I'm retiring from AVS. New AVS upgrade sucks that BAD! - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 200Likes
post #271 of 442 Old 06-13-2014, 11:15 AM
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
No offense taken, Fatshaft. We are the 1099 bros...
DaJoJo likes this.
Nothing is what I want - a true Zen saying.
Marantz AV7005 pre/pro cheap
Bob Sorel is offline
post #272 of 442 Old 06-13-2014, 11:22 AM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
Originally Posted by lbrown105 View Post
I am still getting nothing in the tools drop down even after I cleared my cache (Chrome)
update; works on explorer but not on Chrome for me
lbrown105 is offline
post #273 of 442 Old 06-13-2014, 11:32 AM
SXRDISBEST's Avatar
Quoted: 109 Post(s)
Liked: 64
Can't post more than one picture per post on iOS.
SXRDISBEST is offline
post #274 of 442 Old 06-13-2014, 11:36 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
The mobile version of this site has really taken a downward spiral since the upgrade. I'm basically using the desktop mode on my Nexus 7 and Nexus 5 at this point, but find it painfully slower as obviously there are a lot of graphics, etc. that have to load.
The most annoying thing so far with the Mobile version is that the concept of breadcrumbs seems to have all but disappeared. I can't figure out is how to get from a post/thread back to the sub-forum? It used to be relatively simple, but now I seem to have to click on the Menu icon, then click on "Forums" (whereas before the subforum and I believe forum you were in would already be there so you could select it), then wait for the master forum list to d, then scroll back down to the forum you were in, etc.
Hopefully I'm just missing something that's right in front of me.
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #275 of 442 Old 06-13-2014, 11:41 AM
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
Hmmm...It's working on Chrome for me...
post #276 of 442 Old 06-13-2014, 11:42 AM
mrogowski's Avatar
Quoted: 153 Post(s)
Liked: 288
I got it!
Let's buy out AVS and turn it into a CO-OP. Then go with a forum software that everyone likes.
Sent from my 80-286 DOS 3.2/Windows 3.0 machine using Terminal
mrogowski is offline
post #277 of 442 Old 06-13-2014, 11:48 AM
SeekingNirvana's Avatar
Quoted: 248 Post(s)
Liked: 164
This!!
SeekingNirvana is offline
post #278 of 442 Old 06-13-2014, 11:53 AM
Administrator
Administrator
VerticalScope's Avatar
Quoted: 541 Post(s)
Liked: 139
@pbc When in a thread, there's an "Up" button at the bottom of the thread that takes you to the subforum.
VerticalScope is offline
post #279 of 442 Old 06-13-2014, 12:02 PM
Done Deal DR's Avatar
Quoted: 99 Post(s)
Liked: 146
Originally Posted by Done Deal DR View Post
When viewing the desktop site via a retina Ipad, I cannot select the 'tools' drop down list. I'm guessing I should be able to click on that and get a list of commonly used options that were easy to use on the huddle platform. I'm on many other vbulletin forums and don't have this menu drop down issue on the same iPad. Perhaps this could be looked at?
Also, why do we need to de select that sidebar? Having over 1/3rd the screen taken up by that was infuriating, that should be disabled by default instead of hidden in some random menu option as it is right now.
Overall, this isn't that bad. I'm on many forums and most of them are vbulletin. The previous huddle platform was more advanced however, and easier to use. Meh, it is what it is.
I have not seen this addressed and there's at least a few of us affected by it. Is this fixable? If not I have no way to view "threads I've posted in".
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
post #280 of 442 Old 06-13-2014, 12:07 PM
Administrator
Administrator
Quoted: 541 Post(s)
Liked: 139
@Done Deal DR Having our team check it now, sorry for the delay.
post #281 of 442 Old 06-13-2014, 12:13 PM
Quoted: 99 Post(s)
Liked: 146
Thank you! Outside of the ridiculously tiny editor which I believe is being worked on, and this, the site is more or less stable for me.
Good job with the transition, overall it's pretty smooth. I know it's a lot of work. I will miss the previous platform as it was the best I've ever seen in a forum, now it feels like all the others I'm on with a few bugs that I'm sure will be worked out with time.
post #282 of 442 Old 06-13-2014, 12:29 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 408
Not sure if this has been mentioned already, but if I go to a post of any poster, say "XYZ", click on their nym, and select "Find more posts by XYZ", the dates of all that person's posts show up as 12-31-1969, 07:00 PM. This is on desktop, Firefox Win7.
andyc56 is offline
post #283 of 442 Old 06-13-2014, 12:31 PM
Administrator
Administrator
Quoted: 541 Post(s)
Liked: 139
@andyc56 Looking - thanks for reporting it.
post #284 of 442 Old 06-13-2014, 12:35 PM
onebadmonte's Avatar
Liked: 26
I like the new upgrade.
onebadmonte is offline
post #285 of 442 Old 06-13-2014, 01:02 PM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
Edit and thumbs up are BROKEN on the mobile version! Also I keep getting kicked off and need to log back in.
AVS YOU BETTER FIX THIS!
wattheF is offline
post #286 of 442 Old 06-13-2014, 01:15 PM
Administrator
Administrator
Quoted: 541 Post(s)
Liked: 139
This issue (iPad Retina tools) should now be fixed, we've made a change that is working on our test iPad retina.
Mark
Done Deal DR likes this.
post #287 of 442 Old 06-13-2014, 01:18 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 1087 Post(s)
Liked: 827
Mark
I had a page still on my iPad that wouldn't activate the Tools button, after a refresh it worked!
You guys are crushing these at a crazy pace!
Mike Lang, Administrator
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Join the AVS Forum Club and help support the site. Help Support AVS Forum Sponsors.
AVS Forum is not sponsored by or in any way affiliated with AV Science Inc.
Mike Lang is offline
post #288 of 442 Old 06-13-2014, 01:18 PM
DDailey's Avatar
Quoted: 138 Post(s)
Liked: 129
Originally Posted by ambesolman View Post
But a pic says a thousand words bob😉
You have one of the most offensive avatar's ever! What a jerk.
DDailey is offline
post #289 of 442 Old 06-13-2014, 01:38 PM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
Thanks for getting the mouse-over on the forums header working, any way to get it to also show the sub directory or will it only show the main forums?
also can anything be done with how PMs work? sending group PMs is pretty worthless right now. if they could be made to work like threads like they did in the old forum that would be amazing
Sibuna is offline
post #290 of 442 Old 06-13-2014, 02:07 PM
Quoted: 99 Post(s)
Liked: 146
Mark
+1 Works perfect now, thank you!
VerticalScope likes this.
post #291 of 442 Old 06-13-2014, 02:27 PM
Erich H's Avatar
Quoted: 1495 Post(s)
Liked: 1906
@Erich H Which view would you want to see this on - when looking at the thread, or looking at the list of threads on a forum, or which area?
Mark
Great work getting the thread 'start date' back up.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #292 of 442 Old 06-13-2014, 02:29 PM
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
See, Mark and his team rock!! It simply takes TIME to get these things sorted out, but these guys certainly have the skills to make it happen!
post #293 of 442 Old 06-13-2014, 02:47 PM
Erich H's Avatar
Liked: 1906
Hey now, I wasn't actually complaining!
Erich H is offline
post #294 of 442 Old 06-13-2014, 02:50 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
How do I mark all threads read that I have subscriptions to ? Is this function gone ?
Mfusick is offline
post #295 of 442 Old 06-13-2014, 02:52 PM
ambesolman's Avatar
Quoted: 1100 Post(s)
Liked: 921
Tack likes this.
ambesolman is offline
post #296 of 442 Old 06-13-2014, 02:55 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
[IMG]http://www.avsforum.com/forum/attachment.php?attachmentid=114497&stc=1&d=1402696 293[IMG]
Fail. All aboard the fail boat.
You need to add "/" at the second [img] so it looks like this [/img]
Mfusick is offline
post #297 of 442 Old 06-13-2014, 03:01 PM
ambesolman's Avatar
Liked: 921
[quote=Mfusick;24947881]Fail. All aboard the fail boat.
Fixed it, Thanks! This is rediculous!
post #298 of 442 Old 06-13-2014, 03:02 PM
losservatore's Avatar
Quoted: 2676 Post(s)
Liked: 2453
Can you guys make this a little bit wider ,I use a tablet in desktop mode and I'm having trouble selecting the numbers with my finger tips.
Name:	New Imagegjhjh.jpg
losservatore is offline
post #299 of 442 Old 06-13-2014, 03:07 PM
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
Heheh...when I stressed the word TIME, I wasn't directing it at you, but rather at some of the more impatient people in this thread that have been complaining. Everything will get sorted out in TIME, and once it does, things will get back to normal around here....
You know, the regulars, the people I have gotten to know in this forum have been the most understanding...The quick to complain people are people I don't know at all, and have never read any of their posts...
post #300 of 442 Old 06-13-2014, 03:13 PM
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
A reminder...please post problems, requests, bugs, etc. here:
http://www.avsforum.com/forum/43-for...come-back.html
to make sure that it gets seen by the vB team.
Closed Thread DIY Speakers and Subs
