Two cylinder sub-woofers in SVS style. - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 158 Old 05-07-2014, 12:15 PM
TheGiantPeach's Avatar
Quoted: 134 Post(s)
Liked: 117
Originally Posted by cochinada View Post
Yes that makes sense but this poses some engineering problems as I would have to raise it significantly which means some feet about 220mm x 35mm.
I'm not sure what you mean by "220mm x 35mm"
TheGiantPeach is offline
post #92 of 158 Old 05-07-2014, 12:20 PM
Quoted: 134 Post(s)
Liked: 117
sorry, double post
post #93 of 158 Old 05-07-2014, 01:22 PM - Thread Starter
cochinada's Avatar
I'm talking about 6 feet each with 220mm long and 35mm diameter that will support the cylinder.
cochinada is offline
post #94 of 158 Old 05-07-2014, 01:33 PM
Quoted: 134 Post(s)
Liked: 117
Oh right, yeah you will have to build something like that. I don't know how other people do it because I haven't followed a cylinder sub build before. I imagine you could just screw some dowels onto the baffle, and maybe also have a circular base to screw the other end of the dowels into.
post #95 of 158 Old 05-07-2014, 02:43 PM - Thread Starter
cochinada's Avatar
Yes, the circular base is a must to keep the feet aligned. I will probably use some metallic tubes with an insert but I was not considering that length.
post #96 of 158 Old 05-07-2014, 07:00 PM
LTD02's Avatar
Quoted: 2524 Post(s)
Liked: 2867
"The PC13-Ultra has a 13,5" driver according to the information on the SVS site. I will have an 18". So here I guess I have an advantage at least theoretically."
that is the comparison that is shown in #83.
as for clearance, as the driver begins to move, only about half of the driver excursion translates to additional surround motion. so a decent rule of thumb is about whatever the surround height is, allow for that much more clearance.
Listen. It's All Good.
LTD02 is offline
post #97 of 158 Old 05-07-2014, 11:42 PM - Thread Starter
cochinada's Avatar
I don't know what is the surround height. I only know surround speakers but don't think it has anything to do with it...
Xmax = 30mm.
post #98 of 158 Old 05-08-2014, 01:25 AM
LTD02's Avatar
Liked: 2867
cochinada likes this.
LTD02 is offline
post #99 of 158 Old 05-08-2014, 04:42 AM - Thread Starter
cochinada's Avatar
I see! So you say that 2" (the surround height) between the bottom of the surround and the floor is enough?
I've decided to go for about 6".
Now for a different subject! In terms of damping materials which one of these examples do you reckon is more effective for covering the inside of the box?
DAMPING30
Self-adhesive insulating mat
Recycled felt self adhesiv.
Thickness: 30mm
PYR70
Absorption mat PYR 70 1000 X 500 X 70 MM
Pyramid structure. Best reflection and resonance damping. Very suitable for the equipment of measuring rooms.
Surface: pyramidal
Area Weight: 30.00 kg / m²
TYROFOAM/30
TYROFOAM SG 30/140 245 x 325 x 30.0 mm
Heavy, high expansion foam cushioning for effective Airborne sound absorption. High effectiveness in the lower frequency ranges. For the assignment of loudspeaker cabinets. Also in connection with Bitumex.
Glue proposal with contact cement Interkoll L1534.
Density: 140.0 kg/m3
Dimensions: 245x325 mm
TYROTEX/30/1
TYROTEX N30 30KG/M3
1 mat 0.5 X 1M
Surface: convoluted
Colour: Anthracite
Dimensions: 1000 x 500 mm
Absorption according to DIN 522 21
post #100 of 158 Old 05-09-2014, 10:00 AM
pdxrealtor's Avatar
Quoted: 154 Post(s)
Liked: 154
Subscribed!
Have you ruled out polyfill for a reason?
pdxrealtor is offline
post #101 of 158 Old 05-09-2014, 10:02 AM
Quoted: 134 Post(s)
Liked: 117
Originally Posted by pdxrealtor View Post
Subscribed!
Yeah I've heard good things about just using 3-4 pillows to smooth out resonances.
post #102 of 158 Old 05-09-2014, 10:15 AM - Thread Starter
cochinada's Avatar
No, no. This is just for covering the walls. For filling I'm going to use Visaton's polyester.
post #103 of 158 Old 05-10-2014, 04:31 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Did you mean coving the walls of your enclosure, or covering the walls in your room?
I would not recommend any of those for covering the walls of your theater room!
For that, you something like 4" of OC703 with a 4" air gap, or perhaps something like Safe-n-Sound in a similar fashion.
Martycool007 is offline
post #104 of 158 Old 05-10-2014, 08:03 AM - Thread Starter
cochinada's Avatar
Of my subwoofer of course. It's not enough to fill it. I don't have a theater room but a normal living one and don't intend to do anything about it.
post #105 of 158 Old 05-13-2014, 07:19 AM - Thread Starter
cochinada's Avatar
Hi,
I've inquired about the bolts for mounting this driver as well as the minimum floor distance and got this answer from Sundown after a looooooooooooooong time waiting:
"if down firing I would recommend #8 bolts and use lock washers as well.
You would need at least 4" from floor to woofer.
in mm the distance from center to screw hole is 223mm"
So, after some research I found out that a #8 bolt is more or less the equivalent of an M4 (4mm). More exactly, #8 = 4.166mm.
I find it a little weak as for instance on the speakers I've build my 12" driver uses M5 (5mm) and is much lighter.
I've already asked if I can fit M5 but it will probably take a week or so to get an answer.
The good news is that at least the distance from the floor I got it right as I will have 5.9 inches.
TheGiantPeach likes this.
post #106 of 158 Old 05-13-2014, 01:19 PM
McStyvie's Avatar
Liked: 78
I used the visaton in my sub too, it is ok, though I needed 6 bags for 90 litres, so plan for a bit more than they say.
Also, why not use dowels with the M4s? Or Dübel auf Deutsch. I just used plastic ones from Toom, they hold like 50kg each, so 8 is bomb proof. Also much easier than lock washers.
Sent from my GT-I9300 using Tapatalk
McStyvie is offline
post #107 of 158 Old 05-13-2014, 01:33 PM - Thread Starter
cochinada's Avatar
Yes, I'm also considering visaton or sonofil for filling, depending upon which better deal I can find. For the covering of the inside wall I think I'm going to use TYROFOAM/10.
In some places they say that one bag is good for 20l but I also read that 1.5 is best so this looks really more realistic.
I didn't understand your suggestion about the M4 and a dowel and I also don't know what is Dübel auf Deutsch although 50kg sounds very good! Are you talking about supporting the subwoofer like feet or mounting the driver?
I'm planning to use these for mounting the driver but the doubt is to whether I go for M4 or M5:
post #108 of 158 Old 05-13-2014, 01:59 PM
pdxrealtor's Avatar
Quoted: 154 Post(s)
Liked: 154
A plywood mounting baffle and 2" wood screws will work just fine. FWIW.
post #109 of 158 Old 05-13-2014, 02:09 PM - Thread Starter
cochinada's Avatar
This is what my subwoofer will look like. Instead of varnished baltic birch as planned it will be made of MDF and covered with cork panels.
post #110 of 158 Old 05-14-2014, 12:25 AM
McStyvie's Avatar
Liked: 78
this is what I mean:
Dübel
You drill the hole, drop that plastic bit in, and then the screw goes inside. Works a charm and is easier than trying to line up the holes for the ones you posted. i.e. if you drill slightly crooked, then you will have a hard time getting the screw to go into the lock at the bottom smoothly.
Hope that makes sense.
I gave you the German translation of "dowel" because you posted a link in German, so I thought you lived in Germany smile.gif
McStyvie is offline
post #111 of 158 Old 05-14-2014, 01:00 AM - Thread Starter
cochinada's Avatar
Dübel
Ah now I see! Very clever. The only problem is that with this woofer I don't have much space to drill a whole larger than the size of the screw because the holes are very close to the border of the driver. mad.gif
No, I live in Portugal but since we don't have almost anything here I need to by most material in Germany but I don't speak the language. smile.gif
post #112 of 158 Old 05-19-2014, 02:01 AM - Thread Starter
cochinada's Avatar
@TheGiantPeach,
Hello, is it 0.6A and 12VDC enough for the transformer for the miniDSP or is it better to have more current?
post #113 of 158 Old 05-19-2014, 12:36 PM
Quoted: 134 Post(s)
Liked: 117
@TheGiantPeach,
According to their website, you need at least a 0.125A 12v supply, so you should be just fine with that.
How are things going with this project? Have you started purchasing things yet?
post #114 of 158 Old 05-19-2014, 01:17 PM - Thread Starter
cochinada's Avatar
I've purchased almost everything right now except for the spikes. All I have to do is wait for all the things to arrive.
The cabinet for instance should be done on the first week of June but the driver will probably arrive only at the end of the month because as I was told Sundown has a 20 day manufacturing deadline and then it will ship to Italy and finally to me.
Anyway I should have the cabinets ready for mounting the drivers long time before that.
post #115 of 158 Old 05-19-2014, 01:20 PM
Quoted: 134 Post(s)
Liked: 117
That's awesome! I'm excited to see your progress and really excited for you to have some killer subs!
post #116 of 158 Old 05-19-2014, 01:23 PM - Thread Starter
cochinada's Avatar
Thanks a lot! I'm also very curious and a bit nervous I confess, to see if these subs are really going to be as good as I hope.
post #117 of 158 Old 05-19-2014, 01:45 PM
Quoted: 134 Post(s)
Liked: 117
Yep, I felt exactly the same while building mine. But it ended up sounding better than I had hoped for. And at least on paper, yours should be far louder and lower than mine.
post #118 of 158 Old 05-21-2014, 08:25 AM - Thread Starter
cochinada's Avatar
This guy doens' like high pass filters:
"It's important to note that, only a sealed subwoofer (with a system Q of 0.5 to 0.707) with it's inherent 12dB/octave roll off, can offer the optimal transient repsonse and a natually flat in-room response, albeit below the lowest room mode. Adding a high pass filter to protect the driver from excessive bottom end, internal EQ or tuned ports (which rotate phase) to boost output, ALL impact this requirement. The DXD12012 (and the 808) ticks these respective boxes, with it's internal EQ set to allow the resumption of the natural roll off, below 30Hz."
http://www.avforums.com/review/kreisel-sound-dxd-12012-and-quattro-stack-review.388
post #119 of 158 Old 05-22-2014, 02:24 AM - Thread Starter
cochinada's Avatar
Talking about filters, I've been reading the information about the miniDSP and it looks like I'm going to need to buy a plugin. mad.gif
Is this enough for the LT and HP and LP? Or do the LP and HP come with the box and don't need another plugin?
2way Advanced
post #120 of 158 Old 05-22-2014, 06:36 AM - Thread Starter
cochinada's Avatar
- room gain will likely be coming in around 24hz or so, so if the response starts to roll off at that point in the winisd model, it is ok. the room will help boost it back up.
So, taking this into account, in theory the graph in red should be better as it achieves greater SPL and starts to roll off at about 25Hz or so. Agree?
