Need help with DIY - Sealed Dual opposed 12" sub with balanced inputs, 220v - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-18-2014, 02:52 PM - Thread Starter
intgenx's Avatar
Folks,
I have 5 channels of Neumann KH310 (3 way active, with total 290W) with MOTU Ultralite MK3 as my "Sound Card". Source is a PC playing FLAC files from a hard-drive.
I'm looking to build a Sealed Dual opposed 12" sub with balanced inputs (XLR) and 220v power source (although a broad range 110-220v amp would also be great).
I'd rather not go to 15" or 18" drivers (for which I see many existing designs) - I think they will be too heavy for me to carry without additional freight charges.
If there are any existing designs pl. let me know - as they didn't come-up in my search...
I'm now in the US and so I can order a couple of drives and amps to take with me to India and build the cabinets there...
Pl. recommend the best 12" drivers and amps with balanced inputs...
What is the minimum / optimum cabinet volume required and the suggested dimensions...
My budget is $2000 including cabinets... and my main goal is low distortion down to 20Hz. The SPL is not as big a factor as good, clean distortion free high fidelity to the original signal...
Thanks folks for all your responses and help...
intgenx is offline
post #2 of 6 Old 04-18-2014, 03:31 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
Maybe check out the custom kits from Rythmik audio. Seems like they would be just what your looking for. Scroll to the bottom to see the dual opposed option.
http://rythmikaudio.com/DS1200ci.htm
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #3 of 6 Old 04-18-2014, 04:01 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
http://creativesound.ca/details.php?model=Duet%20SDX12A
Not dual opposed but the amp does have switchable voltage.
This will also do 230.
http://www.parts-express.com/dayton-audio-spa1000-1000w-subwoofer-plate-amplifier--300-809
Crown XLS drive core amps can also do 220.
Manic1! is offline
post #4 of 6 Old 04-18-2014, 04:05 PM
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1547
BassThatHz is offline
post #5 of 6 Old 04-18-2014, 04:48 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Originally Posted by BassThatHz View Post
In that case, what you'd want is this package:
http://creativesound.ca/details.php?model=SDX12%20Promo
He needs two.
I was thinking 2 kits with 2 plate amps.
Manic1! is offline
post #6 of 6 Old 04-18-2014, 08:35 PM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
That looks like a darn good 12" driver.
bear123 is offline
