How to put an image in a post! - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #1 of 54 Old 06-12-2014, 08:23 PM - Thread Starter
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
Click on the image that you want to insert and a new window will pop up with the image in it. Highlight the URL in the pop up window and copy it like this:
Hope this helps some folks.
Best,
John
ID:	113049   Click image for larger version
Name:	jbrown15 mockup with 15 inch drivers.png
ID:	113081   Click image for larger version
ID:	113137   Click image for larger version
ID:	113145   Click image for larger version
ID:	113161   Click image for larger version
Listen. It's All Good.
LTD02 is offline
post #2 of 54 Old 06-12-2014, 08:25 PM
Bombelman's Avatar
Quoted: 56 Post(s)
Liked: 52
what do I paste ?
edit: the pic with the "copy" step got left out
Bombelman is offline
post #3 of 54 Old 06-13-2014, 07:39 AM
charmerci's Avatar
Quoted: 316 Post(s)
Liked: 207
But it was SO much easier before.
popalock and cardoski like this.
charmerci is offline
post #4 of 54 Old 06-13-2014, 07:52 AM
Mike Garrett's Avatar
Quoted: 7087 Post(s)
Liked: 4794
Pic test.
[IMG][/IMG]
mjgarrett100@gmail.com
Mike Garrett is offline
post #5 of 54 Old 06-13-2014, 08:01 AM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
test
OMG, this is INSANE on how to now...
LTD02 likes this.
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #6 of 54 Old 06-13-2014, 08:06 AM
tuxedocivic's Avatar
Quoted: 2202 Post(s)
Liked: 2078
Thanks John. I was wondering what to do.
You can also use photo bucket or some other photo server. Takes a little extra work but you can quickly post the pics in multiple threads and forums. Just another method.
LTD02 likes this.
tuxedocivic is offline
post #7 of 54 Old 06-13-2014, 08:12 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
I've just been uploading to imgur and then just using the "insert image" and pasting in the imgur url. It's a lot easier/faster.
JWagstaff is offline
post #8 of 54 Old 06-13-2014, 08:12 AM
Anthony_Gomez's Avatar
Quoted: 66 Post(s)
Liked: 187
I'm just going to skip AVS image uploading and use an imgur account (technically, you don't even need an account)
Upload (cut and paste or drag and drop, urls or images, or classic upload)
copy code
paste code
Anthony_Gomez is offline
post #9 of 54 Old 06-13-2014, 08:14 AM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
To further add to what Anthony said, if you type an "l" (lower case L) at the end of the image url before .jpg or .png or whatever, then it will make it the size of a large thumbnail, instead of full resolution (which makes the pictures HUGE off a camera)
so it would be
http://i.imgur.com/2yc00Vol.png
instead of http://i.imgur.com/2yc00Vo.png
post #10 of 54 Old 06-13-2014, 08:18 AM
Quoted: 66 Post(s)
Liked: 187
New trick I didn't know! Thanks.
post #11 of 54 Old 06-13-2014, 09:17 AM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1532
Let's try
Not too hard. My shot from 80 yards at pitch and putt with my kids.
chalugadp is offline
post #12 of 54 Old 06-13-2014, 11:04 AM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
when you have put the picture inside the post u can click it and there are little white squares in the corner . you can click those and drag the picture to the preferred size then.
Boxozaxu likes this.
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz , center RC-64-II 200W 59Hz-24KHz , sides 2xRS-62-II 150W 50Hz-24KHz , rears 2xRB-81-II 150W 44Hz-24KHz , heights 2x Salora T25i
Yamaha RX-A3040, SVS PB13-Ultra 1000W 14-200hz
4 mm el cheapo wire / Samsung UE-ES8000S TV+evo 2014 / Optoma DH-1015 Sony PS3
DaJoJo is offline
post #13 of 54 Old 06-13-2014, 11:14 AM - Thread Starter
LTD02's Avatar
Liked: 2888
one problem with hosting pictures externally is that over time many of those accounts delete pictures and the threads end up with a whole bunch of busted links. that was one nice feature about the last version of the avs software--it was easy to host the files at avs and insert them into the threads. a year or two (or more) later, all the pics are still there.
Fatshaft, pdxrealtor and Boxozaxu like this.
LTD02 is offline
post #14 of 54 Old 06-13-2014, 11:30 AM
pdxrealtor's Avatar
Quoted: 154 Post(s)
Liked: 154
They will implement the advanced vbulletin software before you know it. It allows bulk uploads and management.
Same idea as the old uploader, a bit different interface. If they don't - we will need to start a petition thread to ask them for it.
This current system is year 2k tech.
mtbdudex and DaJoJo like this.
pdxrealtor is offline
post #15 of 54 Old 06-13-2014, 11:45 AM
Quoted: 66 Post(s)
Liked: 187
I've been on many forums that migrated software in which all old attachments were wiped. I have a several year old imgur account and all images are still up/shrug
post #16 of 54 Old 06-13-2014, 01:12 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
It's basically like it used to be. Which is less good than it recently was.
Mfusick is offline
post #17 of 54 Old 06-13-2014, 01:20 PM - Thread Starter
LTD02's Avatar
Liked: 2888
"I've been on many forums that migrated software in which all old attachments were wiped. I have a several year old imgur account and all images are still up/shrug"
can't speak to imgur. there are countless old avs threads that were really nice until imageshack and photobucket dropped the pics. that's what i was referring to.
LTD02 is offline
post #18 of 54 Old 06-13-2014, 02:01 PM
pdxrealtor's Avatar
Quoted: 154 Post(s)
Liked: 154
^ +1
The flip side is if using a third party hosting service is you own the images, and have the right to remove them for whatever reason where -as some forums, Home Theater Shack comes to mind, makes them theirs after 30 days.
post #19 of 54 Old 06-13-2014, 11:57 PM
chalugadp's Avatar
Liked: 1532
I'm using Tapatalk and its one click and post. Super fast
post #20 of 54 Old 08-19-2014, 05:35 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 327
How does that work? I use Photobucket and don't like that clicking on the image in AVS takes you to the host site.
Pres2play is online now
post #21 of 54 Old 08-19-2014, 05:37 PM
chalugadp's Avatar
Liked: 1532
Install tapatalk and when in thread click on top right 3 dots. Attach picture and hit done and image.
post #22 of 54 Old 08-19-2014, 05:54 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 327
thanks, I'll give it try.
post #23 of 54 Old 08-19-2014, 06:28 PM
Boxozaxu's Avatar
Quoted: 463 Post(s)
Liked: 314
I've used tapatalk to post a few pictures but I noticed the pic file is actually hosted by tapatalk and not avsforum. Same problem with broken picture links if tapatalk goes out of business.
Boxozaxu is offline
post #24 of 54 Old 08-19-2014, 11:53 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 327
post #25 of 54 Old 08-19-2014, 11:59 PM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 327
Used the first method mentioned in post 1. How do reduce the size of the picture so I can fit text in there?
post #26 of 54 Old 08-20-2014, 08:06 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 789
I'm surprised that google picasa web is not used more.
They are big, stable company. I've used them since Mar-2007, 15GB of free storage.
It's easy to upload directly to that from my Mac via iPhoto or Aperture. Same from WinTel computers.
You can directly upload also from within the web app, or using their small picasa application.
Plus, for smartphones so easy to upload from them to picasa.
Then, you can specify the size of the file being displayed easily, like this:
picture size simply by the "s800" or "s1024" or sXXX, the XXX being the pix width desired.
Test of photo at 288 pix via "https://lh4.googleusercontent.com/-8LFIEU2a4eY/U-Q3eYYiJ6I/AAAAAAAASa8/HCibQMycwTY/s288/Aug-7-2014%2520Star%2520Trails.jpg":
Test of photo at 512 pix via "https://lh4.googleusercontent.com/-8LFIEU2a4eY/U-Q3eYYiJ6I/AAAAAAAASa8/HCibQMycwTY/s512/Aug-7-2014%2520Star%2520Trails.jpg":
Test of photo at 1024pix via "https://lh4.googleusercontent.com/-8LFIEU2a4eY/U-Q3eYYiJ6I/AAAAAAAASa8/HCibQMycwTY/s1024/Aug-7-2014%2520Star%2520Trails.jpg":
mtbdudex is offline
post #27 of 54 Old 08-20-2014, 02:13 PM
erwinfrombelgium's Avatar
Quoted: 446 Post(s)
Liked: 239
Thanks for that, LTD02!
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is offline
post #28 of 54 Old 08-21-2014, 08:24 AM
Pres2play's Avatar
Quoted: 678 Post(s)
Liked: 327
Looks great, but seems they only offer 1 GB.
post #29 of 54 Old 08-21-2014, 08:58 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 789
I've got nearly 3,000 images there - most uploaded at 1024pix, some 1600pix, a few full size RAW files also, they don't care format jpg/tiff/png/raw.
It's 15GB free storage, more than that and you can choose a plan.
You can see my 3,000 images are under 1GB, I'll "never" run outta free storage space.
https://www.google.com/settings/storage?hl=en_US
mtbdudex is offline
post #30 of 54 Old 08-21-2014, 09:11 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 789
just 1 more post...
I've got 42 albums...I can set each one's visibility as private, via link only, or public, which is handy.
Even private I can share images in it to forums, that just means others cannot see that album.
Public is of course open to all, and via link if you send a link to people then they can access that album
and uploading to an album is so easy, you can upload within an album directly to that, or easily create a new album..
I have a flickr account, hardly use that, have not tried other photo hosting services.
This has worked for me since 2007.
mtbdudex is offline
