IB Home Theatre Setup - Design Ideas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-25-2014, 07:38 PM - Thread Starter
Liked: 0
Hi, I'm new here and this is my first post. Not likely to be my last considering how active and helpful everyone seems to be. Having said that, here goes....
I have a relatively large room in my basement where my home theatre is. You'll notice in the front center a section of 45deg bumpout. This currently houses my a/v equipment. (all kinda stacked up on the floor ) The house is quite new, we've only just finished building in February with much left to do but we're living here now so that's the best part.
I really want to do an IB setup for the subs and I can basically fill in the 45deg. section to do so. Bracing the wall is no problem so I am thinking of having the subs fire out into the room. My question is if I can get reasonably good results using just 2 of the Fi IB318's? I can have roughly 140cu.ft. of volume behind the wall so if I have to go with more it is possible.
When I get my wall and shelving designed I'll post some CAD renderings but for now I've posted a pic which shows the room dims.
Thanks in advance,
Scott
_WeaSiL_ is offline
post #2 of 8 Old 06-25-2014, 11:33 PM
BassThatHz's Avatar
Quoted: 2296 Post(s)
Liked: 2038
The more subs the better; until the threshold of pain is reached. Otherwise there is no non-zero minimum or maximum.
The formula is as simple as that!
BassThatHz is offline
post #3 of 8 Old 06-26-2014, 02:37 AM
LTD02's Avatar
Quoted: 2461 Post(s)
Liked: 2781
in a big room, ported cabs will help a lot for the low end.
infinite baffle is limited the same way sealed subs are. all the work must be done by the driver. with enough of them, that's not a problem...but 'enough' can sometimes be a really large number. :-)
Listen. It's All Good.
LTD02 is offline
post #4 of 8 Old 06-26-2014, 04:35 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 180
How would two IB3-18's in an IB configuration compare to two Dayton HO18's with each in a full sized MartySub? What about comparing those same two HO18's, each in a full sized Marty, but with four IB3-18's in an IB configuration with two manifolds of two drivers each?
Martycool007 is offline
post #5 of 8 Old 06-26-2014, 04:48 AM
LTD02's Avatar
Liked: 2781
here you go marty. green 2x martysubs. blue 2x ib's.
doubling up the fi drivers (going from 2 to 4) would give +6db, roughly.
LTD02 is offline
post #6 of 8 Old 06-26-2014, 12:42 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
In a room this size (~4500cu) I would want 4 Marty's or 6 ib318s, but I don't know what your listening style is. This should get you close to reference levels.
If I had to pick between the two, I would go IB318.
Stumbo is offline
post #7 of 8 Old 06-26-2014, 04:21 PM - Thread Starter
Liked: 0
I really and truly wish that I could do 6 IB's. Unfortunately that just isn't the case. If I do decide to go with the two 18's and I'm getting the impression that it is a feasible option. I'm thinking of using DIYsoundgroup speakers for the rest of the system. If I pair up 4 of the Fusion-6's for surround duties, and 2 Fusion-10 Pures for LR and a Fusion-4 Quad4 for Center, would there be any large holes in the system? I have wiring in place for the 6's to hang from ceiling.
Thanks again,
Scott
_WeaSiL_ is offline
post #8 of 8 Old 06-26-2014, 09:35 PM
Thomas-W's Avatar
Quoted: 22 Post(s)
2-18"s aren't enough for a room that large unless you plan on sitting 10' from the IB.
There's a $10/driver discount available when 4 drivers are purchased at one time, that's probably your best bet if the budget is limited.
Note: don't mix ported subs with IB's, If you need additional drivers to even out in room response use low 'Q' sealed boxes with an IB
IB Subwoofer FAQ
Thomas-W is offline
