Curved SEOs Tempest Build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #91 of 107 Old 04-30-2014, 03:09 PM - Thread Starter
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
Originally Posted by JWagstaff View Post
wow those speakers are so nice. What do you do to make the pieces of laminate attach to each other so perfectly? Is it like a mitre joint or do they overlap the sides but they glue together and you can't see the crack?
They overlap. In person if you stand a foot or two away (depending on your eyes) you can see the line. The permanent marker blends them in so well that it doesn't bother me and from more then a couple feet you can't see it at all. If these were regular rectangle boxes I would have mitered them. Trying to miter the joints on these things would have kept me from sleeping.
realtight is offline
post #92 of 107 Old 04-30-2014, 05:38 PM
maxcooper's Avatar
Quoted: 13 Post(s)
Beautiful work. Those look really nice, in shape and finish.
-Max
maxcooper is offline
post #93 of 107 Old 05-01-2014, 05:55 AM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
Anyone that has even done "Simple" sub boxes knows how much blood, sweat, tears and cussing have gone into these. Very innovative design and execution and should look and sound amazing.
btinindy is offline
post #94 of 107 Old 05-16-2014, 12:32 PM - Thread Starter
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
Here is my final update for this project as I finished this project yesterday! I was out of town last weekend so between work and "husband" projects, it was a scramble to the end. I think they turned out nice but had to add a couple finishing elements to hide my screw ups.
Crossovers going in as well as denim stuffing, ports, feet and terminals:
I added side stripes because for some reason or another I absolutely destroyed the last edge I had to trim and it looked terrible. Go figure, I get worse as I finish rolleyes.gif
Here's a close up, the final two images show the new trim I used around the woofer holes because I'm extremely picky like that and hate the way the stock Eminence gaskets look.
Overall I'm very pleased with how they ended up. I listened to them last night for a couple hours and enjoy the clarity and efficiency. My current theater speakers are JBL synthesis which are only 92-89db's and aren't the most revealing speakers so these will be a nice upgrade. biggrin.gif
post #95 of 107 Old 05-16-2014, 02:03 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Wow did those ever turn out awesome! That looks like a lot of stuffing, it's not blocking the ports at all is it?
jbrown15 is offline
post #96 of 107 Old 05-16-2014, 02:08 PM - Thread Starter
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
Nope, the denim lining is around 1.5” thick and I only lined the back curved walls along with the top and bottom. Ports closer to the front so they should be good. smile.gif
I think the picture makes it look like there is more stuffed in there then there really is.
post #97 of 107 Old 05-16-2014, 02:11 PM
jbrown15's Avatar
Liked: 1993
Without a doubt that is the nicest a Tempest build I have every seen! Excellent work, you should be very proud!
jbrown15 is offline
post #98 of 107 Old 05-16-2014, 02:13 PM - Thread Starter
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
Thank you JB, yes I am very happy with the work put into these, I need a little break before starting my next build! I'm thinking the SEOs 88 Special for a center along with the 10" coaxials for surrounds.
post #99 of 107 Old 06-18-2014, 03:54 AM
saginawjuggalo's Avatar
Quoted: 47 Post(s)
Liked: 51
Awesome job.. They look amazing! The only thing that could make them even better looking (just my taste) is a Cherry/Black combo.
Did you remove the front woofer gasket? I'm not a fan of the way the stock gasket looks either. If you did indeed removed it, how hard was it to take it off? A flat-head screwdriver and Goo Gone?
Now that you had the speakers up and running for a month, could you give a more detailed impression of the Tempests? I'm about to pull the trigger on a DIY Tempest set, but need a little pushing.
JVC DLA-RS40 w/003 lamp,DIY False-wall 125" acoustically transparent screen,Darbee Darblet,Sanyo PLV-Z2000 (gaming),7.1 DIYSoundGroup 1099 x3 LCR & Slanted Volt 6 rears x4,Onkyo TX-NR818,Emotiva LPA-1,Behringer EP4000 (x2),Sealed Stereo Integrity HT18"s (x8),Balanced MiniDSP,Cross·Spectrum UMIK-1,DIY Acoustic Treatments,PS3,Sony BDP-S590,Seiki SR4KP1 Region Free BDP,Toshiba HD-A1,Roku,Outdoor Antenna,APC H15 power conditioner,Harmony Smart Control,Rebuilding*HTPC,Leather Theater seating etc.
saginawjuggalo is offline
post #100 of 107 Old 06-18-2014, 06:26 AM
PassingInterest's Avatar
Quoted: 177 Post(s)
Liked: 486
Very nice!
PassingInterest is offline
post #101 of 107 Old 06-18-2014, 07:27 AM
AudioJosh's Avatar
Quoted: 248 Post(s)
Liked: 227
Wow, just stumbled upon this thread. Those look amazing! They remind me of the JBL everest styling.
One minor suggestion, if it is helpful. Early diffraction is the worst type of diffraction for imaging and spatial cues. The upper and lower fingernail where the curved front overhangs the front baffle could cause such diffraction. A very easy fix that would be very aesthetically congruent would be to obtain some high density wool felt*, maybe a 1/4" thick, dye it black if you can't source black already, apply it to this fingernail and trim to profile. It should be visually imperceptible but sonically helpful.
* let me know if you have a hard time understanding the kind I refer to. I sourced mine a long while back and can't recall the exact details, but it looks like a very dense matt not hairy in any way.
JoshK on most other audio forums
Quantity only when quality is ensured.
AudioJosh is offline
post #102 of 107 Old 06-18-2014, 08:01 AM - Thread Starter
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
I will definitely give a subjective review soon along with some comparisons to other speakers I've built and some commercial offering that to are stand outs in performance and price.
Cherry red does sound like a great option, maybe if I get bored after having these I'll dye them
post #103 of 107 Old 06-18-2014, 08:03 AM - Thread Starter
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
Thanks Josh do you have a link to help out?
post #104 of 107 Old 06-18-2014, 08:14 AM
AudioJosh's Avatar
Quoted: 248 Post(s)
Liked: 227
I am quoting ThomasW from HTguide
I use a local supplier I found in the yellow pages. Other's with no local supplier use www.mcmastercarr.com Scroll down to the Raw Material/Springs section and click on the Felt link.
It doesn't need to be very thick 1/4" -3/8" is fine
It is often used to make gaskets. I bought two rolls of various thicknesses (I think 1/4 and 3/8) some while back to use for projects. You need pieces to be moderately long but not very wide.
post #105 of 107 Old 06-18-2014, 11:55 AM - Thread Starter
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
Perfect, thanks again Josh. I'll be ordering some of this soon and adding it when I can. I never would have thought of this!
post #106 of 107 Old 06-18-2014, 11:57 AM
AudioJosh's Avatar
Quoted: 248 Post(s)
Liked: 227
Glad to help. It should, at least in theory, be quite beneficial and its not too expensive to try.
post #107 of 107 Old 06-18-2014, 11:58 AM - Thread Starter
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
I hate the stock gaskets, makes them look cheap and making a new ring out of mdf was extremely easy and effective upgrade in my opinion
All you have to do to get them off is gently pry them off from the outside edge. Most of the glue is on the inside edge and with a little muscle, it comes right off. I used a sharpy the clean up the edges from the gasket and very little amount of rubber cement to glue the new mdf rings on.
