Ultimax 15" LLT Build - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #1 of 95 Old 06-13-2014, 09:47 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
This is my first subwoofer build and I decided to just go all out with my first attempt. My inspiration and basic outline for the design was a martysub. I wanted to use slightly different dimensions because of my room shape, so I went with a longer and thinner box. It measures out to 21"w x 23"h x 50"L. That works out to roughly 10cf internally after bracing and the driver. It's tuned to 16 hz.
I'm just about finished at this point. All I need to do is install the driver and fire it up! I'm using an inuke1000dsp to power it. Of course I will be using bridge mode to get all the power through one output. I'm hoping this amp will make enough power for the ultimax. But considering that ported designs are more efficient than sealed, my feeling is that it will provide enough power. I have a huge room that's open to the rest of the house, so I need all the sub I can get. Check out the pics and let me know what you think!
LTD02 likes this.
SXRDISBEST is offline
post #2 of 95 Old 06-13-2014, 09:51 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Getting started with a dry fit.
LTD02 likes this.
post #3 of 95 Old 06-13-2014, 09:56 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Coming together nicely at this point.
LTD02 likes this.
post #4 of 95 Old 06-13-2014, 09:57 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Rear view of port structure.
LTD02 likes this.
post #5 of 95 Old 06-13-2014, 09:58 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Most of the bracing is installed at this point and most of the damping material.
LTD02 and Smittyfit like this.
post #6 of 95 Old 06-13-2014, 09:59 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Top installed and curing. This is almost complete!
LTD02 likes this.
post #7 of 95 Old 06-13-2014, 10:01 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Everything screwed and glued. Time to fit the driver and test this baby! I will be finishing the box with Duratex roll on when it arrives on Monday. It's coming from the south end of Florida so it takes forever to get to Arizona!
LTD02 likes this.
post #8 of 95 Old 06-13-2014, 10:12 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
This is definitely an awesome looking driver.
LTD02 likes this.
post #9 of 95 Old 06-13-2014, 05:58 PM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Driver installed and tested. This thing is a beast and started to actually open my plantation shutters from playing cloverfield and ironman. I'm extremely happy with the build, and I'm sure there will be more subs to come in the future. Btw, I love the inuke's eq that's available to tweak on a PC. It really helped fill out the bottom end for movies. For those wondering whether or not the nu1000 has enough juice for the ultimax 15, I can assure you it does. I was able to push it to crazy levels of volume that I would never use while watching something.
Time to get back to some movie watching!
Scott Simonian and LTD02 like this.
post #10 of 95 Old 06-13-2014, 08:14 PM
notnyt's Avatar
Quoted: 2152 Post(s)
Liked: 1980
notnyt is offline
post #11 of 95 Old 06-13-2014, 10:29 PM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Originally Posted by notnyt View Post
Nice work, are you planning on finishing it?
Definitely. I'll be using Duratex. I've never used it before but it seems like its a very nice finish to it.
post #12 of 95 Old 06-14-2014, 05:10 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
What does the rest of your setup consist of? Which AVR are you using and what are your speakers?
Martycool007 is offline
post #13 of 95 Old 06-14-2014, 09:35 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
I'm using a Yamaha Rx-V571 and Klipsch RC52 Center channel, RF15 mains and RB10 surrounds. I also have two Dayton Sub1200's. The Daytons have done an excellent job for only costing a combined $250. The new Ultimax is definitely the star, considering how modest the rest of my system is.
post #14 of 95 Old 06-14-2014, 01:18 PM
antisuck's Avatar
Quoted: 98 Post(s)
Liked: 141
Nice job. And a thousand thanks for not jumping on the bandwagon and calling it a "MegaMarty" or some such thing just because it features a longitudinally braced slot port.
SXRDISBEST and LO4F like this.
antisuck is online now
post #15 of 95 Old 06-14-2014, 01:42 PM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Yeah, my design literally doesn't share a single measurement with that Marty crap!
post #16 of 95 Old 06-14-2014, 02:37 PM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
Nice
15Hz should do nicely! Good to hear that the 'lowly' iNuke1000 is punching nicely too, compared to all the massive builds on here lol
MemX is offline
post #17 of 95 Old 06-14-2014, 03:18 PM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Originally Posted by MemX View Post
Nice
I know. It's easy to get scared into over buying and over building just because you follow these threads and hear that 2000 watts to a single sub is just barely enough to satisfy. It's a bit subjective to say the least!
post #18 of 95 Old 06-15-2014, 03:58 PM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Does anyone have in input on how I should set the limiter on the nu1000 for my application? I have the HPF set at 20hz Linkwitz-Riley 24db. Also, as far as the HPF settings are concerned, why is there a gain knob within that menu?
post #19 of 95 Old 06-16-2014, 03:47 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2573
well, maybe you could all this one the MARYsub... :-)
...where did the "T" go?
the "T" was lost when you castrated it with the LR4 HP @20hz .
green is with no filter.
black is with LR4 HP @20hz (4 is the order of the filter, which is 6db per, so 24db/oct)
magenta is with a little EQ added back in. alternatively you could use a shelf filter to push the high pass down to around 16hz, but you might feel more comfortable with this one:
Parametric EQ: f=20hz, Q=1.40, gain= +3db
that driver's xmax is around 22mm, Klippel confirmed, so it should have even a little bit more than that as potential. in model, the 1000 amp pushes the driver to just past xmax in your enclosure, suggesting that it should be find with no limiter set. the 1000 watts number isn't really the number. that is a screwball voltage peak figure. the real number is something like 700 watts or so.
btw, if you want to know how to push the high pass filter under 20hz:
How to extend the high pass filter below 20hz in DCX2496
also...great build!
lots of "likes" for you. :-)
DavidK442 likes this.
Listen. It's All Good.
LTD02 is offline
post #20 of 95 Old 06-16-2014, 10:25 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
also...great build!
You're definitely right about the MARY part! I didn't realize the sub 25hz performance would be effected so much by a HPF at 20hz. Thanks so much for the info! You truly are doing a service out there with your MAMMOTH number of posts! I believe I did hear some noise from the sub the first time I tested it with Cloverfield. I'm not familiar with the different "bad" sounds that subs make when overextended, but I could have sworn it wasn't something coming from the movie soundtrack. I guess I was trying to avoid that again if possible. And I really appreciate the link to the work around. I might try that when playing sub busters like Cloverfield again!
post #21 of 95 Old 06-17-2014, 06:50 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
If you are worried about driver damage, you could always work out your usual playback level, unplug the speakers from the AVR/amp(s), and then run the soundtrack with just the .1 sub channel running - that will mean any high frequency or untoward noise from the drivers should be obvious
Oh, and +1 to thanking LTD for all his help!
SXRDISBEST likes this.
MemX is offline
post #22 of 95 Old 06-17-2014, 09:53 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Good suggestion for sure! I haven't heard the same sound again so I think it was probably just something from the movie. At the time, I had the sub on the table that I built it on. Which was near the front left speaker.
post #23 of 95 Old 06-17-2014, 09:58 AM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Duratex applied and it looks great. It's a bit tough to get even but I think it's worth the $55/gallon price tag.
post #24 of 95 Old 06-17-2014, 12:19 PM
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1505
Sweet build ! In a few months you'll be like me and all your speakers will be diy
chalugadp is offline
post #25 of 95 Old 06-17-2014, 01:48 PM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
Putting a bow on this one and calling it FINISHED! Tons of thanks to everyone on this thread for so much great information. I'm officially addicted!
post #26 of 95 Old 06-23-2014, 11:18 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
Sweet, you should be very happy with that!
MemX is offline
post #27 of 95 Old 06-23-2014, 12:35 PM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
I most certainly am happy with it! The Ultimax is starting to break in and sounds excellent. Scary at times! I'm getting flat response down to about 16 hz and haven't seen the clip light once on the inuke.
post #28 of 95 Old 06-23-2014, 01:26 PM
djhamp's Avatar
Quoted: 24 Post(s)
Liked: 27
Looks good! Can you give me more details on the port dimensions please?
I have the 15" ultimax in a sealed box now and would like to get more output with out buying more speakers, seems like this would work.
djhamp is offline
post #29 of 95 Old 06-23-2014, 01:49 PM - Thread Starter
SXRDISBEST's Avatar
Quoted: 52 Post(s)
Liked: 42
This box came out to about 11.2 cf net after bracing, so I needed a 60" port for 15hz tuning. The port opening is 18" when you remove the bracing width as well. I used 1x4's for the port bracing which come out to roughly .75"x3.5". The port top panel is 45.75" long and I have a 14" piece extending it vertically within the box. This adds up to 59.75", but that's the outside dimension of the port. If you measure it down the middle, it's actually 63.5" long. With this large of a port diameter, I probably wouldn't hear any port noise even with two 18's. And obviously I don't hear any at all currently. The peak air velocity at about 15 hz is something like 16 m/s.
post #30 of 95 Old 06-23-2014, 09:07 PM
schmidtwi's Avatar
Quoted: 166 Post(s)
Liked: 121
Great job, SXR! Very nice looking sub!
Do you have a complete cut list by chance? I may also try this with one of my UM15-22's. Just bought my 3rd one, and haven't built a box yet - other 2 are sealed 21" cubed.
The Schmidt Haus Theater - WIP (or not) since 2010
schmidtwi is offline
Dayton , diy , llt , subwoofer , ultimax
