2 sealed 15's vs 1 ported 18 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BrutalBodyShots
post #1 of 13 Old 07-03-2014, 12:06 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 30
Looking to add on to my existing set up. This is the forum where overkill is the norm right?
Currently using 2 um15's in sealed 4 cubic ft boxes.
Am thinking the next upgrade will be:
2 more um15's in sealed 4 cubic foot boxex. Cost about $700 total for both drivers and cabinets.
or
1 Dayton Audio RSS460HO-4 18" Reference HO in a diysoundgroup ported Stonehenge flat pack
- 5.4 cu ft ported to 20hz. Cost would be about $475 for the 1 driver and cabinet.
http://www.diysoundgroup.com/ported-...tonehenge.html
Would love to see how these 2 options graphed out for output and frequency response.
My gut says to go the first route as it will integrate the easiest but trying to keep the cost in check.
Looking for your 2 cents. Thanks guys.
jake515 is offline
post #2 of 13 Old 07-03-2014, 12:23 PM
BrutalBodyShots's Avatar
Quoted: 353 Post(s)
Liked: 85
or
I would think adding a ported 18 to the two sealed 15's you have now much sound a bit off. I think SQ wise adding two more 15's would be your best bet, but you'd likely give up a bit of SPL. I'm sure one of the guys on here can post you a graph comparing the two options. Two 15's offer a little over 35% more cone are over a single 18 which might give you an extra db if the 18 were sealed, but since it's ported you'd gain quite a bit more in the >20hz content.
BrutalBodyShots is offline
post #3 of 13 Old 07-03-2014, 12:37 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Bassment is online now
post #4 of 13 Old 07-03-2014, 02:56 PM
notnyt's Avatar
Quoted: 2151 Post(s)
Liked: 1980
The ported 18 will give you more output by far down low.
IMO, two ported 18s. UM18s release soon
notnyt is offline
post #5 of 13 Old 07-03-2014, 03:01 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
What does the system fail to do? That is to say, what variety of overkill are you looking for?
HopefulFred is online now
post #6 of 13 Old 07-03-2014, 07:20 PM
Quoted: 353 Post(s)
Liked: 85
UM-18's are 1/2-3/4 of a year behind, so saying they will be "released soon" is wishful thinking.
Also, for ported cabs they require much larger enclosures than the SI-18, Dayton HO, UXL-18, etc with about 50% more internal volume.
chalugadp likes this.
post #7 of 13 Old 07-03-2014, 07:50 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
WHat is a UM18 ?
Mfusick is offline
post #8 of 13 Old 07-03-2014, 09:18 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 30
The existing system is really quite good. Just wanting to take it up a notch. Always wanting to put together something special and unique from the listeners perspective.
jake515 is offline
post #9 of 13 Old 07-03-2014, 10:06 PM
notnyt's Avatar
Liked: 1980
notnyt is offline
post #10 of 13 Old 07-04-2014, 09:05 AM
Quoted: 353 Post(s)
Liked: 85
Well Jake, adding two more sealed 15's in addition to what you have now should give you 3db. It would also give you an even smoother response in your room by spreading out your sources of output even better than with just 2 enclosures. I guess the question is whether or not 3db is "good enough" for you or if you'd desire more down the line. Going with two 18's, still sealed, is only a marginal cost over two 15's generally speaking and would probably give you almost 5db over your current setup which is pretty nice. If you're looking for that 6-10db gain, you're going to have to go ported but again I'm not sure how that would blend with your sealed enclosures; I've never mixed them so you'd have to ask some of the more qualified/experienced guys on here their opinions on it.
post #11 of 13 Old 07-04-2014, 09:28 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
6 dB if he's increasing the amplification
post #12 of 13 Old 07-04-2014, 07:28 PM
Smittyfit's Avatar
Quoted: 83 Post(s)
Liked: 27
jake515 -> Hard situation.... How about.... Build a HUGE horn or ported subwoofer tuned LOW, send under 30hz to it.
Then use the 15" subwoofers as midbass modules. Place them near field listening position, and have the horn in corner for more bass reinforcement.
Best of both worlds?
Hahahaha, just a suggestion
Smittyfit is offline
post #13 of 13 Old 07-04-2014, 07:55 PM
BassThatHz's Avatar
Quoted: 2030 Post(s)
Liked: 1546
Keep saving up for dual UXL-18 then. If space is a concern 20x20x20 or so sealed, otherwise ported.
They can replace your UM-15's, or you can buy another amp and run all 4. Use them to smooth out the bass(?)
BassThatHz is offline
diysoundgroup , stonehenge , um15
