Dayton UM-15-22 compared to what commercially? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-10-2014, 05:22 PM - Thread Starter
DBryant's Avatar
I bought the kit from PE. SPA-1000 amp, UM-15-22 driver, and their 3 cu' flat pack box. Since I have around $700 into this project I am hoping it will outperform subs from SVS, HSU, in this price range. Is this the case?
DBryant is offline
post #2 of 6 Old 07-10-2014, 06:23 PM
BassThatHz's Avatar
Quoted: 1996 Post(s)
Liked: 1501
http://www.data-bass.com/systems
It should be similar to a SVS PB-13 Ultra sealed.
It you had bought a inuke3000DSP instead you could have EQ'ed the subs and added another for not much more money, and would be even louder.
I use 6 UM-15's in my mains, they do good for the money...
BassThatHz is offline
post #3 of 6 Old 07-11-2014, 06:21 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 175
I agree with BassThatHz in that you should have gone with the iNuke3000dsp amplifier for the EQ/DSP capabilities and the option to add another sub when funds permit. See if you can return that Dayton amp, and possibly go with the iNuke3000dsp, which may also be cheaper if you shoo around!
Martycool007 is offline
post #4 of 6 Old 07-12-2014, 03:09 AM - Thread Starter
DBryant's Avatar
I wish I could-got it slightly used off of Fleabay. I had actually looked at the Inukes prior to getting the PA amp. Maybe I will try to resell it and get the Inuke. I currently have a 15" Dayton Reference HF sub in a ported box but with just the PE 230 watt plate amp powering it. If I had been thinking I could have used the Inuke to better power the Dayton HF.
DBryant is offline
post #5 of 6 Old 11-03-2015, 08:28 AM
chadsmith013's Avatar
Quoted: 488 Post(s)
Liked: 440
http://www.youtube.com/watch?v=DJq0NDSXH9Y
I know this is old but man I cant even imagine how loud and deep that is.
chadsmith013 is offline
post #6 of 6 Old 11-04-2015, 10:21 AM
HOTDIGITY's Avatar
Quoted: 114 Post(s)
Liked: 88
I'm thinking of 1 UM-15 in a sealed box, around 3cu.ft. to use in a 2.1 music only setup. I currently have a sealed 12" Rythmik servo sub and was looking to get higher output without breaking the bank.
HOTDIGITY is offline
