AVS Group Project......Speaker Name: SEOS Maximus - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 223Likes
post #31 of 1280 Old 05-15-2014, 09:47 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
Originally Posted by Erich H View Post
Here's a comparison between the Alpha-8 (same size as the Fusion-8) along with the Fusion-12 that some think is kinda big:
Here they are next to SEOS MAXIMUS!
Erich, my wife is starring at me like I'm crazy because I'm literally laughing out loud at how big those monsters are!... I've personally carried a set of Tempest down into my theater so I know how big they are compared to the two huge speakers....lol
It's going to take at least two guys to move those things around!....lol
jbrown15 is offline
post #32 of 1280 Old 05-15-2014, 09:48 PM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1531
Like the look of the wmt
chalugadp is offline
post #33 of 1280 Old 05-15-2014, 09:49 PM
doc5150's Avatar
Quoted: 43 Post(s)
Liked: 34
This is gonna rock...subscribed I like the 3rd one...badass looking
doc5150 is offline
post #34 of 1280 Old 05-15-2014, 09:49 PM
jbrown15's Avatar
Liked: 1995
Originally Posted by chalugadp View Post
Is that's what in the funk audio speakers coming to your GTG
Not that I'm aware of.
jbrown15 is offline
post #35 of 1280 Old 05-15-2014, 09:51 PM - Thread Starter
Erich H's Avatar
Quoted: 1478 Post(s)
Liked: 1895
If the 21" B&C is used, it has a neo magnet that will save a lot of weight. The 10's could be neo too.
Not sure how the ports will go. I like that my original Maximus design uses 3 circular ports like the Fusion-12. Those are drawn at 6.25" because that's the outside diameter of the 4" Precision Ports. But I'm not sure if 4" is big enough, so it might need a big slot port.
The 18" JBL pro cinema speakers use dual 4" ports I believe. But I'm hoping to speaker spank those using the 21" B&C with 60mm peak excursion. eek.gif
_______________________
The SEOS Waveguide Project
Erich H is offline
post #36 of 1280 Old 05-15-2014, 09:56 PM
jbrown15's Avatar
Liked: 1995
Just the cabinets are going to weigh a ton, even if its Baltic birch with that size....lol
jbrown15 is offline
post #37 of 1280 Old 05-15-2014, 10:07 PM
WereWolf84's Avatar
Quoted: 291 Post(s)
Liked: 110
I'm wondering is this speaker going to be used in cinema or home tongue.gifbiggrin.gif
WereWolf84 is offline
post #38 of 1280 Old 05-15-2014, 10:37 PM
clausdk's Avatar
Quoted: 214 Post(s)
Liked: 82
Awesome project!
clausdk is offline
post #39 of 1280 Old 05-15-2014, 10:40 PM
mt2mt2's Avatar
This is gonna be GREAT!!!!
mt2mt2 is offline
post #40 of 1280 Old 05-15-2014, 11:01 PM
rsvr79's Avatar
Quoted: 186 Post(s)
Liked: 116
Use an 18" woofer in a folded horn with a 30 Hz or lower shoulder. The outline from the side should look like an L with the horn mouth front firing at the bottom.
Then in the vacant space above the folded horn mouth, use a smaller driver (10"?) in a compression chamber with a SEOS 24 for your mids. Like how Avantegarde does with their horns.
Then above the SEOS 24 have a kickass CD on a SEOS 15 for the highs. With maybe a bullet tweeter for the dog whistle sound effects.
I'm not at my laptop right now or I would throw together a super quick sketchup. Give me a few minutes.
edit Done. By "a few minutes" I meant "60 minutes". This is super rough, certainly not measured out properly or folded properly. And the mounting solution was just a random idea.
Exploded Mid. Pretend these are smooth joins and not half-assed sketches. Don't judge me.
Front. That's an 18" in a folded horn, an 8" in a compression chamber on a SEOS 24, a big CD on a SEOS 15, and a bullet tweeter.
3/4.
Side.
rsvr79 is offline
post #41 of 1280 Old 05-16-2014, 01:07 AM
LTD02's Avatar
Quoted: 2525 Post(s)
Liked: 2868
if this is meant to be powered by an avr, you may wish to consider using a woofer with less weight and power handling in order to keep efficiency/sensitivity as high as possible. kind of in the spirit of the old skool builds.
having a voice coil that can take 2000 watts and a cone/surround/spider all up to the task beat efficiency down and with 100 watts or so, the system won't be coming anywhere close to using all the voice coil excursion.
in order to get the most sensitivity out of the system, a lightweight driver, such as the old altec 416-8C is the way to go. gosh, I wonder why altec designed that driver that way? ;-)
a horn is always interesting, but even for 30hz, the length would have to be somewhere in the 12.5 feet long region. not that it can't be done, just might be a little more size/complexity than you want to bite into.
i'm not completely sure that I understand what the application is for this product. it would seem much better to have an active crossover for the lower end where all the power will be used and this is what a typical avr does with the subwoofer output. ?
Scott Simonian likes this.
Listen. It's All Good.
LTD02 is offline
post #42 of 1280 Old 05-16-2014, 01:43 AM
LTD02's Avatar
Liked: 2868
rsvr79, that is a very creative design.
how would the 8" mid in a compression chamber work on the seos 24"? are you suggesting just firing it into the horn with no modification to the horn itself? if so, what kind of upper limit in frequency response would something like that have?
LTD02 is offline
post #43 of 1280 Old 05-16-2014, 02:01 AM
BassThatHz's Avatar
Quoted: 2350 Post(s)
Liked: 2115
Trying to imagine them in my room.
Will there be a center channel version too?
BassThatHz is online now
post #44 of 1280 Old 05-16-2014, 05:18 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Love this thread! It's always so much fun picking and fantasizing drivers!
RSVR79- I don't think that it would be optimal to use a Seos-15 for the tweeter because the tweeter won't have to extend all that low, and assuming the other Seos waveguides have the same pattern control on the top end, then a Seos-10 might be a better, or simpler tool for the job. Perhaps a Seos-10 with a Radian 475BePB?
I also really like the idea of using the Beyma TPL-150, but, that thing is expensive and considering the cost of the B&C 21" sub and what ever high quality mids are used, that starts to seriously add up!
Martycool007 is offline
post #45 of 1280 Old 05-16-2014, 05:19 AM - Thread Starter
Erich H's Avatar
Liked: 1895
i'm not completely sure that I understand what the application is for this product. ?
No design has been set in stone and I'm hoping for more ideas. But it's got to be big and crazy.
Erich H is offline
post #46 of 1280 Old 05-16-2014, 05:19 AM
Quoted: 280 Post(s)
Liked: 181
Also, that new BMS ribbon planner that someone linked on the first page looks absolutely amazing!
post #47 of 1280 Old 05-16-2014, 05:30 AM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
this idea reminds me a lot of Jakes SEOS 24 monoliths which are using the 24+ BMS compression driver and 4 AE TD 15s running an active xover. they are beyond silly
i like the look of the TMW you drew above more than the WTMW but thats just me
Curious to see where this goes
Sibuna is offline
post #48 of 1280 Old 05-16-2014, 06:12 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Your description makes me think of this...
What if you made the cabinets attach together but separate like wilson audio to help with moving them? You could probably do some pretty cool designs like that too.
JWagstaff is offline
post #49 of 1280 Old 05-16-2014, 06:37 AM
tuxedocivic's Avatar
Quoted: 2186 Post(s)
Liked: 2055
Why the bA750 over the FL450. I'd go SEOS 18 with FL450 and 8" mids. Side by side mids cause problems, I'm warning you wink.gif Also, crossing really low with passive parts, is not easy.
You're thinking fairly extreme for the woofer section. I'd consider this an area of economy if that matters.
My youtube channel: Impulse Audio
tuxedocivic is online now
post #50 of 1280 Old 05-16-2014, 06:53 AM
JohnDean's Avatar
Quoted: 467 Post(s)
Liked: 206
I think I may need 2 of #4 for my backyard once I find a new one.
Just go all out for sure. I'm not sure this one has any room for words like "Economy" wink.gif
JohnDean is offline
post #51 of 1280 Old 05-16-2014, 07:27 AM
Liked: 2055
His OP mentioned reasonably priced drivers. ?
post #52 of 1280 Old 05-16-2014, 07:29 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
why does it have to be passive crossovers? Isn't using a miniDSP as an active crossover not only cheaper than passive, but better?
post #53 of 1280 Old 05-16-2014, 07:35 AM
JohnDean's Avatar
Quoted: 467 Post(s)
Liked: 206
Reasonable <> Economy.
I know what you mean though. I'd think that $1000 for a single speaker has some room for better than economy. I guess I'm forgetting that if it uses a bigger SEOS than the 15 they get expensive quick.
JohnDean is offline
post #54 of 1280 Old 05-16-2014, 07:37 AM
FredrikC's Avatar
Some thoughts:
Passive XO pluss low XO frequency and high power handling = no good.
SEOS 18" wih dual mids is probably not much better than existing 15" designs in terms of pattern control and sound quality.
My sugestion for a 3 way would be.
SEOS 24 + large format. 5-600-8kHz. Drive units: Radian 951 or similar.
4x12" woofers = more surface area and thermal handling than a single 21" and will allow to cross higher making it easier to stick to passive XO. Drive units: AE TD12H or similar.
Supertweeter crossed with minimum 4th order @ 8kHz. I've tried this and there is no audible comb filtering when crossed steep and there is a benefit in terms of decay and dispersion. Drive units: Bullettweeter or small ring radiator CD.
Quick sketch:
FredrikC is offline
post #55 of 1280 Old 05-16-2014, 07:43 AM - Thread Starter
Erich H's Avatar
Liked: 1895
I don't know where the crossover point will be to the dual 10's. If it's well under 1000hz, then using the BA-750 will allow for maximum wattage without any worry. Plus if the top is in it's own compartment, then it could be used by itself, which means the BA-750 would make more sense.
Again, this idea is a group project so nothing is set in stone right now.
Erich H is offline
post #56 of 1280 Old 05-16-2014, 07:57 AM
lukeamdman's Avatar
Quoted: 1226 Post(s)
Liked: 1515
I will post some cheesy drawings soon so you can see the size of these compared to something like the Fusion-12. It's a real eye opener. biggrin.gif
Here were my first 2 ideas:
SEOS-18 with the BA-750 compression driver.
Dual 10" mids directly underneath
Ported 21" B&C subwoofer at the bottom.
Baffle size is 24" x 49". Waveguide is at 44" off the ground.
Idea #2:
Dual 10" mids
Dual 18" pro woofers. Likely FaitalPro
This speaker would be set up like the 1099. The only problem is height and where to put the ports. Before ports, the baffle is 22" x 58". Waveguide roughly 35" off the ground.
I'm really liking idea #2. The SEOS-18 with the BA could be crossed under 1k, and using 18" drivers would keep the cabinet narrower and would save on weight over the 21's.
There are also MANY high sensitivity "pro" 18" drivers to choose from.
lukeamdman is offline
post #57 of 1280 Old 05-16-2014, 07:58 AM
mobeer4don's Avatar
Quoted: 135 Post(s)
Liked: 131
How about an economy/modernized version of the JBL 4345? http://www.audiokarma.org/forums/showpost.php?p=7797324&postcount=7
Or 4355 if you need to go larger? http://jbl43.com/?pid=53449515
mobeer4don is offline
post #58 of 1280 Old 05-16-2014, 09:03 AM - Thread Starter
Erich H's Avatar
Liked: 1895
I don't think it would be cheaper. Who knows if anyone else would even build these, so I'd rather just stick with a passive design for myself because I don't have a miniDSP or 6-9 separate amps to power 2-3 of them.
I don't know much about crossover design, but if there's a way to make the big woofer(s) run off a different amp separate from the top, that would be okay. Maybe bi-amping it? I don't know, that's why I was asking for ideas.
Erich H is offline
post #59 of 1280 Old 05-16-2014, 09:04 AM
pnw
pnw's Avatar
Quoted: 50 Post(s)
Liked: 78
Modular/stacked WMTMW using existing flatpacks for two 18" woofers, 18" SEOS with the best 1" CD, four good 6-7" mids 2x2 above and below the SEOS. (Side-by-side 6" produce narrower horizontal directivity than a 12", to extend directivity lower than the SEOS alone.)
LTD02 likes this.
pnw is offline
post #60 of 1280 Old 05-16-2014, 09:07 AM
jbrown15's Avatar
Liked: 1995
jbrown15 is offline
