Inuke6000DSP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-14-2014, 02:19 PM - Thread Starter
AVI20's Avatar
Inuke6000DSP
I have a minimarty sub that I built, and I am just having some issues with all the settings on the DSP software, is there any way anyone has the same or similar setup and could send me their settings?
AVI20 is offline
post #2 of 4 Old 06-14-2014, 02:39 PM
chalugadp's Avatar
Quoted: 1673 Post(s)
Liked: 1531
Only setting that could help you is hpf. I set mine at the 20hz and then put a 3db boost at 20hz with peq. That pushes tuning down to close to 17hz
All the other peq settings are room Dependant. Each room is different and you need to take measurements to get success. Can use spl meter with test tones or use rew with mic.
chalugadp is offline
post #3 of 4 Old 06-14-2014, 02:59 PM
asarose247's Avatar
Quoted: 815 Post(s)
Liked: 617
Question settings
a Question for clarity
was that a HPF at 20 and then a PEQ set with the 3 db boost? Gain?)
if at first a HPF, settings please and then
for the PEQ, what was the Q?
thank you
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #4 of 4 Old 06-14-2014, 03:58 PM
chalugadp's Avatar
Liked: 1531
thank you
Yes gain. Peq was q of 1. You can use the workaround that ltd posted . I don't listen at crazy levels so I'm not worried about boosting a bit.
