AVS Group Project......Speaker Name: SEOS Maximus - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 214Likes
Old 05-16-2014, 03:22 PM - Thread Starter
Erich H's Avatar
Quoted: 1318 Post(s)
Liked: 1585
Hey, Erich. My speakers are saying, "Come at me, bro!"
Did you end up using dual 10's in each of your speakers? I don't think so.
Did you end up using a BA-750 for the compression driver? I can't recall that either. The BA stands for Bad Azz in case you weren't sure! biggrin.gif
_______________________
The SEOS Waveguide Project
Erich H is offline
Old 05-16-2014, 03:25 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 4892 Post(s)
Liked: 3814
Scott Simonian is online now
Anthony_Gomez's Avatar
Quoted: 61 Post(s)
Liked: 184
Oh, it is on Mister!
watch it, or Erich will find a way to make his avatar be the speaker :P
Anthony_Gomez is offline
Old 05-16-2014, 03:33 PM - Thread Starter
Erich H's Avatar
Liked: 1585
Erich H is offline
Old 05-16-2014, 04:02 PM - Thread Starter
Erich H's Avatar
Liked: 1585
What about skipping the dual or triple midranges and just go with a single 12" midbass woofer with a 21" woofer underneath?
Maybe like this:
http://www.parts-express.com/bc-12pe32-12-midbass-speaker--294-660
Erich H is offline
Old 05-16-2014, 04:07 PM
NWCgrad's Avatar
Quoted: 1041 Post(s)
Liked: 993
I dont get the double/triple midrange approach for an ultimate level speaker system. It looks kinda cool but its been done.
___________________________________________
Two ears and a brain comprise a powerful acoustical analysis tool, able to extract enormous resolution, detail, and pleasure from circumstances that, when subject to mere technical measurements, seem to be disastrous. Floyd Toole
http://www.avsforum.com/forum/15-gen...sement-ht.html[/B]
NWCgrad is online now
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1496
Maybe like this:
http://www.parts-express.com/bc-12pe32-12-midbass-speaker--294-660[/quote
Like that
chalugadp is offline
Old 05-16-2014, 04:41 PM
tuxedocivic's Avatar
Quoted: 1811 Post(s)
Liked: 1643
Then you might as well build a Fusion 12 and a multi sub system.
Maybe like this:
tuxedocivic is online now
Old 05-16-2014, 04:49 PM
BassThatHz's Avatar
Quoted: 1893 Post(s)
Liked: 1446
Chances are, someone who can afford multiple $1000 Maximus's, can also afford to go fully active with external amps, and have all the power in the world.
LR $1000 x2 = $2000
NU1000DSP $200 x 2 = $400
NU3000DSP $280 x 2 = $560
Total: $2960
LCR $1000 x3 = $3000
NU1000DSP $200 x 3 = $600
NU3000DSP $280 x 3 = $840
Total: $4440
An extra $480 per speaker isn't so bad; and no soldering is involved.
At least the option exists if they want to.
Active/passive mix is another option.
BassThatHz is offline
Old 05-16-2014, 05:52 PM - Thread Starter
Erich H's Avatar
Liked: 1585
I haven't said it was going to be the ultimate speaker. Big and loud.
Erich H is offline
Old 05-16-2014, 06:05 PM
jbrown15's Avatar
Quoted: 2522 Post(s)
Liked: 1993
Really at the end of the day hasn't everything been done?
LTD02 and Erich H like this.
jbrown15 is offline
Old 05-16-2014, 06:07 PM - Thread Starter
Erich H's Avatar
Liked: 1585
You're thinking home theater.........and not thinking about doing a fun project 'just because we can'.
The Fusion-12 with a multi sub system wouldn't be the same. If someone wants 2 really big full range speakers, the Maximus would be better than some Fusion-12's and 5 subwoofers scattered around with wires all over the place.
BassThatHz, I'm not sure I follow what you're saying. If $1000 is someone's maximum amount, they probably will care tacking on an extra 50%. If $1k is a lot for someone to spend on a speaker.....$500 extra certainly will be. I highly doubt anyone else would be building these but me anyway.
Erich H is offline
Old 05-16-2014, 06:20 PM
Quoted: 825 Post(s)
Liked: 454
I don't know much about crossover design, but if there's a way to make the big woofer(s) run off a different amp separate from the top, that would be okay. Maybe bi-amping it? I don't know, that's why I was asking for ideas.
How about a plate amp with speaker-level inputs for the bass, and then passive above it? (Like AJ's Soundfield Audio Monitor 1.) Something like the 500W Ying amp might actually be cheaper than a good LF passive crossover.
Here's what I'd like to throw into the ring:
Top: biggest SEOS you're willing to use, your best 1" CD
Midbass: B&C's new 12NBX100, open baffle (look at that FR!)
Bass: B&C 21SW152 in open baffle + out-of-phase backwards-facing closed box 15 powered by plate amp so you can adjust the radiation pattern in the room.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Old 05-16-2014, 06:51 PM
A9X-308's Avatar
Quoted: 1040 Post(s)
Liked: 771
Originally Posted by rsvr79 View Post
edit a modular design I drew up a while ago. It was designed around 12's, 6's, and a SEOS 12, but there's no reason it couldn't be scaled up.
http://imgur.com/a/Dse9M
My surrounds are like that. Here's the sketch I did some time ago to mock up the idea before building the crappy mdf boxes they're currently in.
They use TD15, TD10 and a JBL Ewave WG, but I'll probably order the QSC clones from Parts Express soon as the rebuild is to start as soon as I can get some time on the big table saw. These are active of course.
A9X-308 is offline
Old 05-16-2014, 06:54 PM
NWCgrad's Avatar
Liked: 993
Perhaps...but the Tux1099 already has the side by side mids. I assume Erich would want something different, but all who remember the Bad News Bears know what happens when you assume.
Old 05-16-2014, 06:56 PM
Quoted: 61 Post(s)
Liked: 184
IMO (and I'm not the one invested here lol) different only matters to me if it achieves something greater than the conventional.
Old 05-16-2014, 07:27 PM
LTD02's Avatar
Quoted: 2185 Post(s)
Liked: 2402
Originally Posted by pnw View Post
Modular/stacked WMTMW using existing flatpacks for two 18" woofers, 18" SEOS with the best 1" CD, four good 6-7" mids 2x2 above and below the SEOS. (Side-by-side 6" produce narrower horizontal directivity than a 12", to extend directivity lower than the SEOS alone.)
+1
i'm not completely sure that I understand what the application is for this product. ?
No design has been set in stone and I'm hoping for more ideas. But it's got to be big and crazy.
what i meant is whether or not you want to get the highest efficiency out of the system for a setup powered by an avr at something like 100-200 watts
OR
maximize output using massive power amplification and drivers with extreme power handling/output potential.
BECAUSE
those call for two radically different designs.
Originally Posted by FredrikC View Post
Some thoughts:
Passive XO pluss low XO frequency and high power handling = no good.
+1
a low crossover point would require a very large inductor, aka "choke", right in front of the woofer. that will heat up, increase resistance and generally isn't a good idea...which of course is why you almost never see it done, especially in pro audio applications.
Plus, that's a design that might be done at a later time anyway.
have you finally got them all properly set up and integrated?
for what they are, yours are probably about as good as one can do.
Maybe like this:
+1
+1
more often than not.
tux and i are on the same page here. the "subs" are just the woofer channel, whether or not they are in the same enclosure. running them as "subs" allows for separate power to them, which is where all the power in a system like this is required.
i'll submit a suggestion in a bit. :-)
Scott Simonian likes this.
Listen. It's All Good.
LTD02 is offline
Old 05-16-2014, 07:44 PM
chalugadp's Avatar
Liked: 1496
LTD02 likes this.
Old 05-16-2014, 07:44 PM - Thread Starter
Erich H's Avatar
Liked: 1585
Okay, if you guys don't think the dual woofers side by side is a good idea, then maybe MTM is better. The side by side ones would make 2 enclosures much easier with the subwoofer in the bottom one, but that's alright.
I put in the Fusion-12 for size comparison. biggrin.gif Keep in mind the ports can be changed a lot. I was even thinking side porting would be just fine for these speakers.
The center of the waveguide height in the first big speaker is around 44" off the ground. Second one is about 42". Third is about 41" up. All would use the BA-750 compression driver to allow for a lower crossover.
Rebel975 likes this.
Erich H is offline
Old 05-16-2014, 07:53 PM
antisuck's Avatar
Quoted: 91 Post(s)
Liked: 133
Erich I am far from one of the experts here, but to match directivity I think you need to cross high to a smallish mid or cross low to a larger mid (or side by side mids) so your last diagrams may not work well, or at least not use the BA to potential. Or use a horn on the mids to control directivity another way. Or cross ridiculously low like the noesis where everything is omni.
antisuck is online now
Old 05-16-2014, 07:55 PM
jbrown15's Avatar
Liked: 1993
The Tempest looks like a tiny little bookshelf speaker next to those monsters!...lol eek.gif
jbrown15 is offline
Old 05-16-2014, 07:56 PM
antisuck's Avatar
Quoted: 91 Post(s)
Liked: 133
Lol I am referring to 10 and 12" mids as "smallish". This place is ruining me biggrin.gif
Old 05-16-2014, 08:03 PM - Thread Starter
Erich H's Avatar
Liked: 1585
I think one of the designers said that if there are 2 mid woofers under the waveguide and the crossover is low enough, it acts like a point source type set up. I'm not sure where that crossover point would be though.
Erich H is offline
Old 05-16-2014, 08:04 PM
stormwind13's Avatar
Quoted: 55 Post(s)
Liked: 90
YES! Been waiting for this a while now.
stormwind13 is offline
Old 05-16-2014, 08:27 PM
Liked: 1643
For two side by side 8" I'd assume around 700hz if my extrapolation is correct.
W-M-T-M-W All the way. 18-(2x8")-SEOS 18-(2x8")-18
LTD02 likes this.
Old 05-16-2014, 08:42 PM
LTD02's Avatar
Liked: 2402
similar to what many have suggested already.
i'm not sure why one would want to run those 18's passively, but to each his own.
seos 15 with quad 8's in a sealed enclosure with something like a 150-250 or so f3/q=0.707 would allow them to be run with no high pass crossover components.
18's ported and tuned to whatever the user wants. higher for more sensitivity/output. lower for more extension/sub-bass.
at 2' x 2' x 6.5'+ they would seem to qualify for the maximus label.
height was adjusted to get the horn to about 44" height.
woofers such as the 18ps76 could be used and are pretty cheap too, ~$200 ea and a pair give more than 120db output potential from 20hz with just about any tuning. so these speakers may not end up costing a fortune while producing quite a bit of output.
a plate amp or something to power the 18's would seem like a logical thing to do. several companies do something similar. passive midtops/powered bottom end.
LTD02 is offline
Old 05-16-2014, 08:45 PM
LTD02's Avatar
Liked: 2402
haha! we really were on the same page! that is what i was working on too. :-) well, i stuck a seos15 in there, but details...details... ;-)
and yes, something in that ballpark for the cross should be low enough for the effect that is being described.
LTD02 is offline
Old 05-16-2014, 08:50 PM
atabea's Avatar
Quoted: 311 Post(s)
Liked: 200
Now that looks truly bad-ass!! great stuff as usual, LTD.
atabea is offline
Old 05-16-2014, 08:56 PM - Thread Starter
Erich H's Avatar
Liked: 1585
LTD02,
As mentioned earlier, I don't care how those big woofers are powered, I just don't want an all active speaker.
I've drawn out that design you posted when Jeff was working on the 88 Special and asked him if using four of the 8" woofers should be considered as an option. He said something about them getting a bit louder and handling more power, but not bringing much more to the table for the increased size. But I can't recall if I mentioned the 18's up top and well as the bottom. Or maybe he just realized I was insane to consider that for home use. biggrin.gif
The BA-750 on the SEOS-18 can cross low enough to the side by side woofers to act as a point source. I believe it was Pete Schumacher that first mentioned it to me. I thought about using the BA-750 in the 88-Special, but in the end went with the DNA-360 so people weren't questioning if the speaker was 'timbre matched' to other models.
Erich H is offline
Old 05-16-2014, 09:04 PM
Liked: 1643
