Dual Ultimax 12" - First time builder - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By LTD02
  • 1 Post By bombertodd
  • 1 Post By Mrkazador
post #1 of 22 Old 06-10-2014, 08:58 PM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
I'm going to build my first set of speakers, a pair of Dayton Ultimax 12" with Parts Express knockdown cabinets for my living room. I'm going to power the pair with a inuke 3000 dsp amp. I'm building my shopping list right now and have a few questions.
1) I have a Denon AVR that will feed the amp via RCA. How do I hook up the amp? (RCA ---> XLR) or (RCA ----> Y-splitter ----> two XLR's)
2) When connecting the amp to the subs, do I just connect them with a speakon cable? Do I need the 2 pole or 4 pole connectors?
Thanks, I'm sure I'll have more questions as the project progresses.
Klipsch RF-82II, RC-62II
2x Dayton Ultimax 12, Behringer iNUKE3000DSP
Denon 2113ci
New Theater Under Construction
bombertodd is offline
post #2 of 22 Old 06-10-2014, 09:24 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I'm not real familiar with the inuke but I think it has a biamp mode where you can input with one signal and output two so you wouldn't need a splitter. If you're doing stereo subs then 2 pole is fine. 4 pole is needed when you bridge the amp.
Mrkazador is offline
post #3 of 22 Old 06-12-2014, 09:49 AM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
Thanks, searching for inuke biamp connections turned up a picture that was much more helpful than reading the manual.
http://www.hometheatershack.com/foru...nnections.html
Denon 2113ci
post #4 of 22 Old 06-20-2014, 05:25 PM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
Most of my stuff has came in. I started gluing the flatpacks together with Titebond 2 and clamps. Do I need to seal the cabinets? If so, with what?
Denon 2113ci
post #5 of 22 Old 06-20-2014, 06:15 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
If you properly glued the cabinet, there won't be any leaks.
post #6 of 22 Old 06-21-2014, 03:02 AM
LTD02's Avatar
Quoted: 2336 Post(s)
Liked: 2563
missed your post the first time through.
the inuke needs a splitter before the amp.
in other words, you must have a separate input for each channel going into the amp if running one sub off of each channel.
bombertodd likes this.
Listen. It's All Good.
LTD02 is offline
post #7 of 22 Old 06-21-2014, 08:28 AM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
Thanks LTD. Any benefit form spitting the RCA or the XLR? Or just get what's cheapest?
Code:
RCA ---> RCA ---> XLR ---> AMP
     \--> RCA ---> XLR ---> AMP
      OR
RCA ---> XLR ---> XLR ---> AMP
             \--- XLR ----> AMP
This represents a splitter:
Denon 2113ci
post #8 of 22 Old 06-21-2014, 10:33 AM
Anthony_Gomez's Avatar
Quoted: 61 Post(s)
Liked: 184
Can you use the inuke itself as a splitter, taking channel A input and run it mono to both A/B outputs?
Anthony_Gomez is offline
post #9 of 22 Old 06-21-2014, 10:58 AM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
Anthony, I've been trying to figure this out. I've read yes and no on the forums and the instruction manual is not clear (to me).
I'm still a little green when it comes to terminology. I've been reading until my eyes bleed but somethings are still muddy in my head.
EDIT:
Here's the manual if anyone wants to take a peek:
http://www.behringer.com/assets/NU60...00DSP_M_EN.pdf
Denon 2113ci
post #10 of 22 Old 06-22-2014, 10:30 AM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
Here are some pictures so far. The cabinets are very easy to build. I have very little wood work experience and these were fun to build. I still have to install the front piece and attach the baffle. I also decided on the green faux leather for the cabinet with a black painted from.
EDIT:
I need to get the real camera out, these cell phone pics kinda stink.... sorry!
ID:	130930   Click image for larger version
ID:	130938   Click image for larger version
ID:	130946   Click image for larger version
ID:	130954   Click image for larger version
Denon 2113ci
post #11 of 22 Old 06-22-2014, 10:59 AM
LTD02's Avatar
Liked: 2563
"Can you use the inuke itself as a splitter, taking channel A input and run it mono to both A/B outputs?"
not in the way that most folks want to use it.
a splitter is required to send an input into each channel.
LTD02 is offline
post #12 of 22 Old 06-22-2014, 02:37 PM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
I stuffed both boxes with a pound of Polyfill each. I'm going to add a screen to keep it out of the driver. Probably the only thing I'll get done this weekend... Stupid homework... Hopefully tomorrow I can cut and router the countersink holes for the speakon connectors.
Denon 2113ci
post #13 of 22 Old 06-22-2014, 02:46 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I would line the walls with thick insulation or polyfill if you can. The driver has a high qtc in that size enclosure according to winisd so a heavy fill can bring that down a bit.
post #14 of 22 Old 06-22-2014, 10:56 PM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
I added another half pound to each box, so total of 1.5 pounds per box.
I'm going to make a RCA to XLR splitter cable. I heard I should use microphone cable (whatever that is). Can I use 12 gauge speaker wire instead? Also how should I wire it up? I'm new to XLR plugs but I can solder like a champ.
Is diagram 1 possible without the shield? If not I think I'll try to make them like diagram 3 if possible. I was going to order these:
http://www.monoprice.com/Product?c_i...seq=1&format=2
EDIT:
I got this RCA to XLR madness straighten out!
Name:	rca to xlr 1.jpg
ID:	131738   Click image for larger version
Name:	rca to xlr 2.jpg
ID:	131746   Click image for larger version
Name:	rca to xlr 3.jpg
Denon 2113ci
post #15 of 22 Old 06-26-2014, 05:03 PM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
I got the faux gator leather on one box. Used Loctite 200 spray adhesive and staple gunned the bottom. I also installed some little black plastic feet I picked up at Home Depot for $2.50. I bought some rustoleum bed liner for the front baffle (that's primer on there now).
I purchased the gator material at Big Z fabric for those that are interested.
Denon 2113ci
post #16 of 22 Old 06-26-2014, 05:10 PM
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1505
Can you take a pic at a lower angle and a bit closer ? It looks good and want to see better. My wife might like this.
chalugadp is offline
post #17 of 22 Old 06-26-2014, 05:39 PM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
OK, I went and stole my wife's Cannon. No laughing at my messy garage either please....
ID:	137313   Click image for larger version
ID:	137321   Click image for larger version
ID:	137329   Click image for larger version
ID:	137337   Click image for larger version
chalugadp likes this.
Denon 2113ci
post #18 of 22 Old 06-26-2014, 05:50 PM
chalugadp's Avatar
Liked: 1505
Thanks , maybe I will do a leather finish too
post #19 of 22 Old 06-26-2014, 07:17 PM
LTD02's Avatar
Liked: 2563
that's some nice work there. uncommon and creative and a little...eerie.
LTD02 is offline
post #20 of 22 Old 06-27-2014, 02:24 PM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
Baffles are almost done being painted.
I have a question about installing the driver. How or what is the best way to drop in the driver into the cabinet without scratching the baffle?
Denon 2113ci
post #21 of 22 Old 06-27-2014, 04:55 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Loop a few zip ties in the driver mounting holes for some handles. Kite string would probably work too.
post #22 of 22 Old 06-27-2014, 06:07 PM - Thread Starter
bombertodd's Avatar
Quoted: 190 Post(s)
Liked: 95
Good idea. I didn't even think about looping something through, dropping the driver in and cutting the loop so it can be removed. The joys of doing something for the first time and all the strange questions that arise.
Denon 2113ci
