Video Subwoofer Build - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Video series a good idea
Yes 72 97.30%
No 2 2.70%
Voters: 74. You may not vote on this poll
 21Likes
post #1 of 53 Old 06-06-2014, 12:25 PM - Thread Starter
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1532
Minimarty Video Subwoofer Build
After building many Martysub enclosures I decided to make a video thread of my latest one, which is the minimarty. You would follow the same steps if you were building the martycube or full marty. I decided on the minimarty because I wanted to match my other one I already built. This one is horizontal (my center channel sits on top of it) and my other one is vertical. I like the minimarty since it has virtually the same performance of the full marty and its 8" shorter.
I was in a big rush in putting this box together so its not a hollywood production. Basic camera angles but it is in HD. I have uploaded all the videos to Youtube and I will give the links below. I have the hole 3 hour plus build in one video and the 15 individual vids broken down so if your only interested in finishing you can watch just that. All but about 45 mins of the build is on the videos to see. Some boring sanding I didn't show. Post two has all the cut sheets, drawings, and info for Martysubs. I hope this is a benefit for people just starting out and don't have a lot of experience. A couple of pics of finished minimarty
The wood I use is ultralite 3/4" mdf. The place I buy it from (Windsor Plywood in Canada) cuts it down to 4 equal pieces for me for free. That way I can bring it home in my car.
Here is the videos
Whole 3 hour plus video
Intro
Cutting Pieces
Assembly
Bracing
Foam & Silicone
Front Baffle
Attaching Top
Belt Sanding
Veneering
Rabbet Edge in Oak
Filling & Sanding
Finishing
Speakon Connector
Installing Driver/Cable
SPL
LTD02, hogues, nube and 13 others like this.
chalugadp is offline
post #2 of 53 Old 06-06-2014, 12:25 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
Here is minimarty cutlist for horizontal
And vertical
Here is a list of some of the types with a graph below showing spl.
1) Full Marty (Green in graph) 2' by 2' by 4' ~ 17hz tuning in 11cuft box (1100 watts)
2) MiniMarty (Green in graph) 2' by 30" by 36" ~17hz tuning in 10cuft box (1100watts)
MiniMarty (Green in graph) 2' by 2' by 40" ~17hz tuning in 9cuft box (1100watts)
3) Martycube (Black in graph) 2' by 2',by 2' ~20hz tuning in 5 cuft box (1100 watts)
4) Just for fun the blue line in graph is 4cuft sealed sub (1100 watts)
5) Just for wows is the red line which is Martycube with Uxl18 driver (2200 watts)
Drivers
For the below graph the driver is Dayton Audio RSS460HO-4 18" (except for red)
Other drivers that work are :
SI 18, uxl 18, as well as si 15 and ixl 18
Cutlist
Here is an instructional guide to building the Cube
I just finished a minimarty for my room
Here's a comparison of mini marty vs cube in my room
15hz full marty +5 dbs
20 hz full marty +3.5
30hz full marty +2
40hz full marty +0.8
50hz Cube +1.2
60hz Cube +2.2
70hz Even
80hz Even
90hz Even
Some pics of various Martycubes
Accessories
$11 RCA Cable (which I had previously for the klipsch subs)
http://www.amazon.com/gp/product/B003FVVMS0/ref=oh_details_o08_s01_i01?ie=UTF8&psc=1
$5 RCA to XLR converter
http://www.amazon.com/gp/product/B000068O4D/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1
$13 Speakon cable for each sub
http://www.amazon.com/gp/product/B000E1U4WY/ref=oh_details_o02_s00_i01?ie=UTF8&psc=1
$2.59 Speakon Panel Mount for connecting amp to subs:
http://www.amazon.com/gp/product/B00067JSFK/ref=oh_details_o01_s00_i03?ie=UTF8&psc=1
$8 Speaker Gasket Tape
http://www.amazon.com/gp/product/B0002ZPLPW/ref=oh_details_o01_s00_i02?ie=UTF8&psc=1
$2 Rubber Feet
http://www.amazon.com/gp/product/B002N5VYRI/ref=oh_details_o01_s00_i01?ie=UTF8&psc=1
$10 Acoustic Foam
http://www.amazon.com/gp/product/B0002ZPLP2/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
Tools
$30 Nail Gun
http://www.amazon.com/gp/product/B000EJW1ZY/ref=oh_details_o02_s00_i02?ie=UTF8&psc=1
$40 Jasper Jig (for cutting cirlces)
http://www.amazon.com/gp/product/B00009K77A/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
$9 Assorted Nails from 1" to 2"
http://www.amazon.com/gp/product/B00004YZQQ/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
For wiring up the subs go here and use the wiring wizard
http://www.the12volt.com/caraudio/wo...?Q=&I=#results
Speaker Cutouts
For Si18,dayton 18ho, and uxl18, inside diameter needed is 16.75"
Outer diameter for flush fit for si18 is 18 7/16" and for uxl 18 its 18.5"
Using Limiter in 4ohm bridged for inuke amp
93.8Vp is 1099.8 watts in 4ohm bridged mode
105.8 on 4ohm load is 1399.2 watts
Erich H likes this.
post #3 of 53 Old 06-06-2014, 12:44 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
This is a great idea I'm sure it would help tons of people.
JWagstaff is offline
post #4 of 53 Old 06-06-2014, 12:52 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
If you build it they will come....do it!
lovinthehd is offline
post #5 of 53 Old 06-06-2014, 12:55 PM
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
Perfect timing I think because I just decided to build two minis for myself. It'll be my first diy endeavor.
Will you release videos as you go or all at once at the end?
in3rtia is offline
post #6 of 53 Old 06-06-2014, 01:00 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
All at once. I'm pretty speedy in my builds. Start to finish in 4 to 5 days.
post #7 of 53 Old 06-06-2014, 01:08 PM
Rebel975's Avatar
Quoted: 21 Post(s)
Liked: 127
I wanted to vote "no" just to be different. But, Darth Vader came from the planet Vulcan and said that he'll melt my brain if I do, so I didn't have a choice. I voted "yes".
mbyrnes and zencarver like this.
Rebel975 is offline
post #8 of 53 Old 06-06-2014, 01:21 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
Originally Posted by Rebel975 View Post
I wanted to vote "no" just to be different, but Darth Vader came from the planet Vulcan and said that he'll melt my brain if I do, so I didn't have a choice. I voted "yes".
never done a poll question but its kind of lame(my question). If people have some requests for stuff they want to see let me know. I won't guarantee i will do it, but I will think about it. I just need to find a camera that takes off 30 pounds of my appearance eek.gifsmile.gifcool.gif
post #9 of 53 Old 06-06-2014, 01:48 PM
Dank1209's Avatar
Donny thanks for the time u spend on the many articles. On this forum. U are very helpful .I think the video would be an outstanding idea
Dank1209 is offline
post #10 of 53 Old 06-06-2014, 02:02 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
thanks, we all were noobs at one time
artyusmce likes this.
post #11 of 53 Old 06-06-2014, 02:05 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
I'm looking forward to seeing the veneer and finishing portion of the videos
Fattykidd is offline
post #12 of 53 Old 06-06-2014, 02:08 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
Going to use my watco oil and polyurethane. Haven't decided what veneer to use. Maybe black walnut , teak, or ...
post #13 of 53 Old 06-06-2014, 02:11 PM
wlhungdude's Avatar
Quoted: 191 Post(s)
Liked: 238
Get with a realtor. They have cameras that make crappy houses look great in pictures. rolleyes.gif
Dank1209 likes this.
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #14 of 53 Old 06-06-2014, 02:39 PM
Dank1209's Avatar
Dank1209 is offline
post #15 of 53 Old 06-06-2014, 02:59 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
If she looks like this
post #16 of 53 Old 06-06-2014, 03:47 PM
kevings's Avatar
Quoted: 299 Post(s)
Liked: 466
Good idea Donny... It would help out people new to diy, for sure.
Also make the girl u posted your assistant, in that same outfit..
She can hand you tools as u need them, etc.
U do the above, and every man in the world with an internet connection, might end up with a Marty sub:)
kevings is offline
post #17 of 53 Old 06-06-2014, 04:42 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
Bombelman likes this.
post #18 of 53 Old 06-06-2014, 05:07 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Start to finish no edits would be sweet
Mfusick is offline
post #19 of 53 Old 06-06-2014, 06:38 PM
kevings's Avatar
Quoted: 299 Post(s)
Liked: 466
kevings is offline
post #20 of 53 Old 06-09-2014, 08:35 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
Ok starting this tomorrow,
I need the driver on the end and the port going up. This box is sitting right beneath my center channel. Sizes are a little different cuz I am using ultralight mdf which mine is 11/16"
post #21 of 53 Old 06-09-2014, 10:21 PM
cessna1466u's Avatar
Quoted: 117 Post(s)
Liked: 204
Donny, the Sub Box Builder! (Said the same as Tim The Tool Man Taylor) and Pamela Anderson can be your tool girl. She knows about woofers....eek.gif
cessna1466u is offline
post #22 of 53 Old 06-09-2014, 11:32 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
my quick math shows about a 10 cubic footer tuned to around 13hz.
is that what you are shooting for?
the first port resonance is going to be pretty low, about 120 hz. might not want to go that low...
38 inches of total measured port length should tune it to ~15hz and push the first port resonance up to around 180hz.
Listen. It's All Good.
LTD02 is offline
post #23 of 53 Old 06-09-2014, 11:48 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
Even with 2" instead of 3" high port ? Original Marty is 3" by 36" for 17hz. If I went to 2" high I thought I would have to make it a lot longer. If not I will reduce length. Thanks for spotting it smile.gif
post #24 of 53 Old 06-10-2014, 10:29 PM
LTD02's Avatar
Liked: 2888
sorry for not seeing this earlier.
when the port is WIDENED, it needs to be LONGER for the same tune.
when the port is NARROWED, it needs to be SHORTER for the same tune.
LTD02 is offline
post #25 of 53 Old 06-12-2014, 08:47 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Who voted no lol...?
Mfusick is offline
post #26 of 53 Old 06-14-2014, 06:24 AM
Wumpscut223's Avatar
I vote for a bikini clad assistant.
Wumpscut223 is offline
post #27 of 53 Old 06-14-2014, 09:56 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I'm looking forward to this
Mfusick is offline
post #28 of 53 Old 06-14-2014, 10:00 AM - Thread Starter
chalugadp's Avatar
Liked: 1532
First coat of spray lacquer
I'm just going to piece together the video clips into categories. No editing, its not Hollywood
charvel74 likes this.
post #29 of 53 Old 06-14-2014, 11:24 AM
MDST's Avatar
Quoted: 32 Post(s)
Awesome good idea for those who're ( like me ) in other countries and have the opportunity to build such impressive boxes.
MDST is offline
post #30 of 53 Old 06-15-2014, 04:43 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
I have finished Video series. Post one updated and ready to be viewed. I put cut lists and all Martysub info in post two. I hope this can become the new area for general martysub chatting in DIY section.
artyusmce and lovinthehd like this.
