DIY: Build the SumpSub Ported Passive Subwoofer - Page 3 - AVS Forum
post #61 of 79 Old 06-03-2014, 06:44 PM
dnoonie's Avatar
Liked: 38
Originally Posted by iontyre View Post
For some reason, that picture of the four of them causes me to keep thinking the phrase 'Exterminate!" in my head... Just add a plunger sticking out the front and you got some nice functional Doctor Who props for a themed theater space!
Honestly, you should feature them and have different themes.  Have some friends over for a theme movie, Star Wars, Dr. Who, and dress them accordingly.  Would they make a good Cousin It with some long hair and a hat?
dnoonie is online now
post #62 of 79 Old 06-04-2014, 11:50 AM
McLuvin's Avatar
It seems very clear to me that you are either not married or have one of the coolest spouses ever. Nice job...
McLuvin is offline
post #63 of 79 Old 06-05-2014, 10:23 AM
morbidcorpse's Avatar
Quoted: 13 Post(s)
Liked: 41
Not really sure if this is kosher, but if some of you are looking for good drivers for this project at a reasonable price, I'm trying to unload some here http://www.avsforum.com/t/1534582/boston-acoustics-12-subwoofer-drivers
morbidcorpse is offline
post #64 of 79 Old 06-05-2014, 02:26 PM
Xanadu376's Avatar
Newbie question: How are you powering this? Do you need something special? All I have is a receiver. So I assume I'd need a separate amp for it.
Xanadu376 is offline
post #65 of 79 Old 06-05-2014, 02:39 PM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Quoted: 707 Post(s)
Liked: 1733
Yes it is a passive sub design with no built-in crossover, therefor it requires an external amp. I use a Crown XTi-2002.
Find out more about Mark Henninger at www.imagicdigital.com
imagic is offline
post #66 of 79 Old 06-05-2014, 03:28 PM
notnyt's Avatar
Quoted: 83 Post(s)
Liked: 338
Originally Posted by imagic View Post
Regarding resonance, here's RTA of a 16Hz sine wave playing through four SumpSubs, from my main listening position...
little late here, but might want to use hann windowing.
notnyt is offline
post #67 of 79 Old 06-05-2014, 03:38 PM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Quoted: 707 Post(s)
Liked: 1733
The learning process continues... thank you.
imagic is offline
post #68 of 79 Old 06-05-2014, 03:39 PM
notnyt's Avatar
Quoted: 83 Post(s)
Liked: 338
np, just gives you a flatter output. You'll see immediately when you toggle.
notnyt is offline
post #69 of 79 Old 06-05-2014, 05:41 PM
DS-21's Avatar
Quoted: 48 Post(s)
Liked: 160
i'm kind of surprised by your comment ds-21. maybe the resonances that you were picking up were not the port, but internal standing waves.
Doubtful. i've never built or been involved with a sub that wasn't properly damped. At the time it was fiberglass (polyfill, as Ken Kantor showed, isn't worth much) but today I use Ultratouch because it works about as well and doesn't make me itch.
ithere are countless folks running subs with port resonances in the range that you say would be a "fail" and i can't recall even a single instance of anybody identifying it as a problem.
I've personally heard it in a several instances. I've also heard it go away with the same driver, same cabinet size, and PRs instead of a port.
maybe the issue is a combination effect where you won't want the subwoofer tuned low AND playing in the passband where the first port resonance is?
Or just avoid the issue altogether by either staying sealed or using passive radiators.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
Multichannel music (and video) urban loft living room system
DS-21 is offline
post #70 of 79 Old 06-06-2014, 08:28 AM
cw5billwade's Avatar
Quoted: 51 Post(s)
Liked: 95
passive radiators? is that like a driver but not hooked up? I think I saww that some where but can not remember where.
cw5billwade is offline
post #71 of 79 Old 06-06-2014, 09:03 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 139 Post(s)
Liked: 349
Same as a driver, minus the voice coil and magnet assembly. http://en.wikipedia.org/wiki/Passive_radiator_(speaker)
Mike Garrett, AV Science Sales
Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Stewart, Seymour, SE, SI & many more.
Klipsch, RBH, Martin Logan, Triad, Atlantic Technology, MK Sound, BG Radia, SVS & Def Tech.
AV Science Sales 5 is offline
post #72 of 79 Old 06-06-2014, 09:13 AM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Quoted: 707 Post(s)
Liked: 1733
...and usually tuneable by adding/removing weights...
imagic is offline
post #73 of 79 Old 06-08-2014, 10:19 AM
NewtownTheater's Avatar
Originally Posted by DS-21 View Post
Really cool idea, Mark!
Four points:
1) One mistake people often make in simulations is not including the effect of vent resonances. Large vent resonances an octave or two above the sub's nominal passband are an issue with EBS (or, as sometimes referred to in forums, "LLT") alignments, and they are IMO very deleterious. (For music, at least. For movies one can probably get away with an EBS alignment.) If the software you use isn't sophisticated enough to simulate vent resonances, I'd recommend using the tried and true (and free) Unibox sheets for MS Excel. (As an aside, the lack of such resonances is a big reason why subs in EBS alignments generally sound better when tuned with passive radiators instead of ports. PR's don't help here, because where would they go? Also, good - long throw, high Qm - passive radiators are expensive.)
2) I'd highly recommend any new builders ditch the binding posts and use a better speaker connector. The Neutrik SpeakOn is simply superior to consumer-style binding posts in every single way: they're sealed, positive-locking, quick disconnect, insulated, etc. And...they're generally cheaper than binding posts and bananas, too! Available at any pro audio shop, Parts Express, Amazon, etc.
3) Your comment about "boxy" sound from cube subs is without basis in reality. If a small cube sub sounds boxy, that is probably because it has too high a Q. The shape of the sub has basically no impact on its performance. Obviously, in any loudspeaker one will want to damp the internal reflections with foam as you did here, or recycled denim insulation (my preference), fiberglass insulation (the most effective, but a pain to use), etc.
4) One should be aware that horizontal mounting (or even storage!) significantly shortens the lifespan of a driver. I've seen Klippel measurements of drivers that have been used horizontally for a long time. The compliance curves look very different from the same drivers new. In a sealed sub, that's not a huge issue. The upper bass with get a little more plummy (higher Q) and the overall output limits will lower over time. But in a vented sub, that means the cabinet will likely be mistuned if it is used for a long time. So if possible, if one is using SumpSubs, Sono-subs, etc. behind a screen, it's better to lay them down than stand them up.
My goal is to someday understand what in the heck all the above means. And oddly enough my friends call me the electronics/home theater wizard...
That's wasn't flying... That was falling with style!
NewtownTheater is offline
post #74 of 79 Old 06-10-2014, 02:07 PM
Augerhandle's Avatar
Liked: 47
Interesting project. Love the ingenuity....would be nervous about the WAF.
Great reference!
I was thinking along the same lines... The MacGyverSub
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
Augerhandle is offline
post #75 of 79 Old 06-17-2014, 06:16 AM
dsully444's Avatar
I am curious if there is a way to take this well documented DIY, thanks for the infor, to have the sub inside of the box to be buried for outside application to add some oomph to my pool music. This is the first DIY I have seen that uses materials for the enclosure that would actually work. Thoughts, can this build be adjusted to somehow put the sub in the enclosure?
dsully444 is offline
post #76 of 79 Old 06-17-2014, 03:56 PM
dnoonie's Avatar
Liked: 38
There is the compound/band pass design that puts the speaker inside the enclosure.
Also I've seen Transmission Line (aka Boss Wave {no they didn't invent it}) designs that also put the speaker inside rather than outside in a kind of compound/band pass design combined with a Transmission Line design.
Back when I was DIYing my own speakers Old Colony Sound Labs had a publication called Speaker Builder which was a great resource. What has replaced that?
Another great resource I used was the Loudspeaker Design Cookbook, not sure it it's as well regarded as it was but I don't consider most any resource all encompassing so...it's still around on Amazon.
Cheers
post #77 of 79 Old 06-21-2014, 05:45 AM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Quoted: 707 Post(s)
Liked: 1733
Originally Posted by Augerhandle View Post
Quote:Originally Posted by TMcG
User name change..... iMagic to iMacGyver
Great reference!
If WAF is an issue, it's a perfect excuse to pitch an acoustically-transparent front projector screen rig!
imagic is offline
post #78 of 79 Old 06-21-2014, 05:49 AM - Thread Starter
Senior Writer @ AVS
imagic's Avatar
Quoted: 707 Post(s)
Liked: 1733
I'm curious too, I'll look into it. It would have to be some kind of bandpass/T-line sub design, as @dnoonie mentioned. The main challenge is finding a plastic disc that fits between the two halves.
imagic is offline
post #79 of 79 Old 06-23-2014, 11:31 AM
dnoonie's Avatar
Liked: 38
This just came up on my side bar adds on this forum, http://www.amazon.com/dp/B004MUFHUM/...5f97aba2c9cbda
I was looking for some inexpensive plastic that might work but the ad 'bots found it before I could, go figure.
If I understand your dimensions correctly....The .118 24" x 24" is $20, .236 24"x24" is $30. Not too bad but it requires cutting. I've free hand cut quit a few speakers spacers from MDF with a jig saw, towards the end I got a nice circle cutting device, now they have great circle cutting devices (jigs with holders and everything) that attach to a hand drill.
This is not as simple as finding something already the right shape. Sometimes it works best to just wander through the hardware store, or maybe the sump pump industry has some handy shapes to help out...How about a basin cover, http://www.sumppumpsdirect.com/pumps...in-covers.html, http://www.sumppumpsdirect.com/TOPP-C18WPE/p13769.html, I'd have to look at it. If you're lucky it could bolt through both basins with the basin cover in the middle.
Cheers
Crown Audio Xti 2002 475w Stereo Power Amplifier 20hz To 20khz Frequency Response 1 4vrms Input Sens
