How much better is this graph? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-13-2014, 09:25 PM - Thread Starter
Samps's Avatar
Quoted: 939 Post(s)
Liked: 529
Is the blue graph worth a rebuild of the box? I currently have the green graph but could get the blue graph with a new box. Cost is not an issue. I'm curious if the additional 3db at 20hz is worth the effort?
Samps is online now
post #2 of 7 Old 06-13-2014, 09:45 PM
BassThatHz's Avatar
Quoted: 2379 Post(s)
Liked: 2153
3db is like a doubling of the watts.
BassThatHz is offline
post #3 of 7 Old 06-14-2014, 05:06 AM
Bill Fitzmaurice's Avatar
Liked: 5687
What matters most is in-room response, not predicted response. You may have an actual in-room f3 of 15Hz, in which case nothing needs fixing. Only by actually measuring the in-room response will you know.
Bill Fitzmaurice is offline
post #4 of 7 Old 06-14-2014, 05:16 AM - Thread Starter
Samps's Avatar
Quoted: 939 Post(s)
Liked: 529
I thought doubling watts got you more spl not extension?
If room gain and eq already get me a flat response to 20hz is there any benefit to having a box that is sized properly?
Edit bill posted as I was typing.
I did check with rew and I do get flat to about 18hz. I was just curious if there was an advantage to getting that result with a larger box vs eq.
Samps is online now
post #5 of 7 Old 06-14-2014, 07:04 AM
Liked: 5687
EQ eats up power and driver excursion. If you can't reach your desired listening levels down low without stressing the amp, voice coil or driver suspension then a larger box may help. The way to know that is by taking a THD reading at your desired maximum output levels; you don't want to see it higher than 10%. I don't know if REW has that capability. I use HolmImpulse, and it does.
post #6 of 7 Old 06-14-2014, 07:11 AM - Thread Starter
Samps's Avatar
Quoted: 939 Post(s)
Liked: 529
Thanks. Exactly the info I was looking for.
Samps is online now
post #7 of 7 Old 06-14-2014, 07:13 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6573
REW has RTA analysis that takes THD measurements.
basshead81 is offline
