Help with first DIY: DO SI 18 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 141Likes
post #91 of 603 Old 06-27-2014, 03:40 PM - Thread Starter
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 895
For veneering, you are using a vacuum bag type method dp? I am now starting to look into the process and want to try it on the next fun little bookshelf project I plan on getting going here pretty soon.
He was using paper backed veneer on his minimarty video.
Sent using Tapatalk since the mobile version is still 👎
ambesolman is offline
post #92 of 603 Old 06-27-2014, 03:44 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
With contact cement?
beastaudio is offline
post #93 of 603 Old 06-27-2014, 04:13 PM - Thread Starter
ambesolman's Avatar
Liked: 895
Here's the link to his veneer video.
post #94 of 603 Old 06-27-2014, 04:39 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Yeah just contact cement and roller. Great for regular stuff. If I was to do a rounded corner I would want a vacuum.
chalugadp is offline
post #95 of 603 Old 06-28-2014, 10:21 PM - Thread Starter
ambesolman's Avatar
Liked: 895
Originally Posted by chalugadp View Post
Change the height to 24" so you can get more pieces on a sheet. Adjust other measurement. That's why all Marty's are 24" for width.
Ok, so I redid the design to where all H&W cuts are 24". I'm guessing the cut sheet program is also taking the blade width into account because it's not letting me do 2 24" pieces out of the width. I'm assuming the blade width measurement is significant enough to throw it out of whack once I start assembly? Any suggestions other than further reducing the cuts from 24"?
post #96 of 603 Old 06-28-2014, 10:24 PM
chalugadp's Avatar
Liked: 1505
MDF is 49" wide. If your using plywood then go to 23.75" wide.
post #97 of 603 Old 06-28-2014, 10:44 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Originally Posted by kevings View Post
maxcut is another really good cutsheet progarm. It's got a really nice interface and the basic version ( which is still powerful ) is free.
http://www.maxcut.co.za/
Cool link!
Mfusick is offline
post #98 of 603 Old 06-29-2014, 08:57 AM - Thread Starter
ambesolman's Avatar
Liked: 895
Is there any reason I couldn't use two different woods? I could do the inner box in mdf and outer in something nicer maybe?
post #99 of 603 Old 06-29-2014, 09:05 AM
chalugadp's Avatar
Liked: 1505
Yes, you can do that.
post #100 of 603 Old 06-29-2014, 12:26 PM - Thread Starter
ambesolman's Avatar
Liked: 895
I think that'll help me get the ball rolling. I'm less concerned about messing up mdf than higher dollar wood. This way I can actually get an operable box while finding and deciding on wood and finish. Not to mention get a little experience before messing with nicer stuff.
I went to a woodworking store yesterday and they game me a couple of liner yards that carries better wood than HD, so they say. I wasn't thrilled with what I saw at HD or lowes so it's worth checking out.
On top of that I'm still gathering tools. My dad says he has a router as well as bar clamps. Just have to drive 2hrs to get them. My buddy loaned me his router but only had one bit...wtf.
post #101 of 603 Old 06-29-2014, 01:29 PM
chalugadp's Avatar
Liked: 1505
Harbour freight tools for clamps.
ambesolman likes this.
post #102 of 603 Old 06-29-2014, 02:26 PM - Thread Starter
ambesolman's Avatar
Liked: 895
That's good looking out! Man they've got some cheap clamps, and it's only 5mi away
post #103 of 603 Old 06-29-2014, 02:37 PM
chalugadp's Avatar
Liked: 1505
I just bought 6 from them for 20 bucks. The lady behind me gave me a coupon for 20% off which saved me another 10 bucks on my 70 dollar total bill.
post #104 of 603 Old 06-29-2014, 05:07 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
The squeeze trigger kind suck. Make sure you get the ones that you screw to tighten, they work a lot better for speaker boxes.
Maklar and BacHolz like this.
Mfusick is offline
post #105 of 603 Old 06-29-2014, 05:19 PM
chalugadp's Avatar
Liked: 1505
F clamps way to go, that's what I buy.
post #106 of 603 Old 06-29-2014, 06:05 PM - Thread Starter
ambesolman's Avatar
Liked: 895
Thanks for the tips!
post #107 of 603 Old 06-29-2014, 08:13 PM - Thread Starter
ambesolman's Avatar
Liked: 895
So with trying to get my cut sheets figured out, should I adjust the bracing dimensions to do dado cuts? If so how much or is it worth the extra trouble?
post #108 of 603 Old 06-29-2014, 10:14 PM
chalugadp's Avatar
Liked: 1505
Not needed. Dado cuts are nice but I would leave that for your next build.
post #109 of 603 Old 06-30-2014, 05:07 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
You can use a router with a straight edge too - it makes nice dado cuts as well.
Mfusick is offline
post #110 of 603 Old 07-01-2014, 12:30 AM - Thread Starter
ambesolman's Avatar
Liked: 895
Think I'm just going to head up to my dad's place in the mountains this week for a few days to check on it since he's outta town for a while. He said he's got a router (with bits), pipe clamps, a compressor and maybe a few other things I could use. There's a lumber supply on the way so I'll check out their selection while I'm at it. Anything else I need I'll grab from harbor freight on the way back into town since they have a sale going on this weekend.
So this is what I've come up with so far. The innards will be mdf and the outer box made of something else. All the innards fit on one sheet of mdf, the out box will be 2 sheets unless I redo the design again. Since there will be a bit of extra wood I may just dbl baffle the side walls for the hell of it. Do I need more bracing? How's it look?
post #111 of 603 Old 07-03-2014, 07:58 PM - Thread Starter
ambesolman's Avatar
Liked: 895
I'm trying to find a jasper jig that will allow for the 18 5/8" circle I want to cut. However, I can't find one that goes bigger than 18 3/16
What are y'all using to cut these larger circles? Got a link?
post #112 of 603 Old 07-03-2014, 08:13 PM
chalugadp's Avatar
Liked: 1505
Make your own jig like this one
Its adjustable and great for hand held or bigger router.
You drill a hole in the center of the baffle the size of the bolt hole. It locks in and good to go.
post #113 of 603 Old 07-03-2014, 08:25 PM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
Bam...
300J
cogeng182 likes this.
popalock is offline
post #114 of 603 Old 07-03-2014, 10:18 PM - Thread Starter
ambesolman's Avatar
Liked: 895
Maybe...jebus, first y'all convince me to build my own sub, now you want me to build my own tools
Originally Posted by popalock View Post
Bam...
300J
Says it's calibrated for half inch bits...I have 1/4" bits. How much will that screw me up?
post #115 of 603 Old 07-03-2014, 10:23 PM
chalugadp's Avatar
Liked: 1505
Its not hard. I know u could do it. Jigsaw and or router needed.
post #116 of 603 Old 07-04-2014, 08:02 AM - Thread Starter
ambesolman's Avatar
Liked: 895
Would you mind sharing some measurements and instructions?
post #117 of 603 Old 07-04-2014, 09:55 AM
chalugadp's Avatar
Liked: 1505
Will later today,
Watching world cup.
post #118 of 603 Old 07-04-2014, 11:04 AM - Thread Starter
ambesolman's Avatar
Liked: 895
post #119 of 603 Old 07-04-2014, 04:05 PM
chalugadp's Avatar
Liked: 1505
Piece is 12" long by 4-5", wide depending on your router. Draw a line in the middle and drill hole for router opening. Then jigsaw hole. Create slot from 4" to 10"away from center of router bit and lined up in middle.
Two ways to do slot. Could router all the way through and then router channel. Or drill hole and cut slot with jigsaw and then router. I'd do first one. Just need a straight cutting bit.
Poke holes through router faceplate to then drill holes for screws to attach jig to router. Lastly get bolt and screw (,I'd go 1/4" bolt) and attach.
post #120 of 603 Old 07-04-2014, 07:02 PM - Thread Starter
ambesolman's Avatar
Liked: 895
Thanks, I should be able to handle that. So it looks like 1/4" bolt, nut, a couple of washers and a wingnut?
Was it a 1/4" router bit as well I guess?
