Solder- does it matter what kind I use ? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By BassThatHz
  • 2 Post By Audio Geek
  • 1 Post By Audio Geek
post #1 of 14 Old 07-08-2014, 02:32 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I am running low. Does it matter what kind of electrical solder I buy ? I use mostly for crossovers, and general electrical stuff.
Someone link me ? or suggest good product and place to buy ? I need some.
Mfusick is offline
post #2 of 14 Old 07-08-2014, 02:44 PM
dtsdig's Avatar
Quoted: 828 Post(s)
Liked: 914
A basic 60/40 like this is fine.
http://www.amazon.com/Electronic-Sol...eywords=solder
Really, just find any decent rosin core 60/40 with a diameter that makes sense for your application and you're good to go.
dtsdig is offline
post #3 of 14 Old 07-08-2014, 02:45 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
60/40 is best for electronics, Kester makes the "best" solder and parts express sells it. http://www.parts-express.com/kester-...spool--370-090 I don't think you need necessarily buy the "good stuff" for crossovers though. It's more crucial on microelectronics where if you hold the iron too long you wreck your stuff.
Bassment is offline
post #4 of 14 Old 07-08-2014, 02:47 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I want ROSIN CORE though right ?
Mfusick is offline
post #5 of 14 Old 07-08-2014, 02:59 PM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Bassment is offline
post #6 of 14 Old 07-09-2014, 04:50 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1550
Diamond Solder. Nothing but the best will do! Like a boss!!!
How you are going melt the diamond is beyond me though!
Mfusick likes this.
BassThatHz is offline
post #7 of 14 Old 07-14-2014, 07:46 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Lol @ that ring
Mfusick is offline
post #8 of 14 Old 07-14-2014, 05:19 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
If you get 63/37 solder (eutectic solder), you eliminate any possibility of cold solders (for peace of mind).
notnyt and andyc56 like this.
Audio Geek is offline
post #9 of 14 Old 07-24-2014, 09:28 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
How about wire strip and splice ? Is there a proper method for maximizing signal transfer ? Does it matter ?
Mfusick is offline
post #10 of 14 Old 07-24-2014, 09:46 AM
notnyt's Avatar
Quoted: 2152 Post(s)
Liked: 1981
Not really, don't nick the wire. Can cause a weak point.
notnyt is offline
post #11 of 14 Old 07-28-2014, 08:17 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
You mean like cut through the jacket too hard and kill some strands ?
Mfusick is offline
post #12 of 14 Old 07-28-2014, 12:42 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Solder: 37/63.
Non solder: crimper, lugs and terminal blocks.
A9X-308 is offline
post #13 of 14 Old 07-28-2014, 04:00 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Originally Posted by A9X-308 View Post
Solder: 37/63.
lol I bought 40/60. What's better about 37/63 ?
Mfusick is offline
post #14 of 14 Old 07-28-2014, 05:02 PM
Audio Geek's Avatar
Quoted: 91 Post(s)
Liked: 42
I mentioned it before...
It also has a lower melting point so you don't have to heat the wires/components up as much.
That said, I also have a whole roll of 60/40 to go through. But my next one will be 63/37. If I knew then what I know now...
Mfusick likes this.
