Will any of the flared port options work with standard abs or PVC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-23-2014, 03:38 PM - Thread Starter
Samps's Avatar
Quoted: 786 Post(s)
Liked: 409
3 inch preferred but I could make 4 inch work.
If not, what is the best way to attach abs or PVC pipe to mdf? If I cut the hole a little tight would pressure fitting be enough?
Samps is online now
post #2 of 16 Old 06-23-2014, 04:03 PM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
cut a hole that is barely bigger that OD of pipe in a piece of mdf one inch-two inches square larger than pipe diameter. then glue pipe to piece. then glue this piece to wherever you want hole for port after you cut out said hole. then use round over bit to get flare. hope I explained it right
manuetdeo is offline
post #3 of 16 Old 06-23-2014, 04:11 PM - Thread Starter
Samps's Avatar
Quoted: 786 Post(s)
Liked: 409
If I understand that method correctly how much additional length does the added mdf with roundover add?
Samps is online now
post #4 of 16 Old 06-23-2014, 05:24 PM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
if i remember correctly the thickness of 3/4 mdf models pretty close in winisd to the flare it shows, i could be and am frequently wrong- so i hope someone who knows for sure will be along and answer for you.
post #5 of 16 Old 06-23-2014, 05:40 PM - Thread Starter
Samps's Avatar
Quoted: 786 Post(s)
Liked: 409
Thanks. If it's close to the winisd model it should work fine. Off by 1db either way won't hurt.
Samps is online now
post #6 of 16 Old 06-24-2014, 08:28 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
wvu80 is offline
post #7 of 16 Old 06-24-2014, 08:51 PM - Thread Starter
Samps's Avatar
Quoted: 786 Post(s)
Liked: 409
Originally Posted by wvu80 View Post
Is there any reason you wouldn't simply buy a flared port? They look relatively inexpensive.
http://www.parts-express.com/cat/speaker-port-tubes/320
I need 3 ports and the prefab ones would cost too much to be worth it. I'm either making my own or going with the slot port. The slot port is looking better the more I read. Cramming 3 ports into a medium size box is presenting a number of problems. If I could get away with 2 it would work better but then they become too long and creat new problems.
Samps is online now
post #8 of 16 Old 06-24-2014, 09:06 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
Wink
The Fusion 12 Tempest uses those slot ports and they are listed at $13 for three.
http://www.diysoundgroup.com/wavegui...ion12-kit.html
I think you should use them, because I have them and they look cool.
Name:	Fusion 10 Pures and Dayton Audio UA721 center.JPG
wvu80 is offline
post #9 of 16 Old 06-25-2014, 10:47 AM
Bud Heavy's Avatar
Quoted: 27 Post(s)
Liked: 24
Do you mean Fusion 10's use slot ports? Tempest use round ports.
Bud Heavy is offline
post #10 of 16 Old 06-25-2014, 11:19 AM
Bud Heavy's Avatar
Quoted: 27 Post(s)
Liked: 24
I plan on building a set of Dayton UM-18's whenever they finally come in. Box design calls for 2 - 4" ID ports by 19.84". A comment was made on PE that this 4" flared port will fit inside a pvc pipe - Part # 260-403. I haven't ordered them yet, but I am getting ready to and hopefully they will fit inside a pvc pipe which is much cheaper than buying that long of a port tube from PE. Another option is to make the flare on the end of a pvc pipe yourself. I saw a pretty good youtube video of this. Just heat the end of pvc until it is pliable and shape it over a bowl.
In my past subwoofer builds I have always mounted the flare on the inside of the cabinet, I like the look better. Cut your hole to match the flare, roundover on the outside, rabbet on the inside so the rim sits in the rabbet and PL glue it up really good.
post #11 of 16 Old 06-25-2014, 11:27 AM - Thread Starter
Samps's Avatar
Quoted: 786 Post(s)
Liked: 409
Let us know if that flare fits the PVC. I actually have that flare using the kit in one of my subs right now but it is glued in place. I wish I would have tested it before I glued it. The flare is a little brittle. I tried using gasket tape under it a when I screwed it down one of the screw holes cracked. So be careful how tight you make the screws.
Samps is online now
post #12 of 16 Old 06-25-2014, 12:00 PM
djarchow's Avatar
Liked: 27
I like the Precision Ports. They are cheaper than Dayton flared ports where you have to buy the individual parts. Thinwall DVW PVC pipe connectors fit the 4" Precision Port flares very well. I use that for elbows. It is a bit loose for the straight Precision Port tubes but a strip of duct tape around the tube makes for a snug fit.
djarchow is offline
post #13 of 16 Old 06-25-2014, 12:20 PM
Bud Heavy's Avatar
Quoted: 27 Post(s)
Liked: 24
Do you need the connector ring to attach the flare port and pvc?
post #14 of 16 Old 06-25-2014, 12:24 PM
djarchow's Avatar
Liked: 27
I didn't use the straight PVC. I was using the elbows since Precision Port doesn't make elbows. The 4" flairs fit tightly in the elbow. You have to use the DVW pipe though, regular schedule 40 doesn't work.
djarchow is offline
post #15 of 16 Old 08-22-2014, 01:30 PM
Bud Heavy's Avatar
Quoted: 27 Post(s)
Liked: 24
Update on PE's 4" flared port #260-403 . They fit 4 inch drainage(sewer, thin walled, SDR35) pipe which isn't your more commonly available pvc(schedule 40). Couldn't find it at home depot but Menards and Lowe's ONLY had it in 10' lengths with one belled end($12) . The port slides right into the belled end, but you need a coupler($1.19) if you want to join it to a non-belled end. If you had SDR41 pipe you may not need a coupler. They do have fins around the pipe at the flare which I have read people were able to break/cut off. I plan on mounting these inside my cabinet so it's a non-issue for me.
Now my UM-18's are hanging out with some 4" pipe just waiting for there new 12 ft^3 homes to be built.
post #16 of 16 Old 08-22-2014, 01:43 PM
corndogggy's Avatar
Quoted: 157 Post(s)
Liked: 44
Do a calculation for two 18" UltiMax subs at the recommended setup of three 4" ports that are 28" long, and do it at a right angle. The end result is about $400 after shipping.
corndogggy is offline
