Help with first DIY: DO SI 18 - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 141Likes
post #121 of 603 Old 07-04-2014, 08:18 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Originally Posted by ambesolman View Post
Thanks, I should be able to handle that. So it looks like 1/4" bolt, nut, a couple of washers and a wingnut?
Was it a 1/4" router bit as well I guess?
The larger router slot will be just bigger then the bolt, and the bolt will need a bit just bigger then it. Get the bolt and screw and then go over to router bits . if the router bit you find is just right size you only need one pass with router. Otherwise you will need two passes.
The advantage of this jig over jasper is you can adjust the size custom. If you want a tight fit for and 8" or 10", driver with hardly any play you can dial it in. Once you find the spot on scrap wood you mark it and its there.
Oh don't use MDF like the picture. It will wear away over time. Use a hardwood like maple or oak. Last you the rest of your life.
ambesolman likes this.
chalugadp is offline
post #122 of 603 Old 07-04-2014, 09:13 PM - Thread Starter
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 895
Thanks Donny!
Sent using Tapatalk since the mobile version is still 👎
ambesolman is offline
post #123 of 603 Old 07-05-2014, 04:43 PM - Thread Starter
ambesolman's Avatar
Liked: 895
New twist...
My sister-in-law has a piece of black marble or granite that she said I could have. Could make a nice addition to the top of the sub. Of course she has no idea how big it is but was intended to go in the floor in front of her fireplace. A corner is broken off but may be able to recut it and use it to my advantage. It'd be really nice if it were big enough in case I build a second sub. Will find out this week!
Mfusick, LTD02 and chalugadp like this.
post #124 of 603 Old 07-07-2014, 08:04 AM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
I'm trying to find a jasper jig that will allow for the 18 5/8" circle I want to cut. However, I can't find one that goes bigger than 18 3/16
What are y'all using to cut these larger circles? Got a link?
I just measured out past the 17 1/2" mark on my jasper and drilled a new hole for 18 1/2" using an 1/8" drill bit, worked perfect for all 8 cutouts for the corinthians...
ambesolman and Boxozaxu like this.
beastaudio is offline
post #125 of 603 Old 07-07-2014, 08:46 AM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
Cheater!
popalock is offline
post #126 of 603 Old 07-07-2014, 08:56 AM
Point Source
beastaudio's Avatar
Liked: 2826
Hardly What's the new avatar pic? Air particle velocity to the MLP?
post #127 of 603 Old 07-07-2014, 09:04 AM
popalock's Avatar
Liked: 1712
I stole it from here.
popalock is offline
post #128 of 603 Old 07-08-2014, 10:26 AM
Boxozaxu's Avatar
Quoted: 455 Post(s)
Liked: 295
If you already own the jasper jig and just want a simple solution, screw your router to a long flat board (1/4 hardboard would work) and then drill a pivot hole for the pin. A throw away jig just to keep things rolling.
(You know, beastaudio's suggestion is probably better if you do have room on the jig for an additional hole.)
Boxozaxu is online now
post #129 of 603 Old 07-08-2014, 10:30 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I used a home made jig for all my sub box driver holes. Jigsaw is another option but usually not as good.
Mfusick is offline
post #130 of 603 Old 07-08-2014, 12:07 PM - Thread Starter
ambesolman's Avatar
Liked: 895
Thanks for the suggestions. I'll decide on a method when it gets time to start cutting some holes.
Picking up the marble/granite slab today after work. Once i get the demensions i can redesign the box again if need be. Hoping it's big enough for a whole top (or two) or at least a good size inlay. Gonna have to get it cut on either way. Does HD or Lowes do that?
post #131 of 603 Old 07-08-2014, 06:48 PM - Thread Starter
ambesolman's Avatar
Liked: 895
HD and Lowes don't do that, but found a couple of places nearby that do. Gonna have to ride around with this slab of granite til Thursday when I can take it to get cut up. It's black and brown and should look pretty nice. The usable dimensions are roughly 60x19x1". It's rough around parts so I'm going to get them to cut straight edges with a tiny round over all the way around and cut it in half to give me two equal sizes. This way I'll have a matching piece if I decide to do another box Hopefully I can make it flush with the wood with a little wood filler when the time comes. Just hoping it doesn't cost an arm and a leg to get it done. Either way it should make it look pretty sweet!
Here's some pics!
LTD02 likes this.
post #132 of 603 Old 07-08-2014, 10:01 PM
popalock's Avatar
Liked: 1712
Man, that is a nice slab'o rock right there.
I'm sure you could make something really nice with that. I personally would want it a few inches wider so I could do a overlay with an inch or two overhang all around, but making an inlay like you mentioned earlier sounds pretty cool. Maybe a bit more advanced than your standard box build, but the potential is there. I've seen people integrate granite into their designs on several different occasions and the added mass helps further dampen the box to reduce vibration, walking, etc..., but I don't think I've ever seen a build on AVS with an actual granite inlay.Anyone else?
Seems like you might possibly have enough to do two DO boxes...
Scott Simonian and ambesolman like this.
popalock is offline
post #133 of 603 Old 07-08-2014, 11:26 PM - Thread Starter
ambesolman's Avatar
Liked: 895
Thanks! Yeah a whole top with an overhang would be ideal but it's only about 18" wide so I don't know if it'll be wide enough to do that with the DO 18s and their mounting depths I'll have to play around with the measurements and see what I can figure out.
Edit: yeah definitely not wide enough. The mounting depth is 9.5" per speaker😕
LTD02 likes this.
post #134 of 603 Old 07-09-2014, 02:42 PM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Subbed - looking forward to seeing some sawdust!
Gorilla83 is offline
post #135 of 603 Old 07-09-2014, 04:15 PM - Thread Starter
ambesolman's Avatar
Liked: 895
You and me both 'rilla! I'll see if the stone cutter can give me any final dimensions tomorrow when I take it in, or at least a good estimate.
I have to work fri-mon then have to leave town for a couple of weeks. While I'm gone I'll finalize the box design, cut sheet and order an amp. When I get back, hopefully the 18s and stone will be waiting on me and I can get cranking on the box! I'm sure I'll have more questions in the meantime
LTD02 likes this.
post #136 of 603 Old 07-10-2014, 01:07 PM - Thread Starter
ambesolman's Avatar
Liked: 895
Went and dropped off the granite slab a few minutes ago. So they'll end up giving me two pieces that are 27.75 x 17.5". They'll smooth the edges and radius all corners. The best part is it's only gonna cost me about $100!!!
Can't wait to see how they turn out
LTD02 likes this.
post #137 of 603 Old 07-10-2014, 05:04 PM
Maklar's Avatar
Quoted: 42 Post(s)
Not a sub and not an inlay but it does have an awesome baffle: http://techtalk.parts-express.com/sh...ranite-Baffles
Maklar is offline
post #138 of 603 Old 07-10-2014, 05:33 PM
popalock's Avatar
Liked: 1712
Dayum... that's some next level stuff right there!
popalock is offline
post #139 of 603 Old 07-10-2014, 08:30 PM - Thread Starter
ambesolman's Avatar
Liked: 895
Fershizzle
post #140 of 603 Old 07-11-2014, 07:28 AM
Point Source
beastaudio's Avatar
Liked: 2826
I bet that front baffle doesn't flex....
post #141 of 603 Old 07-11-2014, 07:59 PM
Maklar's Avatar
Quoted: 42 Post(s)
Hah, turns out he did a sub with a granite top too. http://www.baniels.com/granite-subwoofer-top/
Maklar is offline
post #142 of 603 Old 07-11-2014, 08:24 PM - Thread Starter
ambesolman's Avatar
Liked: 895
That dude does some nice work
post #143 of 603 Old 07-11-2014, 09:20 PM
Maklar's Avatar
Quoted: 42 Post(s)
I believe he works for a granite cutting company so that helps out, still has great skills though.
Maklar is offline
post #144 of 603 Old 07-12-2014, 03:21 PM
Point Source
beastaudio's Avatar
Liked: 2826
^^^^ No kidding. That is an impressive setup I wouldn't even consider an A-T screen with that type of beauty going on.
post #145 of 603 Old 07-12-2014, 03:26 PM
chalugadp's Avatar
Liked: 1505
Yeah but that TV is puny
post #146 of 603 Old 07-12-2014, 05:16 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
that guy in cali with the quasar builds did something with stone. I'll see if I can find it.
Listen. It's All Good.
LTD02 is offline
post #147 of 603 Old 07-12-2014, 05:18 PM
LTD02's Avatar
Liked: 2576
LTD02 is offline
post #148 of 603 Old 07-12-2014, 06:20 PM
Maklar's Avatar
Quoted: 42 Post(s)
Those are some heavy looking subs! Great find LTD02
Maklar is offline
post #149 of 603 Old 07-12-2014, 06:39 PM - Thread Starter
ambesolman's Avatar
Liked: 895
Yeah, makes me wish I had more free granite
+1
post #150 of 603 Old 07-12-2014, 06:55 PM
Maklar's Avatar
Quoted: 42 Post(s)
You might be able to get some remnant granite for fairly cheap as well. Lots of times granite stores will sell their left over from cuts a lot cheaper, I'm hoping to do something like that for a living room end table sub.
Maklar is offline
