My "Daniel" surrounds, with a twist! (Seos 12, DNA350, NS6x2) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-12-2014, 12:14 PM - Thread Starter
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Originally I bought all the parts to build a "Big Mal" center channel, but after several weeks of running my cheap thrills with a fantom center I decided to scrap the project. I was about to pull the trigger on a pair of V10s, but I vaguely remembered seeing a build thread for a seos with two NS6 woofers.
Here's the thread I found:
http://www.diysoundgroup.com/forum/index.php?topic=101.0
All I needed to complete this project was:
Seos 12
DNA Driver
Parts for one crossover (the BigMal uses the exact same crossover, but with an addition Cap added for the outside woofers)
A little bit of wood (I had all the scraps)
Minus the price of the big mal parts I already had, and the fact I had all the wood/stain/paint, I ended up spending less than $100 dollars on this project.
I have a few construction pictures, but there's nothing interesting to be seen, or that hasn't been posted in 1000 other build threads.
The Dans with the Cheap Thrills, all matchy matchy!
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
post #2 of 15 Old 04-12-2014, 12:18 PM - Thread Starter
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Here's something I did a little different, and that I'm proud of.. I used TV wall mounts instead of speaker wall mounts. Amazing, I know!!!
A pic showing how much tilt I can get out of these (I added a small spacer at the top of a bit of flexibility)
Bombelman likes this.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
Stumbo is offline
post #3 of 15 Old 04-12-2014, 12:22 PM - Thread Starter
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Here are the wall mounts I went with:
http://www.monoprice.com/mobile/Product/Details/8100?mainCategoryId=108&categoryId=10828&subCategoryId=1082802
Benefits:
Cheap ($16)
Tons of adjustability
Easy to install
Easy to remove speaker for service (backing plate detaches from arm)
Cheap
Wire management
Good weight capacity (44lbs, my speakers are 25lbs)
Cheap
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
Stumbo is offline
post #4 of 15 Old 04-12-2014, 12:28 PM - Thread Starter
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
As for listening impressions, these little speakers sound great! With boundary gain they have plenty of output down to 80hz in their .9cuft box.
I drove them with my IPR1600 and a 80hz filter to 118db @1m before they started to stink a little, the woofers were definitely jumping around at this point!
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
Stumbo is offline
post #5 of 15 Old 04-12-2014, 01:13 PM
d_c
d_c's Avatar
Quoted: 817 Post(s)
Liked: 868
d_c is online now
post #6 of 15 Old 04-12-2014, 02:05 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Is the mount screwed into the wood? I would feel more comfortable if it was mounted using bolts and a nut/washer
Mrkazador is offline
post #7 of 15 Old 04-12-2014, 04:55 PM - Thread Starter
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Yeah just screwed in. I agree, lock nuts and large washers would be ideal, however the speakers are about 25lbs, so 7.5lbs of lateral pull per screw shouldn't ever go anywhere, I did pre drill the holes and coat the screws in PL first as well.... Also this is pine ply, not MDF.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
Stumbo is offline
post #8 of 15 Old 04-12-2014, 04:59 PM
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1505
In plywood that screw could hold 50 lbs no problem without anything added.
Stumbo likes this.
chalugadp is offline
post #9 of 15 Old 04-12-2014, 05:05 PM - Thread Starter
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Originally Posted by d_c View Post
They look great - good idea on the tv mounts too
I couldn't be happier, the infinite adjustability should let me really dial in the waveguides aim to get a great response across my entire spectrum of listening positions..... Which is one sofa biggrin.gif
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
Stumbo is offline
post #10 of 15 Old 04-12-2014, 05:43 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Thx for the reminder. I have basically the same style articulating mounts and forgot about them. When I finish my surrounds I'll put them to use. Glad you got positive results smile.gif
gpmbc is offline
post #11 of 15 Old 04-13-2014, 09:24 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
Stumbo-
How do you like the Daniels?
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is offline
post #12 of 15 Old 04-13-2014, 10:30 AM - Thread Starter
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Originally Posted by pgwalsh View Post
Stumbo-
I like them! The sound isn't drastically different from my cheap thrills, since they share the same WG/CD.
I think at lower volumes they might actually sound better than my Cheap Thrills, the midrange and vocals are phenomenal, and the woofers are so close to the WG it gives a point-source presentation.
Its a pity they're only going to be called upon for surround duty, they are capable of much more!
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
Stumbo is offline
post #13 of 15 Old 04-13-2014, 11:58 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
I just finished my crossover for one and was going to test them out. Erich sent me baffles months ago, but things came up and I didn't have time. I may cut and clue a box tonight and give them a go this week. I have 14 NS6 drivers and was going to use them for surrounds with my TD12M/SEOS-12's, but we'll see.
Bill said they were articulate, and I gather from your comments you agree.
pgwalsh is offline
post #14 of 15 Old 04-13-2014, 12:27 PM - Thread Starter
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
I agree! I wish I would have bought a dozen of the NS6s when I had a chance, I keep thinking of situations where these speakers would be a good fit.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
Stumbo is offline
post #15 of 15 Old 04-13-2014, 02:19 PM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 284
You might be able to get some more. wink.gif http://www.diysoundgroup.com/limitedsupply/lo-aurasound.html
pgwalsh is offline
