Help with input/output voltage - AVS Forum
post #1 of 2 Old 06-16-2014, 02:02 PM - Thread Starter
dimetera413's Avatar
I'm going to be getting my amp to power 4 SI 18s that are D2 ohms. I have 2 per enclosure. I have a NAD 747 receiver that I use as a pre/pro with a para sound halo amp. I was thinking either the inuke 3000 and running it in 2 ohms to each enclosure or the same with the europower4000. I am not sure of my receivers output voltage and how much is needed for those amps. Can anyone give me any info or advice? I was thinking of a peavey ipr2 3000 also if anyone has advice on that also.
Sent from my iPad using Tapatalk HD
dimetera413 is online now
post #2 of 2 Old 06-17-2014, 01:43 AM
BassThatHz's Avatar
Quoted: 350 Post(s)
Liked: 429
Unless it is in the spec, or you phone them, or measure it yourself, then there is no real way to know...
Worst case, you have to buy an RCA to XLR converter box.
No biggie.
BassThatHz is offline
