Crossover for the Za5.5tt MMTMM - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 04-14-2014, 08:46 PM - Thread Starter
AVI20's Avatar
I haven't built any crossovers before but am really good at soldering, I built the Zaph Audio 5.5tt MMTMM and want to build the crossovers. I have the schematic for them is there anything special I need to know? And should I buy all the parts for it from partsexpress?
AVI20 is offline
post #2 of 19 Old 04-15-2014, 06:19 AM - Thread Starter
AVI20's Avatar
AVI20 is offline
post #3 of 19 Old 04-15-2014, 01:44 PM
Bud Heavy's Avatar
Quoted: 27 Post(s)
Liked: 24
Given Madisound sells a kit with the assembled crossover, could you buy the parts from Madisound?
Epson 8500UB, 130" Seymour XD Screen
Denon X4000, Behringer 6000dsp, 3000dsp, CrownX1000
DIYSG Tempest LCR, V-10 Surrounds, V-6 Rears, Ed Frias AR.com Wides
Dayton UM18 x 2, Infinity 1262 x 4 (+4 WorkInProgress), NHT Dual 10's
Bud Heavy is offline
post #4 of 19 Old 04-15-2014, 02:22 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
If you're a newbie like I am, how does one figure out what wattage resistors you need? or air core vs solid core inductors? What AWG should the inductors be?
Mrkazador is offline
post #5 of 19 Old 04-15-2014, 02:46 PM
Bud Heavy's Avatar
Quoted: 27 Post(s)
Liked: 24
I have never designed my own crossover. There are books or you can ask google for help. Here is just one of many links:
http://www.diyaudio.com/forums/multi-way/189847-introduction-designing-crossovers-without-measurement.html
post #6 of 19 Old 04-15-2014, 04:06 PM
WVSyd's Avatar
Liked: 42
Simple math transfer functions in passive crossovers were how crossovers used to be developed.
And generic crossovers are still sold using that old technique.
However with computer modeling circuits can be developed that take into consideration the actual manner in which the crossover and reactive load interact.
They have different performance characteristics.
( including saturation and hysteresis )
http://www.electrical4u.com/what-is-inductor-types-of-inductors/
http://info.ee.surrey.ac.uk/Workshop/advice/coils/air_coils.html
http://www.die.ing.unibo.it/pers/grandi/papers/ciep00.pdf
"Beware of Salesmen: They are the modern Svengali, immune to Science and Reality"
WVSyd is offline
post #7 of 19 Old 04-15-2014, 04:49 PM
WVSyd's Avatar
Liked: 42
RE:
http://www.zaphaudio.com/ZA5/ZA5.5tt-crossover.gif
Note: the comment This resistance is part of the inductor
This is the DCR of the inductor.
WVSyd is offline
post #8 of 19 Old 04-16-2014, 08:12 AM - Thread Starter
AVI20's Avatar
I wouldn't design them, I have the schematic of all the parts I need and where they go, I would just like to put them together and not buy the pre made ones they sell.
AVI20 is offline
post #9 of 19 Old 04-16-2014, 08:25 AM
WVSyd's Avatar
Liked: 42
Madisound was founded in 72 and started advertising in AA and SB mags.
In my experience they were very good at modeling.
Speculation:
The inductors were chosen and their specific DCR was included in the model. *
The choice of an air core in the HF section and inductors with a metal core in the low pass section was intentional - based upon the characteristics of each ( w cost in mind )
* Make sure this is part of inductor selection
WVSyd is offline
post #10 of 19 Old 04-16-2014, 12:11 PM
Bud Heavy's Avatar
Quoted: 27 Post(s)
Liked: 24
I would either go with Parts Express or Madisound. I have ordered a lot of stuff from Madisound and they are great to work with if you give them a call.
post #11 of 19 Old 04-16-2014, 01:08 PM
djarchow's Avatar
Liked: 27
You can get your parts from anywhere but as as others have mentioned, you need to be sure that you are getting close on the inductor DCR values to what Zaph used in his XO design. I would bet that when John chose values for the inductors, he used Madisound parts to do so. Also you should check to see if any resistors are doubled up to make the final value while still having the proper power handling.
djarchow is offline
post #12 of 19 Old 04-16-2014, 02:03 PM - Thread Starter
AVI20's Avatar
Awesome. I'll give them a call and see what they can do. Thank you all for your help
AVI20 is offline
post #13 of 19 Old 04-17-2014, 07:22 AM - Thread Starter
AVI20's Avatar
So I called them and they can ship the crossovers unassembled. And they can ship the circuit board with or without it, which is a 20 dollar difference, should I just get all the stuff for them and build them on something else or use their circuit board?
AVI20 is offline
post #14 of 19 Old 04-17-2014, 07:34 AM
WVSyd's Avatar
Liked: 42
It's your call...
Getting the board means you don't have to fabricate ( cut, drill hole, wire up etc ).
In your situation: Eliminating this gets you listening quicker biggrin.gif
WVSyd is offline
post #15 of 19 Old 04-17-2014, 07:55 AM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
If you have no idea what you're doing, you may be better off using their circuit board.
Face2 is offline
post #16 of 19 Old 04-17-2014, 12:38 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I say skip the crossover board so you learn how to read a schematic.
post #17 of 19 Old 04-17-2014, 05:01 PM - Thread Starter
AVI20's Avatar
I love to fabricate stuff so that would be a plus, and I think I have a pretty good idea about what I'm doing, and what did you mean by skip the crossover? You mean their circuit board?
AVI20 is offline
post #18 of 19 Old 04-17-2014, 05:04 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I edited my post, I meant to say crossover board (their circuit board).
post #19 of 19 Old 04-17-2014, 05:28 PM - Thread Starter
AVI20's Avatar
Ok cool. And you guys would recommend buying the parts and building it rather than just buying the crossovers put together and ready to go?
AVI20 is offline
