Living Room " Micro-Cube " - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 81Likes
post #151 of 520 Old 06-19-2014, 08:54 PM - Thread Starter
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1498
Originally Posted by charvel74 View Post
Nice. What is your plan for finishing ? Paint? veneer?
I will see how much jbrowns friend wants to spray paint finish. Otherwise I will veneer. Either way it will be dark color and main speaker on top will be medium-light color.
charvel74 likes this.
chalugadp is offline
post #152 of 520 Old 06-19-2014, 08:56 PM
MDST's Avatar
Quoted: 32 Post(s)
Very very nice chaluga and your daughter its right ja ja!!
How about Alpine SWR1522 or MTX 9515 44 on the micro cube??
This forum is a pain in the ass! One day you see something that you like and have everything ready for the next step but when you come back, you see something else even better....
Dank1209 likes this.
MDST is offline
post #153 of 520 Old 06-19-2014, 09:03 PM - Thread Starter
chalugadp's Avatar
Liked: 1498
The alpine specs are good. Don't know much about that driver. Same with the mtx, although its pricey. Would have to model them to be sure. Since I'm getting 4 cost is a factor for me.
post #154 of 520 Old 06-19-2014, 09:31 PM
MDST's Avatar
Quoted: 32 Post(s)
Yeah, and 4 drivers like those ( performance on micro cubes ) for that price is unbeatable!
MDST is offline
post #155 of 520 Old 06-19-2014, 10:17 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Donny, can you post a pic of it next too your Marty cube?
jbrown15 is offline
post #156 of 520 Old 06-19-2014, 10:25 PM - Thread Starter
chalugadp's Avatar
Liked: 1498
Don't have the cube anymore, sold it. Its smaller but not tiny
post #157 of 520 Old 06-19-2014, 10:36 PM
basshead81's Avatar
Quoted: 165 Post(s)
Liked: 4744
What about the Polk MM1540?
http://www.polkaudio.com/products/mm1540
basshead81 is offline
post #158 of 520 Old 06-19-2014, 10:36 PM
jbrown15's Avatar
Liked: 1993
oh okay, I didn't realize you didn't have the Marty cube anymore.
jbrown15 is offline
post #159 of 520 Old 06-19-2014, 10:39 PM
LTD02's Avatar
Quoted: 2293 Post(s)
Liked: 2489
"How about Alpine SWR1522 or MTX 9515 44 on the micro cube??"
i've yet to see a frequency sweep of the alpine swr's. kind of hard to believe. i'm not sure if the additional excursion of either of those drivers helps a whole lot given the ported design and the modest tuning relative to the Dayton. maybe if you can blast a ton of power through them. maybe.
Listen. It's All Good.
LTD02 is offline
post #160 of 520 Old 06-19-2014, 10:46 PM - Thread Starter
chalugadp's Avatar
Liked: 1498
And someone's coming tomorrow to pick up one of my minimarty enclosures. I have had six different sub boxes in the last six months. The micro makes seven. Guess I am a subwoofer whor$&#-.
Like the porter cable nailer. Compressor is good too, its hdx.
post #161 of 520 Old 06-19-2014, 11:01 PM
jbrown15's Avatar
Liked: 1993
Yeah Porter Cable makes great stuff, I have their brad nailer, molding stapler and upholstery stapler.
jbrown15 is offline
post #162 of 520 Old 06-19-2014, 11:04 PM
jbrown15's Avatar
Liked: 1993
Donny, I have two UMIK-1 mics; you can borrow one if you want and run some sweeps with REW once you have all four subs up and running. I'm sure there's lots of guys that would love to see some measurements on this new micro marty.
chalugadp likes this.
jbrown15 is offline
post #163 of 520 Old 06-19-2014, 11:06 PM
randyc1's Avatar
Quoted: 232 Post(s)
Liked: 40
[QUOTE=chalugadp;25112266]And someone's coming tomorrow to pick up one of my minimarty enclosures. I have had six different sub boxes in the last six months. The micro makes seven. Guess I am a subwoofer whor$&#-.
...So your plan Chalugadp is to have 4 Mini-cube's, to replace all your Marty's ??
randyc1 is offline
post #164 of 520 Old 06-19-2014, 11:08 PM - Thread Starter
chalugadp's Avatar
Liked: 1498
Yeah that would be good. I will take some initial measurements with SPL meter and then have you over to do rew!
post #165 of 520 Old 06-19-2014, 11:08 PM
jbrown15's Avatar
Liked: 1993
I think he's replacing two Marty's with four of these micro marty's.
jbrown15 is offline
post #166 of 520 Old 06-19-2014, 11:12 PM - Thread Starter
chalugadp's Avatar
Liked: 1498
[quote=randyc1;25112546]
Yes four micro-cubes. Even if its the same output that I currently have that's just fine. I want smaller sub's to be stands for my new mains. Just two cluttered in my living room with big enclosure and big mains coming.
I also want to try nearfield to see if its more tactile, and I like the idea of subs all around me. Also I will come out 300 bucks ahead which pays for almost one of my new mains.
post #167 of 520 Old 06-19-2014, 11:46 PM
jbrown15's Avatar
Liked: 1993
What about using the Sundown SA-15 drivers?
Can be had for a decent price http://www.amazon.com/SA-15-D4-Sundo.../dp/B004ILQK3I
And Josh Ricci seemed to think it was a pretty good driver.
http://www.data-bass.com/data?page=driver&id=44
Their are also available in 2ohm, so you could run two off of a single inuke 3000.
http://www.amazon.com/SA-15-D2-Sundo...J22RW2SM6PC082
jbrown15 is offline
post #168 of 520 Old 06-19-2014, 11:51 PM - Thread Starter
chalugadp's Avatar
Liked: 1498
The Dayton is 300 bucks cheaper for 4 and modeled really well . I'm sure some others will use alternate drivers.
post #169 of 520 Old 06-19-2014, 11:55 PM
MDST's Avatar
Quoted: 32 Post(s)
Check this out John ( post 10 ):
http://www.diyaudio.com/forums/subwo...ands-look.html
LTD02 likes this.
MDST is offline
post #170 of 520 Old 06-20-2014, 12:11 AM
jbrown15's Avatar
Liked: 1993
True but with the amount of xmax the Sundown has it could have a pretty good size output advantage over the Daytona. The only difference is you wouldn't be up $300 you'd break even, wouldn't it be worth it if it was a an upgrade over the Daytona for only $300?
Maybe LTD can model the Sundown driver in the micro marty for anyone else that might be interested. Especially with it looking like its not to hard to buy.
jbrown15 is offline
post #171 of 520 Old 06-20-2014, 12:13 AM
jbrown15's Avatar
Liked: 1993
I just read that post, wow that looks like a really good driver to use in the micro marty and can be picked up on Amazon for under $200ea.
jbrown15 is offline
post #172 of 520 Old 06-20-2014, 12:23 AM - Thread Starter
chalugadp's Avatar
Liked: 1498
I'd be curious to see the model with these other drivers. I don't need more SPL though. When I run it loud now there is a lot of rattles in my old home. Don't have that sweet bunker like u
post #173 of 520 Old 06-20-2014, 12:25 AM - Thread Starter
chalugadp's Avatar
Liked: 1498
I don't have amp power for four sub's to take advantage of alpine.
post #174 of 520 Old 06-20-2014, 12:34 AM
jbrown15's Avatar
Liked: 1993
Doesn't the inuke 3000 have roughly 2200watts RMS in bridged mode? from the little reading that I did most guys using the Alpine were powering it with between 1000-1200RMS.
I wish my house was a bunker, when I unleash all four subs at my place the neighbours house rattles!...lol
LTD02 likes this.
jbrown15 is offline
post #175 of 520 Old 06-20-2014, 12:39 AM - Thread Starter
chalugadp's Avatar
Liked: 1498
But four drivers and two inuke3000dsp. Don't I have to run in stereo mode ?
post #176 of 520 Old 06-20-2014, 12:40 AM
LTD02's Avatar
Liked: 2489
"I wish my house was a bunker, when I unleash all four subs at my place the neighbours house rattles!...lol"
LTD02 is offline
post #177 of 520 Old 06-20-2014, 12:49 AM
LTD02's Avatar
Liked: 2489
alpine swr1542 - 3.5 cubic feet tuned to 23hz 1100 watts, no filters. excursion 17mm at 32hz.
the swr is supposed to have a pretty linear bl curve (relatively flat and symmetrical). the 15 didn't get 'updated' along with the smaller models in the last round. maybe it was thought that it was good enough. inductance doesn't seem out of control. as always, multiples can bring up the otherwise mediocre sensitivity. not much not to like if you can handle the way it looks. :-0
Name:	swr1542 3.5 cf tuned to 23hz.png
LTD02 is offline
post #178 of 520 Old 06-20-2014, 12:50 AM
jbrown15's Avatar
Liked: 1993
I think the SWR-1522D is a 2ohm+2ohm so if I'm not mistaken you could wire them each as a 2ohm load and run two off of a single inuke 3000 in bridged mode. I'm sure if I'm wrong John or someone else will say something.
That Alpine driver looks pretty good for $200ea.
jbrown15 is offline
post #179 of 520 Old 06-20-2014, 12:51 AM
jbrown15's Avatar
Liked: 1993
What about that Sundown driver John?
jbrown15 is offline
post #180 of 520 Old 06-20-2014, 12:53 AM
jbrown15's Avatar
Liked: 1993
So it looks like a single SWR-1522D has a 2dB advantage at 20hz over the Daytona driver. Not bad for $50 more.
jbrown15 is offline
