speaker build. jtr 2228 performance - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #61 of 79 Old 07-10-2014, 11:12 PM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
which graph is for Tempest?
WereWolf84 is offline
post #62 of 79 Old 07-10-2014, 11:24 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Sorry, just edited that. The Tempest is the green graph.
jbrown15 is offline
post #63 of 79 Old 07-11-2014, 01:34 AM
jbrown15's Avatar
Liked: 1993
This graph might be a little easier to look at and read, again the green line is the Tempest and the pink is my 228HT. The graph has 1/12th smoothing applied and zero EQ for either speaker.
jbrown15 is offline
post #64 of 79 Old 07-11-2014, 01:37 AM
jbrown15's Avatar
Liked: 1993
Crap, I just realized that captured image was only for up too 1760hz. Its the same graph as the first one that I posted, just zoomed in on it.
jbrown15 is offline
post #65 of 79 Old 07-11-2014, 12:52 PM
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 61
They follow alot, but I suspect that your room has treatment issues. How far are you putting the mic? For the Tempest it needs to be about 0.5m away or less and in line with the center of the waveguide and aimed at it. You are likely getting reflections off the mic stand.
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #66 of 79 Old 07-11-2014, 02:24 PM
Nate Hansen's Avatar
Quoted: 252 Post(s)
Liked: 162
Depends on what he's going for.....in room or gated? Looks like in room. He's getting much more significant reflections than the mic stand. Half meter away is too close for either to measure a waveguide and to get proper integration with the other drivers.
tuxedocivic likes this.
Nate Hansen is offline
post #67 of 79 Old 07-11-2014, 02:29 PM
jbrown15's Avatar
Liked: 1993
The mic was 2m's away from both speakers and the mic was level and aimed directly at the waveguide's of both of them.
jbrown15 is offline
post #68 of 79 Old 07-11-2014, 04:44 PM
Quoted: 167 Post(s)
Liked: 61
I'm confused as to what was attempting to be shown. If a comparison of the speakers was the intent then attempting trying to compare speaker response, he was too far away. If he was attempting to show speakers in the room, he probably should shoot for the listening position.
In my opinion, when you reach two meters, the room response can well be contributing to the dips. That the two curves track along most of the graphs makes me believe that the room and the speaker position / angle is contributing to the lack of flatness.
Perhaps I missed it earlier, but what is attempting to be discerned from the graphs? I thought the thrust at one point was to determine the better speaker or attempt to determine how close they were.
Theater Build
post #69 of 79 Old 07-11-2014, 04:59 PM
tuxedocivic's Avatar
Quoted: 1887 Post(s)
Liked: 1712
2m isn't close enough to remove reflection in a common household room, but 0.5m is much to close to represent the speaker's response. 1m is about right IF you gate the measurement properly and isolate the speaker from boundaries as best possible. Something as large as the Fusion 12 is still not gonna measure easily indoors unless you have vaulted ceilings.
So then, you measure at 2m and let the reflections in. The reflections will be the same for each speaker, so what you do as the reader is compare the difference. For instance, there's a deep null at 400hz in both speakers. I would NOT assume that is an issue with the speaker, rather the room.
tuxedocivic is offline
post #70 of 79 Old 07-11-2014, 06:07 PM
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1505
So is it a room that will lower the quality of the speakers we hear or is most rooms look like that ?
chalugadp is offline
post #71 of 79 Old 07-11-2014, 06:30 PM
Quoted: 252 Post(s)
Liked: 162
Below 300hz or so (depends on the room) you enter the modal region where the room begins to dominate the response. This will happen in every small room you put your speakers in. Positioning and room treatments help to an extent. This is why distributed subs work well..... they cancel some modes and boost others based on their position in room. This gets tricky in the midbass region because the wl gets shorter but the room still dominates, as you can see with that gnarly 400hz null.. Directive speakers (IMO) aren't of much use in the modal region but they do help above that if they are constant (or uniform) directivity.
Like tux said I like 1m in room with the speaker halfway between the floor and ceiling. Below 1khz the data will be less detailed due to the freq resolution from the gating. I think 2m+ is ideal if you can get the speaker up in the air outside.
post #72 of 79 Old 07-11-2014, 06:46 PM
jbrown15's Avatar
Liked: 1993
I didn't take the measurements trying to prove one speaker is better then the other, nor did I say I was taking the measurement to try to prove that. I simply posted a measurement showing how both speakers compare in my room, I'll try to take a few measurements tonight with the mic 1m away.
jbrown15 is offline
post #73 of 79 Old 07-11-2014, 07:51 PM
Liked: 1712
Joe, what's causing that null at 400hz. Honestly, that's really quite bad. Usually they aren't that distinct up that high in frequency.
If you could identify the cause, you could tackle it.
That's the kind of stuff people experience and then say, "I want speakers with more midbass" when really they need to fix some things.
post #74 of 79 Old 07-11-2014, 08:04 PM
jbrown15's Avatar
Liked: 1993
I'm thinking its my room Ryan, my room is 19.5ft long but has about a 7ft opening into the room. So one side is open to the 10'x10' area before the theater room. If I had to guess that is causing the problem, I plan on building a acoustical panel that's 3'x6' and hang it where the opening is to help.
jbrown15 is offline
post #75 of 79 Old 07-11-2014, 08:29 PM
Liked: 1712
Usually openings aren't the problem. It most definitely is the room. Just wondering what boundary.
Oh wait, that's not at the LP. Nevermind. It doesn't matter for you cause that's a 2m response. I'm losing my brains.
post #76 of 79 Old 07-11-2014, 08:38 PM
jbrown15's Avatar
Liked: 1993
Hopefully you can give me a crash course on measuring with REW when you're out and room measuring too....lol
Which ferry are you catching over on Saturday?
jbrown15 is offline
post #77 of 79 Old 07-11-2014, 08:45 PM
chalugadp's Avatar
Liked: 1505
I think he could teach everyone a lot on home theater stuff
post #78 of 79 Old 07-11-2014, 09:23 PM
jbrown15's Avatar
Liked: 1993
Donny I think I can come over Monday or Tuesday if you still wanted me too.
jbrown15 is offline
post #79 of 79 Old 07-11-2014, 09:25 PM
chalugadp's Avatar
Liked: 1505
for sure. now I want to take a sweep of my mains too. let me know what day works best for you.
