{N00B} Box Tuning & Sub/Amp Qustions - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 57 Old 04-27-2014, 07:33 PM - Thread Starter
yomama99's Avatar
Probably going to be upright in the corner but I will redo my sub crawl and see what happens. Now Im really excited to build this and put it all together! I cant wait!
Thanks again for all your help!
-Colton
yomama99 is offline
post #32 of 57 Old 04-27-2014, 08:22 PM
Mrkazador's Avatar
Quoted: 263 Post(s)
Liked: 390
You could do a sonosub which uses sonotube (concrete form) for the enclosure. All you would need to build is the end caps.
Here is an example of a sonosub
http://www.avsforum.com/t/1092905/my-sonosub-with-mach5-ixl-15-2-2/0_100
Mrkazador is offline
post #33 of 57 Old 04-28-2014, 01:31 PM - Thread Starter
yomama99's Avatar
Originally Posted by Mrkazador View Post
The maelstrom is a beast of a sub, I would buy it for $250. Do you know if the driver is the first gen maelstrom or 2nd gen? There is two versions.
The guy told me that he thinks it is a first gen. Is it still worth looking into? Do you by chance know what the differences between the first and second gen are? In winISD it is showing the Gen i producing more SPL then the Gen ii.
yomama99 is offline
post #34 of 57 Old 04-28-2014, 01:41 PM
Mrkazador's Avatar
Quoted: 263 Post(s)
Liked: 390
They model fairly close to each other so theres not much difference. If the driver is working fine its definitely worth a buy. High power handling and excursion to back it up, its a nice driver for sure.
post #35 of 57 Old 04-28-2014, 01:55 PM - Thread Starter
yomama99's Avatar
Alright haha thanks! I will still listen to it before I buy but what's the rms on it? I was looking for the specs and all I found was "1500 watts" and I don't know if it's rms or peak?
yomama99 is offline
post #36 of 57 Old 04-28-2014, 03:24 PM
Mrkazador's Avatar
Quoted: 263 Post(s)
Liked: 390
I would assume that is RMS.
post #37 of 57 Old 04-28-2014, 03:47 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
In modeling it seemed like it would take 2000 watts. That is the wattage I used (I guessed) when I was looking at air port velocity. I figured if 2000 watts was good, then it's good. You'll need a lot of amp for that thing.
Mfusick is offline
post #38 of 57 Old 04-28-2014, 05:57 PM - Thread Starter
yomama99's Avatar
The amp he is selling is 4000 on 220v or something like 2300 on 120. I really wanted the amp with it but he had someone say they are going to pick it up on Saturday but it was first come first serve. I would feel bad for taking it from someone like that haha Between you and me, I hope he passes it up so I can grab it! Do you know of any good reasonably priced amps that can get the job done? Whenever I search amps, I get things like Pyle. (thats not going to happen) The main reason I was so interested in the sub and amp was because I could get them together. No I would have to drop some serious coin on an amp to power the beast! Any suggestions?
yomama99 is offline
post #39 of 57 Old 04-28-2014, 06:14 PM
Mrkazador's Avatar
Quoted: 263 Post(s)
Liked: 390
Ep4000
Inuke 3000/6000 with or without DSP
Those are the two most popular right now.
post #40 of 57 Old 04-28-2014, 06:34 PM - Thread Starter
yomama99's Avatar
Ep4000
If went with the iNuke 3000, I could be able to bridge it and give the sub substantial power correct, Im a little fuzzy on bridging? I know about lower impedances means more power from car audio but not bridging the amp?
yomama99 is offline
post #41 of 57 Old 04-28-2014, 06:54 PM
Mrkazador's Avatar
Quoted: 263 Post(s)
Liked: 390
A bridged inuke 3000 will be fine for a single maelstrom x. I think it puts out something like 2000w @ 4 ohms bridged. What high pass filter are you going to use?
post #42 of 57 Old 04-28-2014, 07:12 PM - Thread Starter
yomama99's Avatar
I was thinking 80 hz?
yomama99 is offline
post #43 of 57 Old 04-28-2014, 07:21 PM
Mrkazador's Avatar
Quoted: 263 Post(s)
Liked: 390
That is a lowpass. A high pass protects the driver from over excursion below tuning with a ported enclosure. The inuke DSP can set one as low as 20hz but it might be possible to set one lower with a few tricks.
post #44 of 57 Old 04-28-2014, 07:43 PM - Thread Starter
yomama99's Avatar
I would like 10 but probably should do 15 because I get heavy on the volume knob sometimes. I dont really wanna go any higher than 15 because thats the reason i tuned the box low haha Do you think I could do something around 15 with that amp?
yomama99 is offline
post #45 of 57 Old 04-28-2014, 07:56 PM
Mrkazador's Avatar
Quoted: 263 Post(s)
Liked: 390
post #46 of 57 Old 04-28-2014, 08:07 PM - Thread Starter
yomama99's Avatar
Thank you, if i get one i will give this a shot! I have a lot to learn about home subs vs car audio, but im getting there!
yomama99 is offline
post #47 of 57 Old 05-02-2014, 06:21 PM - Thread Starter
yomama99's Avatar
I have been looking at the iNuke but I am not familiar with the connections in the back? I was expecting something like the single sub out from my receiver to the amp and something like speaker wire from the amp to the sub?
yomama99 is offline
post #48 of 57 Old 05-02-2014, 06:26 PM
Mrkazador's Avatar
Quoted: 263 Post(s)
Liked: 390
Receiver - sub output - rca to xlr
inuke in stereo - 2 pole speakon  to bare wire - bare wire connects to sub
inuke bridged - 4 pole speakon to bare wire - bare wire connects to sub
post #49 of 57 Old 05-02-2014, 06:29 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Link ?
I just happen to need a spare.
Mfusick is offline
post #50 of 57 Old 05-02-2014, 06:35 PM - Thread Starter
yomama99's Avatar
Ok, I would need
http://www.amazon.com/Neutrik-NA4LJX-4-Inch-SpeakON-Adapter/dp/B00067JSM8/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1399080605&sr=1-1&keywords=4+pole+speakon
and
http://www.amazon.com/Hosa-Cable-XRM105-RCA-Male/dp/B000068NZK/ref=sr_1_2?s=musical-instruments&ie=UTF8&qid=1399080660&sr=1-2&keywords=rca+to+xlr
With the two 4 pole speakon connectors, I would go + and - from subwoofer to each 4 pole speakon and plug them into both A and B channel for bridged. Does that sound about right?
yomama99 is offline
post #51 of 57 Old 05-02-2014, 07:00 PM
Mrkazador's Avatar
Quoted: 263 Post(s)
Liked: 390
Link ?
I make my own cables so I don't know what people are recommending for cables.
Originally Posted by yomama99 View Post
Ok, I would need
and
For a bridged inuke you'll need this
one 4pole speakon: http://www.parts-express.com/neutrik-nl4fx-speakon-spx-cable-connector-4p--092-190
one rca/xlr: http://www.parts-express.com/xlr-female-to-rca-female-adapter--240-438
The rca xlr cable you linked to on amazon should work too.
The RCA/XLR cable connects to the "CH A" input on the right. The speakon connects to "CH A" output on the left, this hooks up to your sub positive and negative.
Boxozaxu likes this.
post #52 of 57 Old 05-02-2014, 07:16 PM - Thread Starter
yomama99's Avatar
Ok, so i'll only need one 4pole for bridged? nice, thanks again!
yomama99 is offline
post #53 of 57 Old 05-11-2014, 11:13 AM - Thread Starter
yomama99's Avatar
I got the sub. I'm not sure if its gen i or gen ii? it has stitched leads which I thought was gen ii but it has a single 4 ohm coil? do you by chance know what one that is? i have tried to find something on the single four but couldnt find anything. Also, it looks like it has or had another set of leads for another coil but the leads are just stitched to the spider and lead to nowhere and have imp. There are even holes for another set of terminals too. But the sub sounds great and weighs a ton!
yomama99 is offline
post #54 of 57 Old 05-11-2014, 11:23 AM
N8DOGG's Avatar
Quoted: 1111 Post(s)
Liked: 1217
My Gen 2's were stitched and single 4 ohm coils.
N8DOGG is offline
post #55 of 57 Old 05-11-2014, 11:41 AM - Thread Starter
yomama99's Avatar
Ok then! I got a gen 2! Thanks! I hope to be getting the amp soon and starting on the box, I cant wait!
yomama99 is offline
post #56 of 57 Old 05-11-2014, 03:23 PM
N8DOGG's Avatar
Liked: 1217
I don't know what the gen 1's were though but if memory serves me, they were 2+2 coils. Either way, it's a awesome sub!
N8DOGG is offline
post #57 of 57 Old 05-11-2014, 05:53 PM - Thread Starter
yomama99's Avatar
I know, I cant wait to get this thing hooked up so some real power so I can see the 33mm excursion! I had it wired in series with the two 15s in my car on 1200 watts, the 15s are rated at 600 rms and we going to town but the Maelstorm shrugged it off like nothing! I get excited every time I look at it!
yomama99 is offline
