upgrade bookshelfs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-08-2014, 09:08 PM - Thread Starter
lite2's Avatar
upgrade bookshelfs
Can an existing brand name bookshelf be upgraded with aftermarket parts? Thanks.
lite2 is offline
post #2 of 4 Old 07-09-2014, 05:31 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
For the most part, no. If you change any of the drivers on an existing speaker, then you would need to rework, or build a new crossover, which is extremely difficult to do. It takes a very long time reading and studying speaker design to be able to build your own crossovers:
Martycool007 is offline
post #3 of 4 Old 07-09-2014, 05:32 AM
mobeer4don's Avatar
Quoted: 123 Post(s)
Liked: 117
Yes, but...
The speaker was designed and optimized as a complete system...woofer, tweeter, crossover, and enclosure. Making a change in one almost certainly requires a change somewhere else and those changes may not be simple or easy to figure out without measurement and testing gear. In many cases, you are probably better off getting a "better" speaker rather than trying to "fix" an existing one.
mobeer4don is offline
post #4 of 4 Old 07-09-2014, 07:53 AM
Bassment's Avatar
Quoted: 910 Post(s)
Liked: 366
they can be replaced, they won't necessarily be an upgrade. Most likely would be worse. Look up your specific speakers and see if anyone has done modifications, sometimes people find really good replacements, or crossover modifications, or something to give good improvements.
Bassment is offline
