What would be the better choice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-04-2014, 04:45 PM - Thread Starter
04rex's Avatar
Quoted: 118 Post(s)
Liked: 26
I am trying to decide between which sub to build. I will be getting the inuke1000 for sure, the 1.5 cu ft diysoundgroup sub box for sure and only 1 (wife issues).
Should I go with the infinity 12" that some people have built or the Ultimax 10? What would be better?
It would be in a 18x13 ft room with 9ft ceilings and open to 1 side. Essentially used for everyday tv watching, music and maybe a movie. No crazy bass is needed as I already have a home theatre in the basement.
Just want the best sub for that box and my room.
04rex is offline
post #2 of 5 Old 07-04-2014, 05:38 PM
notnyt's Avatar
Quoted: 2286 Post(s)
Liked: 2107
I'd go dual opposed infinity in single box if budget is the consideration, otherwise dual opposed um12 =]
notnyt is offline
post #3 of 5 Old 07-04-2014, 06:19 PM - Thread Starter
04rex's Avatar
Quoted: 118 Post(s)
Liked: 26
Can't do a bigger box size than that though.
04rex is offline
post #4 of 5 Old 07-04-2014, 07:03 PM
BassThatHz's Avatar
Quoted: 2058 Post(s)
Liked: 1608
1.5cuft is 14x14x14, mounting depth of UM-12 is 6.22inches.
It will be tight but it should work.
You will need two 1000dsp's or one 3000dsp though. One will be underpowered by ~66%, or ~3.3db
BassThatHz is online now
post #5 of 5 Old 07-04-2014, 09:13 PM - Thread Starter
04rex's Avatar
Quoted: 118 Post(s)
Liked: 26
Is that with the infinity dual opposed or a single um12 in a small box?
04rex is offline
