Duratex rocks! - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #1 of 49 Old 07-03-2014, 01:42 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 30
Duratex rocks!
Ordered a gallon and 3 rollers for eighty bucks delivered.
That gallon has covered 2 4cu ft sealed enclosures and 3 88 specials from the diysoundgroup.
All 5 cabinets look good I still have at least half of the gallon left.
Impressive stuff for sure. It is not often a product lives up to the hype but Duratex does.
jake515 is offline
post #2 of 49 Old 07-03-2014, 02:00 PM
BrutalBodyShots's Avatar
Quoted: 353 Post(s)
Liked: 85
Have any pictures of your finished product(s)?
BrutalBodyShots is offline
post #3 of 49 Old 07-03-2014, 02:23 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Couple of questions since I will be using duratex to cover my four sub's. The roller from them is all I need ? (Don't need to buy other painting gear )
How do you control the pebble factor ? I want a slight bumpy look. Pics would be good
chalugadp is offline
post #4 of 49 Old 07-03-2014, 02:24 PM
notnyt's Avatar
Quoted: 2152 Post(s)
Liked: 1981
notnyt is offline
post #5 of 49 Old 07-03-2014, 03:03 PM
wyattroa's Avatar
Quoted: 165 Post(s)
Liked: 117
Originally Posted by notnyt View Post
took me a gallon per cabinet
I wonder if it also depends on the material, mdf vs plywood.
Sub build http://www.avsforum.com/forum/155-di...et-r-done.html
Center - JBL LC2
Mains - JBL L820
Surrounds - JBL L820
Sub - Dual UXL'18 enclosures,iNuke6000dsp
wyattroa is offline
post #6 of 49 Old 07-03-2014, 03:04 PM
notnyt's Avatar
Liked: 1981
well my cabinets were huge... so kind of expected.
notnyt is offline
post #7 of 49 Old 07-03-2014, 03:37 PM
wyattroa's Avatar
Quoted: 165 Post(s)
Liked: 117
Lol, I know that..I have been through your build many of time dreaming. Still makes me wonder about material though and maybe soaking in on plywood.
Center - JBL LC2
Mains - JBL L820
wyattroa is offline
post #8 of 49 Old 07-03-2014, 03:38 PM
notnyt's Avatar
Liked: 1981
I think MDF might be thirstier... I had almost a good coverage with one coat.
notnyt is offline
post #9 of 49 Old 07-03-2014, 03:45 PM
wyattroa's Avatar
Quoted: 165 Post(s)
Liked: 117
Good to know as I am not too far off from the painting stage of my two subs. I will have to see how the duratex is with the mdf. I have a gallon of it.
Center - JBL LC2
Mains - JBL L820
wyattroa is offline
post #10 of 49 Old 07-03-2014, 03:54 PM
Quoted: 3255 Post(s)
Liked: 2743
you can have a range of textures using Duratex. I prefer the leather smooth look and for that you just get a fine foam roller from your local big box. It goes a long way.
eljaycanuck and chalugadp like this.
post #11 of 49 Old 07-03-2014, 03:59 PM
chalugadp's Avatar
Liked: 1505
OK so pebble controlled by roller. Gotcha ya
post #12 of 49 Old 07-03-2014, 04:20 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
Chalugadp, the texture below was done using the blue 4 inch roller that often gets sold with the duratex. if this is to much texture/bumpiness, you can always use a foam roller and it will come out a lot less textured.
this pic blows up pretty big, because it's high res. this close up gives you a good idea.
and op, you are right....duratex is an AWESOME PRODUCT!
kevings is online now
post #13 of 49 Old 07-03-2014, 04:22 PM
chalugadp's Avatar
Liked: 1505
I will get a couple of different rollers . to hide a seam in MDF do I need the texture you have Kev ?
post #14 of 49 Old 07-03-2014, 04:27 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
true, but its because in some countries, your cabinets would be considered nice size houses.
notnyt likes this.
post #15 of 49 Old 07-03-2014, 04:29 PM
notnyt's Avatar
Liked: 1981
hiding MDF seams you're going to want to hit it with some spackle anywhere there are seems to keep it flat and fill it in before painting
notnyt is offline
post #16 of 49 Old 07-03-2014, 04:35 PM
chalugadp's Avatar
Liked: 1505
I already filled it , so no gaps and nice and smooth to the touch. Should be OK ?
post #17 of 49 Old 07-03-2014, 04:36 PM
asarose247's Avatar
Quoted: 695 Post(s)
Liked: 451
Lowes has a flat black, Icon series for about $20/gal, makes a great first coat/primer surface sealer defect detector. dries in a heart beat and if you thin it a bit, apply with a foam roller, you can keep texture to very low and get a sealed surface for more control the far more expensive duratex top coat. it also sands easlily enough it you want to minimize grain raising or mdf surface swelling.
YMMV
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #18 of 49 Old 07-03-2014, 04:36 PM
notnyt's Avatar
Liked: 1981
MDF doesn't have grain really, so should be fine as long as everything is smooth and filled...
notnyt is offline
post #19 of 49 Old 07-03-2014, 04:37 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
i used plywood and i would say that my seams are like 80-90% hidden. if you want to be sure you see no seams, i would do a little spackling / sanding. If i had to do it all over again, this is an extra step id take.
( im actually doing this step on my coffee table build, so we will see if end up nailing it and finishing with no seams )
post #20 of 49 Old 07-03-2014, 04:42 PM
chalugadp's Avatar
Liked: 1505
I think I will try a base coat then the duratex. I know I'm not as picky as some. The room that my stuff is in has little light. Painted my center channel stand yesterday with basic acrylic black and can barely see the seams.
post #21 of 49 Old 07-03-2014, 04:43 PM
asarose247's Avatar
Quoted: 695 Post(s)
Liked: 451
the flat black also makes for a good proof coat before final, especially wrt to plywood/mdf edges/joints"smoothness" and lack of edge/seam/joint evidence
post #22 of 49 Old 07-03-2014, 07:00 PM - Thread Starter
Quoted: 109 Post(s)
Liked: 30
Attachment 147010
I used the blue roller from duratex and it did come out a little rough.
My theater is pretty dark so everything kind of disappears once the movie starts. In a brighter room I can see wanting to used a different roller.
jake515 is offline
post #23 of 49 Old 07-03-2014, 07:05 PM
chalugadp's Avatar
Liked: 1505
How u liking the 88's ?
post #24 of 49 Old 07-03-2014, 07:30 PM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
I just did a search on the Canadian sites (.ca) for Lowes, HomeDepot and Rona. None of them seems to sell DuraTex. (According to the Acry-Tech site, it looks like the only Canadian distributor is located in Waterloo, Ontario.)
If I use the Icon primer as a first coat, would any reasonably good-quality, low-gloss wood paint work well as a subsequent coat? Or is it better / safer to go with a "texture-y" product comparable to DuraTex?
eljaycanuck is offline
post #25 of 49 Old 07-03-2014, 07:36 PM
chalugadp's Avatar
Liked: 1505
Duratex only available online. You might want to put a coat of black primer on first and then see how the seams are. My guess is you will still see them from close up. It depends on how picky you are. Won't hurt. If you are not happy with it then put duratex over top. From 4' and back I don't think you will see seams with just regular paint.
eljaycanuck likes this.
post #26 of 49 Old 07-03-2014, 07:38 PM
Liked: 1798
Yeah, I'll see how the cabs look after a primer coat of Icon.
Is there an alternative to DuraTex that anyone uses / can recommend? Or is DuraTex THE paint to use?
post #27 of 49 Old 07-03-2014, 07:51 PM
notnyt's Avatar
Liked: 1981
notnyt is offline
post #28 of 49 Old 07-03-2014, 07:52 PM
Liked: 1798
OK, thanks, that might be an option. I guess it'll all depend on how the primer works out.
post #29 of 49 Old 07-03-2014, 08:17 PM
chalugadp's Avatar
Liked: 1505
I think duratex is the most trouble free. Bedliner works well but I have seen a couple people have trouble. Depends upon your painting skill.
post #30 of 49 Old 07-03-2014, 09:02 PM
wyattroa's Avatar
Quoted: 165 Post(s)
Liked: 117
I wasnt thinking of priming mine before, but i am now. I am going to fill in all brad hole and the seams before hand and sand it down. Figured I might as well try to do it right..well, as much as I can..lol
Robert
Center - JBL LC2
Mains - JBL L820
wyattroa is offline
