Need help deciding on speaker box for SI18s - AVS Forum | Home Theater Discussions And Reviews
Old 05-23-2014, 09:45 PM - Thread Starter
abuwow's Avatar
There are so many builds here I like and want to do, but was wondering if anyone could recommend what may be best for me to try first.
I have 2 SI18 D2 and a inuke 3000dsp
Room is about 6000 cubic feet, will be only used for movies, the lower the hz the better, don't care about waf, have the tools and want a project so not interested in flatpacks.
I really like notnyt sealed and ported builds, and like I could have both subs in same box, but unsure how well that would end up for what I have purchased already and only having 2 instead of 8 of a better quality.
Otherwise was thinking a couple mini martys, or dual opposed and sonotubes look fun. IB is about the only thing I haven't really considered.
Thanks in advance,
Bob
Bombelman likes this.
abuwow is offline
Old 05-24-2014, 12:52 AM
Bombelman's Avatar
Quoted: 56 Post(s)
Liked: 52
Hi Bob, why not a "full marty" or something with similar internal volume ?
abuwow likes this.
Bombelman is offline
Old 05-24-2014, 05:45 PM
asarose247's Avatar
Quoted: 696 Post(s)
Liked: 452
check out ' kevings" marty build thread. he and I build a full marty in under a week and that was only a few days work. its 3/4 ply and kreg screws let you run full tilt in construction .
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
Old 05-24-2014, 05:50 PM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
With 6000cuft and 2 SI18D2 ,...probably best going to with 2 of the biggest martysubs.
Wire each D2 Driver in series for 4ohms x 900W on each channel.
... If you would of had D4's , they could of had been wired for a 2 ohm load X 1500W each.
abuwow likes this.
randyc1 is offline
Old 05-24-2014, 06:17 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Remember that inukes 900 is actually 600 and 1500 is 1100 watts.
randyc1 likes this.
chalugadp is offline
Old 05-24-2014, 06:19 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Sibuna is offline
Old 05-24-2014, 06:21 PM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
Hell, wire them both on one channel and preorder 2 more.
JohnDean is online now
Old 05-24-2014, 11:45 PM - Thread Starter
abuwow's Avatar
Thanks for the replies. I think I will plan to build a couple full martys. But I still like the idea of both in the corner in the same box like notnyt has, but unsure if I can pull it off with what I have or if the martys would perform better for me. The corner is also where my subs always sound the best and where I have the most room also.
Should I plan to run in series one sub per channel for 4 ohm or would it be safe or wise to run bridged for 2ohm?
Would it be worth while adding 2 more sub on same amp? The long term goal was to maybe get another 3000dsp and 2 more subs, but if I could just add speakers and make a worth while addition I guess that would be pretty nice.
abuwow is offline
Old 05-25-2014, 09:37 AM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
You cant add 2 more SI 18 with the NU3000, you would need another Amp
randyc1 is offline
Old 05-25-2014, 12:29 PM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
I thought the nu3000 would do 2ohm stereo. If so 2 18d2 on each channel would work. Am I missing something?
Old 05-25-2014, 02:13 PM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Yes the NU3000 can do 2x 1500W @ 2omhs,.... the problem is with 2 18D2 on each channel they would be UNDERPOWERED. Each Si18 need 1500,W.. (in reality it's 1100W on the NU3000) ,which is perfect for 1 SI18 @ 2 ohms ,..and with 1 DVC D2 you cant get 2 ohms , either 1 ohm or 4 ohms ?
Only a single (DVC D4 )can be wired for 2ohms , each 4 ohm coil wired in parallel for a total of 2 ohm.
Kinda confusing i know?
randyc1 is offline
Old 05-27-2014, 10:20 PM
saginawjuggalo's Avatar
Quoted: 47 Post(s)
Liked: 51
You will be fine running 2 per channel even if underpowered. I know the iNuke 3000 puts out less than the EP4000, but try it first before buying another amp. You have nothing to lose. I started with 2 SI HT 18 D2's (4.0 cu ft sealed / wired into 4ohm) off an EP4000 and noticed a nice upgrade when going to 4 18's (2ohm per channel). Gaining around 300RMS each and the extra displacement made a nice noticeable difference. I think this would keep a lot of people happy. When I feed all 4 @ 650RMS each I noticed another nice step up.
I now run 8 D2's off 2 EP4000's, They see a bit less then 500RMS each and absolutely punish my home and move the cones nicely excursion wise (during low Hz).
^Those are give or take tested watts. Not the inflated watts Behringer rate their amps at.
I tested things in a 3600 cu ft open L-shaped basement. My personal opinion is you should have more firing power for a 6000 cu ft room. Especially if you don't have the low frequency reinforcement concrete basements offer.
Since you want the lowest frequency, multiple sealed and lots of watts! If that's beyond your budget, start with 4 18's in HUGE ported enclosures.
BTW: If Infinite Baffle is possibility you would save a bunch of $ not needing box materials. Not to mention you only need a fraction of power! More $avings smile.gif Testing is order to know if the location provides a good frequency response at you your listening position. Nothing like nulls taking all the fun out of it. I hate hearing about Integration problems after installs.
Multiple sealed boxes are great because you can easily move them around your room and naturally flatten frequency response. I can fit my 4.0 cu ft boxes in a lot of locations.
abuwow likes this.
JVC DLA-RS40 w/003 lamp,DIY False-wall 125" acoustically transparent screen,Darbee Darblet,Sanyo PLV-Z2000 (gaming),7.1 DIYSoundGroup 1099 x3 LCR & Slanted Volt 6 rears x4,Onkyo TX-NR818,Emotiva LPA-1,Behringer EP4000 (x2),Sealed Stereo Integrity HT18"s (x8),Balanced MiniDSP,Cross·Spectrum UMIK-1,DIY Acoustic Treatments,PS3,Sony BDP-S590,Seiki SR4KP1 Region Free BDP,Toshiba HD-A1,Roku,Outdoor Antenna,APC H15 power conditioner,Harmony Smart Control,Rebuilding*HTPC,Leather Theater seating etc.
saginawjuggalo is offline
Old 05-28-2014, 08:46 PM - Thread Starter
abuwow's Avatar
Nice, thank you guys for the help, I think I'll plan to build full size martys and run 4ohm for now and probably change things up this winter.
abuwow is offline
