How does everyone measure their DIY builds and ensure they did it right, and they are perfect ? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1 of 47 Old 05-27-2014, 02:48 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Advice ? Is there a sticky or thread that explains the total process for a noob ?
Mfusick is offline
post #2 of 47 Old 05-27-2014, 02:57 PM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
Rew.
datranz is offline
post #3 of 47 Old 05-27-2014, 02:57 PM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1726
I'd tell you but you're yelling at me.
Ryan
tuxedocivic is offline
post #4 of 47 Old 05-27-2014, 03:11 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Sorry biggrin.gif how's that ?
Mfusick is offline
post #5 of 47 Old 05-27-2014, 03:30 PM
Liked: 1726
Ha, no problem.
What are you trying to measure? Sub or speaker?
Ryan
post #6 of 47 Old 05-27-2014, 04:57 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Speaker
Mfusick is offline
post #7 of 47 Old 05-27-2014, 05:38 PM
Liked: 1726
If you can go outside, then put the speaker on a 8' ladder well away from the house. Do a sweep in REW (or what ever program you like). Done.
If you can't, then place the speaker on the floor of the biggest room in the house. Keep it as far from walls as possible. Couches too. Put the mic on the floor 3ft away. Tip the speaker forward such that the tweeter is on axis with the microphone. Set the winow/gate at 5ms in your measurement program like REW. Take a sweep in REW (or what ever program you like). Now, the response will be high in the low end and sensitivity will be off. But to confirm the speaker is working/ hooked up right, this doesn't matter.
Now that you have your sweep, you could post it here and get comments. But you'll know something isn't quite right if there is a big null at the XO, or there's a sensitivity mismatch between the tweeter and woofer. Then you know something is up. Any odd peaks or dips greater than 5db above 400hz should also be considered.
Another excellent step is to measure the impedance, but not many people have this capability.
Good luck.
Ryan
post #8 of 47 Old 05-27-2014, 07:41 PM
Bill Fitzmaurice's Avatar
Liked: 4631
To get a standard half-space result with a full range cab take it outside well away from buildings. Take a ground plane (the mic an inch off the ground) measurement from 2 meters or more distance. That gives you half-space below the baffle step frequency. Put the cab on its back, suspend the mic the same distance as before above the cab. That gives you the half-space result above the baffle step frequency. When you superimpose the two plots you'll see where they intersect in the lower midrange. Splice the two at that frequency for a full range half space result. With a sub just do ground plane, as the baffle step frequency will be above the nominal 100Hz bandwidth.
Bill Fitzmaurice is online now
post #9 of 47 Old 05-27-2014, 08:20 PM
Liked: 1726
That seems overkill for a rookie just looking to confirm his wiring.
Ryan
post #10 of 47 Old 05-27-2014, 08:28 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Yes. I use Bill or tux's methodology depending upon the design. I've also done some on my 2nd story verandah, speaker facing out and mic on an outrigger, so no boundaries for 15m out and about 12m to the ground. The new mains are too tall to do on the verandah so I'll do them in the yard.
A9X-308 is offline
post #11 of 47 Old 05-28-2014, 03:17 AM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
The Audyssey 2EQ in an Onkyo 717 will indicate if a speaker is wired out of phase.
This video demonstrates how to test for phase using a 9v battery. I used it with the battery touching the binding posts, so I could see if the phase was correct all the way through the cross over.
https://www.youtube.com/watch?v=xIMHGkxw72o
wvu80 is offline
post #12 of 47 Old 05-28-2014, 09:00 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Good luck.
I just need to learn REW and get a proper mic I guess.
Mfusick is offline
post #13 of 47 Old 05-28-2014, 09:36 AM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
I've wondered about this as well. One of the nagging concerns I have about DIY is making a wiring mistake and never knowing the difference.
Mfusick likes this.
The Plains Theater Has Begun
J_P_A is offline
post #14 of 47 Old 05-28-2014, 09:46 AM
Liked: 4631
If you're serious enough about your sound to be building your own you should be serious enough about it to have measuring tools. With the abundance of freeware and a USB mic coming in at $100 or so there's really no excuse not to.
Mfusick, J_P_A and asarose247 like this.
post #15 of 47 Old 05-28-2014, 10:27 AM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
No argument there. My only concern is not knowing everything at the beginning. I'm afraid I will measure my speakers, but have errors either in my speaker connections, my measurement setup, or in my measurement interpretation because I'm still learning. The last of those can be handled by simply posting my results here and asking for help. The other two I'm still concerned could cause problems that will be more difficult to uncover.
Learning is part of the fun, and I'm certainly planning to build, measure (I have a calibrated mic, already), tweak, verify, etc. But I have concerns none the less.
J_P_A is offline
post #16 of 47 Old 05-28-2014, 01:10 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
With a little caution in regards to connecting your amp to a shorted load and driving a tweeter with no high pass, you're safe. The rest of it is more subtle and can be worked out posting here and comparing to the designer's measurements. You won't be able to have opposing faults that accidentally result in linear response, so real problems will be evident.
Mfusick likes this.
HopefulFred is offline
post #17 of 47 Old 05-28-2014, 07:33 PM
Cortga's Avatar
I just started making measurements myself and am learning by doing, so far I have only done in room measurements and am satisfied with the results. If you built a crossover that someone else designed have some one else double check your wiring or post pics with the schematic. But if they sound good to you, just enjoy
Cortga is offline
post #18 of 47 Old 07-22-2014, 11:13 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I'm still a little nooby at understand REW. Is there a good tips and cheats list or thread?
Mfusick is offline
post #19 of 47 Old 07-22-2014, 11:45 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Bassment is offline
post #20 of 47 Old 07-22-2014, 12:51 PM
chadcj7's Avatar
Quoted: 58 Post(s)
Originally Posted by Bassment View Post
Here's an easy guide to follow. The basics of REW is really not that difficult. https://dl.dropboxusercontent.com/u/...101%20v3.7.pdf
what is a good mic for testing? Also will the mic work for both speakers and sub testing?
chadcj7 is offline
post #21 of 47 Old 07-22-2014, 12:56 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Dayton UMM-6 or miniDSP umik. Works for both speaker and sub measurements.
Bassment is offline
post #22 of 47 Old 07-22-2014, 05:33 PM
Samps's Avatar
Quoted: 788 Post(s)
Liked: 416
IMO the hardest part of rew was getting the asio driver to send multichannel sound to the avr. It took quite a bit of tinkering with the PC sound settings and relaunching rew to get it to stick. Other than that, if you can operate this forum rew will be simple.
Samps is online now
post #23 of 47 Old 07-22-2014, 06:20 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
You get the sub today ?
chalugadp is offline
post #24 of 47 Old 07-22-2014, 06:28 PM
notnyt's Avatar
Quoted: 2155 Post(s)
Liked: 1982
umik1 from csl, imo
notnyt is offline
post #25 of 47 Old 07-22-2014, 06:40 PM
Samps's Avatar
Quoted: 788 Post(s)
Liked: 416
Tracking says tomorrow. Hoping my wife stays home to sign for it. I'll keep you updated.
I Agree on the umik1. Hooked it up and worked straight out of the box with the cal file on a flash drive.
Wish it had a longer cord though. Finding long hdmi cables is tough. I'd rather use a 6 foot hdmi and a long USB.
Samps is online now
post #26 of 47 Old 07-22-2014, 06:57 PM
asarose247's Avatar
Quoted: 696 Post(s)
Liked: 451
Not too long ago I had similar cabling/positioning issues.
Kbarnes suggested that up to a 10' extension on the usb cable for the mike was acceptable.
problem solved.
Mfusick likes this.
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #27 of 47 Old 07-22-2014, 08:37 PM
mhutchins's Avatar
Quoted: 82 Post(s)
Liked: 95
How does the role of a calibrated sound level meter such as the Galaxy Audio CM-140 differ from the role of a calibrated microphone such as the MiniDSP UMIK-1 for testing speakers and rooms? I'm ready to take the next step and improve my measurement skills and purchase the right tools for the job.
Mike
mhutchins is offline
post #28 of 47 Old 07-22-2014, 09:01 PM
notnyt's Avatar
Liked: 1982
Mike
something like umik1 doesn't need to go through audio interfaces which may have rolloff or other issues. Also, very simple to setup and work with.
notnyt is offline
post #29 of 47 Old 07-22-2014, 09:16 PM
mhutchins's Avatar
Quoted: 82 Post(s)
Liked: 95
So if I get a CSL-calibrated miniDSP UMIK-1 microphone, I won't need a sound level meter?
post #30 of 47 Old 07-22-2014, 09:46 PM
notnyt's Avatar
Liked: 1982
If you want the spl levels to be accurate, yes, you'll need an spl meter to calibrate the level. The other solution is to get an omnimic kit.
notnyt is offline
