Something to beat La Scalas? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-25-2014, 08:23 PM - Thread Starter
homeskizzle's Avatar
Liked: 31
Currently, I have 3 Klipsch La Scalas for my front 3 in my HT. They do sound great and have a solid presence. I'm kinda curious to see if I can get more punch out of them. The Book of Eli scene (from the Blu Ray Demo download that I got from this forum) sounds good and the gun shots have a good punch, but I am wondering if there is more. I have a single sealed Dayton 18 HO and a full sized Marty for the bass, so (for now) I feel covered in the bass category.
I'm currently using an HK 3600 to power my 5.1, but do have a Sherbourn 7X150 sitting in the box behind me. Maybe the punch I am looking for could be delivered by an outboard amp. Just throwing that out there to muddy the waters. However, I am not sure I have enough electrical outlets to add the Sherbourn to the equation.
The reason why I'm wondering is that I heard a pair of JBL JRX225s at a local, small concert at a brewery (Quest Brewing) here in Gvegas (Greenville, SC). Those speakers had great mid bass and punch...even being 20ish feet away and outdoors...as opposed to being 7 feet away and indoors for my current setup. Those particular JBLs run for about $420 a piece. Would those JBLs beat the La Scalas for HT duty? Any experience with those or similar PA speakers in a HT environment would be helpful.
Part of the reason I am posting in the DIY section is that I've considered building Tempests or the redesigned Sentinels (whenever they are released) for my front 3. Ideally, I'm looking to keep it to $500 a piece for the front 3. Any advice or thoughts are appreciated and welcomed.
Scott
Klipsch La Scalas with original AA crossovers - L/R
Klipsch La Scala split with AL-3 crossover - Center
Crummy surrounds I need to replace
Dayton sealed 18" and full sized Marty - EP 4000 bridged
Epson 3500 and Homegear 120" screen
homeskizzle is offline
post #2 of 15 Old 04-25-2014, 09:40 PM
LTD02's Avatar
Quoted: 2455 Post(s)
Liked: 2778
might want to look into cancellation reflections. that can destroy midbass.
http://peavey.com/support/technotes/soundsystems/new%20boundary%20cancellation.pdf
koturban likes this.
Listen. It's All Good.
LTD02 is offline
post #3 of 15 Old 04-26-2014, 03:02 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1139
HS, the trouble with your question is that it's vague and subjective. Even though I've owned a couple of pair of LS (and KH and Heresy) words like punch will have a certain reference to you, but they might not mean the same to me.*
Lets put it this way; after having several heritage speakers, I don't any more. What was essentially the smallest component of my DIY PA system, and what has become my template for a 3 way home speaker bettered them, and easily. But it was active JBL/Beyma and I'm not aware of something similar out there commercially or easily DIY. I get what people like about the Klipsch H range, but they have too many faults for my taste. The LS also has a poor LF roll off; mostly gone by 100Hz and weak by 125Hz due to the too short horn.
Best suggestion: if looking at a commercial product like the JBLs, go into a store, express your interest, and see if you can buy and return or hire for a modest fee (usually possible mid week) and see if it can be deducted if you decide to keep them. If it's DIY, look around and see who has them, and ask if you can come around to hear. The offer of BBQ fixings and some drinks usually goes a long way toward that. Try to take a pair of the LS to compare, make a day of it and have some fun.
When considering cost, did you factor in potential sales value for the LS? If not add that in as it might allow something even better.
* Years ago, after a long online correspondence with a guy full of lots of vague description I went to hear a pair of small speakers with huge midbass and slam. Turns out the guy was from HK, lived in a small apartment, listened close and quite softly and listened to music that most would describe here as having no bass, eg some operas in Chinese for example. When I played selections of dinosaur rock through them, they were awful (to my taste) and thin and gutless sounding even at low level. Lovely guy and worthwhile experience, because they couple of hours listening and talking to him made clear the differences in language in description that hours online had not. I'm sure if you and I met, the difference would not be so great, but it may also be a set up issue that some time with REW/EQ may help you diagnose/correct and the experience of actually listening to other potential purchases is invaluable.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #4 of 15 Old 04-26-2014, 04:43 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 180
Ok, for starters, the La Scala is a great speaker, but like A9X-308 stated, they don't really have much extension below 100hz, which can make them seem weak and anemic if you don't have good subs or if your subs aren't setup, optimally. I would start by selling them. You can probably get close to, or above $1,000 for them, depending on their condition, then build yourself a trio of Seos speakers. The Seos designs have all of the good qualities of the La Scala and other Klipsch Heritage speakers, but, they also lack the pitfalls of those speakers. It's like they do everything the La Scala can do, and more!
As far as which Seos speaker to go with, that depends on whether or not you are comfortable building your own enclosures and assembling your own crossover. I like the Tempest with the upgraded AE TD12 woofer, or the Tux-1099, both of which will best your La Scala in every category. If you can wait, the new soon to be released redesign of the Sentinel-15 will be the ultimate in that price range! I would wait for it, but that's just me.
Martycool007 is offline
post #5 of 15 Old 04-26-2014, 06:24 AM
LFM2's Avatar
I would recommend looking at the Klipsch forums and determining if an upgrade of the LaScalas may fit the bill. The Eminence Kappa 15C is suggested a cheap and effective upgrade. They are $110 each from Parts Express.
I would also that you also look at the ported LaScala threads for a simple, effective cabinet mod.
LFM2 is offline
post #6 of 15 Old 04-26-2014, 12:30 PM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
My La Scalas gained a lot of authority and sound better at all volumes with an Emotiva UPA-7 driving them than they did with the HK AVR-235 -- not that they sounded bad before.
moosifee is offline
post #7 of 15 Old 04-26-2014, 09:29 PM
A9X-308's Avatar
Liked: 1139
The Tux1099 looks good to me on paper (not ever heard them) so MC007's suggestion to get thee to hear some sounds good to me.
I would suggest some caution with this. I hung around the Klipsch forums for many years when I had mine and they are very bad with fanboi-ism, both towards Klipsch stuff and the small number of other people who do 'approved' mods.
The K33 is the least of the problems with the LS and the Kappa won't make that much difference. oney definitely should be spent on the rubbish MF/HF sections, both drivers and flares.
I've done it and though it makes a small difference in some rooms, it's not that great. You'll also devalue your LS if you do it, so better to start from scratch and make new LS if there is some potential you may sell the original LS sometime in the future.
An amp change would be the last place I would spend money as it is by far the least efficacious. They are a very easy speaker to drive in terms of load and efficiency.
A9X-308 is offline
post #8 of 15 Old 04-27-2014, 12:18 AM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
He already has the amp. It's a matter of plugging it in.
moosifee is offline
post #9 of 15 Old 04-27-2014, 12:42 AM
A9X-308's Avatar
Liked: 1139
Not the point. It's not going to make any difference.
A9X-308 is offline
post #10 of 15 Old 04-27-2014, 12:52 AM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
Funny, when you said it was the last place you would spend money, I thought the idea that money would not be spent was somehow salient. Carry on.
moosifee is offline
post #11 of 15 Old 04-27-2014, 02:48 AM
blazar's Avatar
Quoted: 730 Post(s)
Liked: 532
I second this comment... Highly likely your issue and is an issue i have personally now. Adjust speaker and listening position some as a first option.
Blazar!
blazar is offline
post #12 of 15 Old 04-27-2014, 05:03 AM
Quoted: 280 Post(s)
Liked: 180
You could always go with the CornScala since you already have the K-33 woofer. Then all you would need is the JBL clone M2380 horn with a Selenium or FaitalPro 2" mid, and then the Selenium D220ti compression driver with its stock horn and a Crites crossover.
I personally would be more inclined do sell the La Scala's and build some Seos based speakers, such as the Tempest or the new redesigned Sentinel. They should best your La Scala's by quite a decent margin.
post #13 of 15 Old 04-27-2014, 11:59 AM - Thread Starter
Liked: 31
I'll start with this just to see if I can get anything more out of them. May take me more than a few reads to comprehend, lol. Course that depends on how many beers I have too.
I'm not in a rush to do anything, so I think that waiting for the redesign of the Sentinel sounds like the best option. I have no problem building enclosures. Crossovers? Never done them (or soldered for that manner) before. Either I'll venture into it or get pre-assembled ones.
Thanks for the ideas - love this forum.
post #14 of 15 Old 04-27-2014, 01:13 PM
brian6751's Avatar
Quoted: 1083 Post(s)
Liked: 1077
Definitely go by this first so you can make sure it's your speakers and not room cancellations.
I can tell you that I have owned a pair of LA's and I first replaced them with Cornscalas and then a pair of SEOS Tempests with TD12M woofers. The SEOS were easily my favorite.
The
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #15 of 15 Old 04-27-2014, 01:18 PM
A9X-308's Avatar
Liked: 1139
And changing from one capable SS amplifier to another on an efficient and easy to drive speaker will not make any difference, irrespective of whether it costs anything or not. That is the salient point. What is so difficult to understand about that? I misread the initial post, hence my response.
A9X-308 is offline
