10 - AVS Forum
 14Likes
post #271 of 283 Old 09-19-2014, 06:58 PM
Gorilla83's Avatar
Quoted: 294 Post(s)
Liked: 436
Originally Posted by baniels View Post
Recent project. First time using a large 45° tool on the CNC. This is a new GR Research OB design.
Very clean looking! What brand mills do you use? And what machine are you running?
Gorilla83 is online now
post #272 of 283 Old 09-19-2014, 07:19 PM
baniels's Avatar
Quoted: 59 Post(s)
Liked: 67
For 95% of project using MDF or BB, I use a 3/8 Onsrud compression. 60-123MW is the part number.
The waveguide was machined with a Whiteside 1508.
The machine is a slightly modified KRMx02. Spindle is an Hitachi M12VC with PreciseBits collets.
baniels is offline
post #273 of 283 Old 12-15-2014, 08:16 AM
awedio's Avatar
Quoted: 34 Post(s)
Can you share more info on your CNC?
How was the Kronos build, modifications, documentation etc?
Any CNC build thread?
awedio is offline
post #274 of 283 Old 12-15-2014, 08:29 AM
baniels's Avatar
Quoted: 59 Post(s)
Liked: 67
I have a build thread, but a lot of changes have been made since the last post.
http://www.cnczone.com/forums/cnc-wo...79134-cnc.html
Dust collection was a large modification. I have a 6" hose running from the cyclone all the way to the shoe. Lots of head scratching to make that happen... Low ceilings made that a challenge.
I swapped out for the cncrouterparts Pro R&P components, Pepperl Fuchs prox sensors with dual long axis homing for self squaring.
SuperPID spindle speed controller.
The spoil board doesn't have the t-tracks anymore; those were utterly useless for sheet stock and just got in the way of my hold down screws.
I might be forgetting something.
Next on the list is a vacuum hold down.
baniels is offline
post #275 of 283 Old 12-15-2014, 08:33 AM
awedio's Avatar
Quoted: 34 Post(s)
Thx for the update, will head over & read the build.
If you had to do this project again, what would you do different?
Use the same kit? different parts?
awedio is offline
post #276 of 283 Old 12-15-2014, 08:36 AM
baniels's Avatar
Quoted: 59 Post(s)
Liked: 67
Without a lot of research on the current market, I'd probably go with the cncrouterparts Pro Nema 34 kit.
Gorilla83 likes this.
baniels is offline
post #277 of 283 Old 12-15-2014, 09:17 AM
Gorilla83's Avatar
Quoted: 294 Post(s)
Liked: 436
This. From the many I've talked to that have built some version of that kit, they have been very happy with it.
BTW the vac hold down is WELL worth the effort. I've got to get my dust collection upgraded to all 6" as well.
post #278 of 283 Old 12-15-2014, 09:33 AM
awedio's Avatar
Quoted: 34 Post(s)
Reading baniels build thread, that Kronos "kit" seems like a lot of work, even though he has access to machine shops etc
awedio is offline
post #279 of 283 Old 12-15-2014, 03:07 PM
awedio's Avatar
Quoted: 34 Post(s)
G83,
If someone was going to send you a file or drawing to cut some BB, what's the best format to send it in?
awedio is offline
post #280 of 283 Old 12-15-2014, 06:58 PM
chrapladm's Avatar
Quoted: 256 Post(s)
Liked: 103
G-code seems like the easiest route. Next would be Sketchup but then would require G83 to convert it from there.
What router bits has anyone used cutting plastic?
Only ask because I am looking at possibly doing a carbon fiber baffle but then have to cut the holes out. Will experiment first but this project is a very slow moving one.
chrapladm is online now
post #281 of 283 Old 12-16-2014, 06:21 AM
Gorilla83's Avatar
Quoted: 294 Post(s)
Liked: 436
G83,
Personally I use the vectric products (vcarve pro) so that format would be ideal. Second best would be sketchup.
post #282 of 283 Unread Today, 12:18 AM
chrapladm's Avatar
Quoted: 256 Post(s)
Liked: 103
G83 how did you figure out the exact dimensions to be cut out for a WG?
I cant remember which one you did in the past. SEOS 12 or something else I dont remember. Although I could be completely wrong and talking about someone else.
post #283 of 283 Unread Today, 06:32 AM
Gorilla83's Avatar
Quoted: 294 Post(s)
Liked: 436
The last SEOS24 cutout I did I was given the dimensions from a "rough" measurement.
