Official CNC router Help and Suggestions thread - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #301 of 324 Old 12-31-2014, 04:48 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1669 Post(s)
Liked: 1491
Thanks Gorilla. As soon as the Vectric site comes back, I'll purchase Vcarve Pro.
Edit: Now own Sketchup Pro and Vcarve Pro.
Gorilla83 likes this.
dgage is online now
post #302 of 324 Old 01-01-2015, 06:25 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Good deal. You will find many uses for vcarve even outside of cabinet making. Watch all of the relevant videos at least once. Have fun and come back with questions - I know you will have many.
Gorilla83 is offline
post #303 of 324 Old 01-04-2015, 12:22 PM
Deep Sea Sound
dgage's Avatar
Liked: 1491
Gorilla, I'm not liking all of the tabs I will be needing to cleanup. Do you have any plans/notes/info on your vacuum hold down system you can share? Thanks. And Congrats again on #2 ...exciting!!!
dgage is online now
post #304 of 324 Old 01-04-2015, 12:36 PM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Here you go:
http://www.talkshopbot.com/forum/showthread.php?t=19556
Start reading, there is a LOT to learn.
Thanks for the congrats, we are excited!
ID:	459105   Click image for larger version
Name:	motors in box.jpg
dgage and baniels like this.
post #305 of 324 Old 01-04-2015, 07:27 PM
Deep Sea Sound
dgage's Avatar
Liked: 1491
Thanks Rilla!
I noticed you mentioned you might be able to get by with 2 motors...do you still think that? Or should I just plan on 3 from the beginning?
EDIT: I actually have a 5'x10' so I think I'd need a minimum of 3 unless you think I need 4...I definitely don't want to redo anything so if 3 is questionable, I'd do 4 from the beginning.
And how often do you have to clean the ShopVac filter?
Anything you'd do differently?
Thanks again for blazing the trail and sharing your knowledge and experience!
dgage is online now
post #306 of 324 Old 01-05-2015, 05:07 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Thanks Rilla!
2 motors would probably more than fine if you are only cutting full size (4x8 and larger) sheet goods. The extra motors help when you need extra volume to account for losses due to air bleeding out of lots of cuts or smaller sized pieces. I did buy another 2 motors (used) to experiment with a smaller enclosure at some point. In your situation with the huge table, and considering how cheap these motors are, I would probably do at least 4 motors. I think for those who have built something similar the rule of thumb was one motor per zone, assuming the zones are split equally. You can always set them up so you can power down half the motors as long as you have a flapper door or something between them to prevent air from being bled out from an unused motor.
I really like these lighthouse motors - I probably have ~75-100 hours on mine so far. Right after powering mine up, I actually removed the filter box from the mix as it proved to be a pretty big restriction. It was still fine the way it was, I just figured after I got all of the junk out of the lines I could pretty much just use the bleeder board as the filter.
First - Figure out what you plan on cutting and create your grid/zones as needed. You can size the motors required based on this, but these things are only ~120 per motor so as long as you have the electrical in place to support them, go big. FYI - The 4 240v motors I have are on a 30A 240V line and breaker.
Youtube vid of mine in action during testing - https://www.youtube.com/watch?v=u1X9...ature=youtu.be
post #307 of 324 Old 01-05-2015, 12:27 PM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
A couple of things to note for those interested in building a DIY VAC setup:
1) If you decide to use the lighthouse motors, be absolutely SURE to use the gaskets. They do not include them by default and prevent the motor from being crushed from over tightening. I lost my first motor by not using these within seconds. Since I added the gaskets (they should include on the orders!!) there are no issues.
Motor source that I used: http://www.centralvacuummotor.com/shopbot.htm
2) The motors are NOT quiet so if you mind the noise you might want to run them in an adjacent room. Most that have tried hard to suppress the noise in some kind of box seem to do so at the expense of rises in temperature. Mine run quite cool - I have a temp sensor on the primary motor housing and with most runs under 45 minutes to an hour I typically don't see anything north of 130 degrees, even in the summer.
3) For those limited to single phase power but want a plug and play solution you can buy something similar to what I have built here:
http://www.blackboxvac.com/
They seem to be quite reasonable especially compared to the three phase alternatives which are 5-10k typically.
post #308 of 324 Old 01-05-2015, 02:58 PM
Deep Sea Sound
dgage's Avatar
Liked: 1491
I was doing searching and there doesn't seem to be a clear set of plans for the "black box" system you used. So I was indeed considering the Hurricane. I'll do some more research and see if I can pull together the final details to determine whether I have the time to do this DIY or if I should bite the bullet and buy the Hurricane.
Gary Campbell says the Hurricane is an improved version of the one you built...have you read anywhere about a comparison to determine the amount of improvement? Thanks.
David
dgage is online now
post #309 of 324 Old 01-05-2015, 05:15 PM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
I had read the same regarding some enhancements made to the hurricane setup, but not sure what the specifics are. As for the black box design, there aren't a set of plans or anything, but Gary had posted some pictures and general guidelines for overall design. I should still have my vectric files somewhere though, let me take a look so you can get an idea.
If I recall I think I spent around 800 dollars on my setup including motors, wood, and electrical stuff so a real bargain for what it is.
post #310 of 324 Old 01-05-2015, 06:25 PM
Deep Sea Sound
dgage's Avatar
Liked: 1491
I could probably figure it out...read quite a bit today. But it's the little things like the 1/4" bypass hole so the motors don't burn up or the gaskets that you learned about the hard way. I think I saw one wiring diagram but there wasn't complete agreement on how to wire the black box (one suggested a fuse). But $800 and some time compared to $2000 is definitely worth thinking about, especially when I can handle wiring and plumbing fairly easily.
If you have any additional materials though, it would be greatly appreciated, especially the wiring diagram you used.
dgage is online now
post #311 of 324 Old 01-06-2015, 05:00 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
For the bypass/venting - I installed a 2" ball valve that allowed me to open/close to add more air to the system as it needed it, and I can close it when there the system is no longer sealed and I'm cutting pieces much smaller than the zone. Installing a vacuum gauge is a must to see where you stand with suction along with a temperature gauge of some sort to see how hot the motors are running. It's pretty basic and much simpler once you've used it for a few days.
As for the wiring it's very easy. Each motor only has 2 hot leads (power leads) and a ground. There is no neutral wire required. You can either use a breaker or a fuse for each motor, doesn't really matter as long as you're protected. I liked using the breaker panel because it allowed me to use one 10 gauge wire in and it served as a distribution block for the different motors. You could just as easily wire the motors in parallel. I build my own cord with a 10-2 flex wire with ground and matching plug. Very easy to do that part.
dgage likes this.
post #312 of 324 Old 02-06-2015, 08:38 AM
awedio's Avatar
Quoted: 79 Post(s)
Liked: 26
Not really a CNC router, but similar
Having a 'lil fun making a "jig" for the bolt holes of my FaitalPRO 18FH500
awedio is offline
post #313 of 324 Old 02-06-2015, 06:33 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
Pretty awesome either way. The tool change out was pretty awesome also. How is this being held in place?
It looked like there was a bit of movement on the second to last hole. Just curious.
chrapladm is offline
post #314 of 324 Old 02-06-2015, 08:55 PM
awedio's Avatar
Quoted: 79 Post(s)
Liked: 26
Always love the tool changer, btw, it holds 24 tools.
Yes, there is a lot of movement. My feed rate was too fast/material is poorly held
awedio is offline
post #315 of 324 Old 02-06-2015, 10:32 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
You guys and your fancy tools.
post #316 of 324 Old 03-15-2015, 06:13 PM
Liked: 0
this is a fantastic thread.. thanks for the insight.. i tried to quote chrapladm but don't have a sufficient post count.
did you end up buying your own router? where in adelaide did you find the cnc guy?
am happy to PM if you want, but it wont let me send you on!
mrcleaner is offline
post #317 of 324 Old 03-15-2015, 08:25 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
Mrcleaner if your in ADL then there are quite a few CNC companies. I just keep buying tools lately to make building easier. Cant afford the cnc option yet.
post #318 of 324 Old 07-08-2015, 06:23 AM
JackNC's Avatar
Quoted: 141 Post(s)
Liked: 39
I would appreciate some advice on nominal dimensioning for Dadoes and dogbone fillets
My workflow is to design in Sketchup and then import .skp files into VcarvePro to debug the toolpath and make sure the parts are "clean". Then I go to the CNC shop and do this over again with their help because I don't yet have a VcarvePro license and I don't know enough about toolpathing. Consequently, I want to get all that detail into the Sketchup drawing rather than doing that work in Vcarve using their gadgets. That might change if/when I invest in a Vcarve license.
I can draw a dogbone by drawing two tool-diameter circles at/near the end corners of the stopped Dado. It looks to me the centers of those circles should be inset 1/2 the radius of the tool from the edges. Is that right? The dogbone won't be visible. I just don't want to have to fight to get the pieces to fit together. I tried squaring up the edge of the slot by hand on my proto and that was an incredible pain compounded by the slot itself being too tight.
How tight should the slot be? I quick calculation says that 1/64" oversize should more than cover all the tolerances. Is that tight enough? I just want to locate the part precisely and hold it in place for gluing. I'm not concerned about strength of the joint.
Thanks for your help
Jack
JackNC is offline
post #319 of 324 Old 07-08-2015, 08:08 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Jack - You're on the right track. Tradtionally, filets are done 1/2 the radius of the tool in each corner where slotting/fitting is done. I usually add in some extra space .01 or .02 as it usually means the difference between sanding or no sanding. Once you get vcarve licensing you can use the "allowance" toolpath feature to easily add in the typical .01 to .02 in the slots. BTW the new vcarve 8.0 version is phenomenal!! If you're planning to do more projects in the future it's definitely worth the investment from my perspective. I'm planning to do some 'wall art' next week.
post #320 of 324 Old 07-08-2015, 08:46 AM
JackNC's Avatar
Quoted: 141 Post(s)
Liked: 39
Please tell me if I have it right. The top left is my first attempt. Its pretty ugly so I thought I should ask. The bottom right is my interpretation of what you said, using a 1/4"mill to cut a nominally half inch slot, with an 1/8" mill cutting the dogbones. I like that method, its less work and gives me a precise stop.
JackNC is offline
post #321 of 324 Old 07-08-2015, 09:42 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
That looks pretty good. If you use the filet tool and preview in Vcarve you will see it looks similar to that.
post #322 of 324 Old 09-08-2015, 12:40 PM
Deep Sea Sound
dgage's Avatar
Liked: 1491
I am about to place an order for a beefed up CNC Router Parts 5'x10' CNC kit with 2.2kW spindle as well as an Oneida Super Dust Gorilla 5HP dust collector. I'm looking for comments about vac hold down systems, basically whether to buy the Black Box vacs or build my own.
I've seen comments where the designer of the Black Box Vac seemed to say his 4 vac Hurricane might be equivalent to 6 Lighthouse 7123 motors using the DIY kit. He's made comments about better performance but I've never seen any reasoning for this. He also suggested that 6 vacs should be good for a 5'x10' table. Since I'll primarily be using 5'x5' sheet goods, I was thinking of going with two separate units, likely with 3 Lighthouse vacs each. This could be the Black Box Cyclone vac at $1700 each or build my own kit for less than that for both 3-vac units. And I've researched the DIY approach and pretty sure I could build it pretty easy but there are some gotchas that a commercial product may have worked out such as how to keep motors relatively cool while maximizing performance. Any thoughts? Thanks.
EDIT: Just want to point out I'm on single phase power.
David
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is online now
post #323 of 324 Old 09-08-2015, 06:28 PM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
David
Hey David,
If you've got the time to invest in building and experimenting with your own LH setup, by all means go for it. As it stands the Black Box setup for 1700 seems well worth the money though considering the time you will spend building and tweaking, etc. If I were running a "business" from my setup like you are that's probably the route I'd go. If you're working with full sized sheets (5x5 or 4x8 whatever) I'd imagine 4 motors will be plenty even on the 5x10 table.
Looking forward to hearing your feedback from the CNCRP setup! I'd imagine I may upgrade mine to something like that in the future when I've got time to build the kit and a matching table.
post #324 of 324 Old 05-10-2016, 06:33 PM
awedio's Avatar
Quoted: 79 Post(s)
Liked: 26
Any one have experience (or used) this software? http://www.mozaiksoftware.com/products/mozaik-cnc
awedio is offline
