Need new speaker design ideas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-24-2014, 06:33 PM - Thread Starter
blazar's Avatar
Quoted: 738 Post(s)
Liked: 537
After feeling the raw power of my dayton subwoofer build, I am interested in rethinking my main speakers and considering a DIY approach...
I like the efficiency and sound of midrange/hi horns, coupled with a 15" sub driver.
Any links to some ideas or specific kits that are highly regarded would be appreciated!
Blazar!
blazar is offline
post #2 of 8 Old 04-25-2014, 09:16 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
How big room? How loud you want?
Any size of the speaker requirements ?
Off the top of my head a FUSION 12 seems like a great choice.
Mfusick is offline
post #3 of 8 Old 04-25-2014, 09:41 AM - Thread Starter
blazar's Avatar
Quoted: 738 Post(s)
Liked: 537
5000 cu ft room, got a lot of room for the main speakers
Blazar!
blazar is offline
post #4 of 8 Old 04-25-2014, 10:42 AM
BassThatHz's Avatar
Quoted: 2350 Post(s)
Liked: 2114
I'd have no hesitation recommending the Fusion 15.
http://www.diysoundgroup.com/waveguide-speaker-kits/fusion15-kit.html
My 15 blends well with my UM's at anywhere from 200 to 70hz.
Mfusick likes this.
BassThatHz is offline
post #5 of 8 Old 04-25-2014, 11:06 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Sure take my reccomendation and go one size bigger biggrin.gif This seems like something you would do tongue.gif
Mfusick is offline
post #6 of 8 Old 04-25-2014, 11:09 AM
ejh2854's Avatar
Quoted: 26 Post(s)
Liked: 34
There is no Honor in Mediocrity
ejh2854 is offline
post #7 of 8 Old 04-25-2014, 11:16 AM - Thread Starter
blazar's Avatar
Quoted: 738 Post(s)
Liked: 537
The fusion does look like a decent line, cheap enough to try. Ideas about the shaping of the box?
Any other good horn kits to consider?
Any spherical horn kits?
Blazar!
blazar is offline
post #8 of 8 Old 04-25-2014, 12:14 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Buy the flat pack and just glue it together, or follow the standard box build (dimensions and cut sheet) for that speaker. Easiest and the result is proven certain from previous others.
Mfusick is offline
